FastAndFurious wrote in post #15039639
I currently own a 70-200 IS II that I have been using for portraits with my 5D3. I love it, but indoors it's tough to use due to F2.8, which is why I have been looking at 85L for a few weeks now but I'm really puzzled as to if I'm making the right decision. If the owners of the lens can kindly respond to these questions, that'd be great:
My main subjects are toddlers/kids.
1) Is it any useful indoors or is it too tight? I also have 35L that I can use if things get too tight.
2) Is the focus too slow to the point of being useless? Why I ask this is, as I work with toddlers and kids, I don't have the luxury to ask them to stand still or pose.
3) Is not having weather sealing a problem? Can you take this lens to the beach or use it under light rain?
4) Can the same level of subject isolation be achieved by FL usage in 70-200 (say using it at 200 @ F2.8) which makes 85L irrelevant?
I feel like I'm wasting money owning both lenses, but the pictures 85L produces look just so good. I also need 70-200, because I couldn't do without its fast AF outdoors (mostly in playgrounds, etc).
On the wide end, I have only 35L, so I can also use the money I have for 85L for the new 24-70 II, but that will have the same issue with F2.8, they are just not fast enough to be used indoors.
1) It might be tight, but that really depends on the room you are in so that is hard to judge. But as you said, you have a 35mm to cover you if that case ever arises.
2) If the focus was so slow it would be useless, people wouldn't be buying this lens
The focus is ONLY slow on the initial going-from-infinity. And even then its not really that slow, thats all based on different people's opinions. Some say its a snail, some shrug it off and it doesn't affect what they shoot. In my case, it hasn't affected my photos. Ive used it to shoot running puppies, horses, etc. Once it has its focus area, it makes the minor adjustments fine. It will be slow if you are shooting at one moment something close to you, and then swinging around and aiming at something in the distance, then it will be slower. Its not hunting, it just has a lot of glass to move.
3) I'm not 100% about this one. I rarely use my lenses in rain. But the other day I was taking photos of a puppy and it started to spit. I didn't stay out that long once it started, but the lens did get a bit wet. It was fine. I wouldn't push it though, but thats just me being my overprotective self.
4) I would say not at all. At 200 f/2.8 your lens produces very nice subject isolation to be sure, but the 85 lets you stand a lot closer to your subject, and with the wider apertures available to you, a 2.8 at 200 won't look like a 1.2 at 85mm. The 1.2 is magical
and not magical as in "soft dreamy" as the lens is quite sharp wide open. But the bokeh is creamy and buttery smooth.
