Thread started 26 Sep 2012 (Wednesday) 19:29
Sizing different pics for a composite
RandMan
Joined Mar 2012
Sep 26, 2012 19:29 |  #1
I have never really done any compositing in the past but have been dabbling a bit in it recently. One thing I'm confused about is how exactly you should resize different images that are going to be copied into the composite image. Sometimes I copy/paste them in and convert to a smart object. Then I do free transform but if the image is much bigger than what it's being added to then I go through this very long and clumsy process of shift-dragging the image a little bit, then moving so I can get to the corner anchor point, then dragging a little, then moving, then dragging and so on. It feels sloppy and tedious.
Is there a better way? I could do image>resize/resample but then I would have to guess at what size I want it, then keep doing it over again until it's right.
Also, is there a big quality difference in doing a free transform to resize versus going through the image resize/resample dialogue?
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
D ­ Thompson
Sep 26, 2012 20:18 |  #2
Give File/Place a try. It will place the new file as a Smart Object which should react to the transformation better.
Once you have selected the Transform tool - look at the tool bar for the W(idth) & H(eight), click the chain between them and use it to resize when it is a lot bigger.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
RandMan
Joined Mar 2012
Sep 27, 2012 11:21 |  #3
Thanks Dennis--do you happen to know the answer to the question about quality difference between that vs. the image size dialogue?
D ­ Thompson
Sep 27, 2012 15:08 |  #4
Sorry, can't say for sure. I have read that it is better to only use Transform once, meaning get it how you want before hitting enter to accept. The article hinted that accepting, then applying another Transform may affect quality.
I don't do a lot of composites so hopefully someone who does will chime in. When I do I either use the File/Place or with the second image open I'll right click and then choose Duplicate Layer and choose the other file in the Destination box. The File/Place may be better if you're putting a smaller image into a larger one.
Dennis
René ­ Damkot
Sep 27, 2012 16:57 |  #5
RandMan wrote in post #15047318 (external link)
None whatsoever, but the transform will use the default re-sampling set in the PS prefs, while the "Image Size" will let you choose every time.
Smart objects are preferrable if you're not sure about the transform, since you can alter it without losing IQ.
http://www.photoshopla​b.com …marter-smart-objects.html (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
RandMan
Joined Mar 2012
Sep 28, 2012 14:47 |  #6
René Damkot wrote in post #15051241 (external link)
Bingo! This thread is officially closed for business--Rene I'm not sure what you do all day night but you seem to answer every single post I've ever made on this site and I thank you tremendously for that. And Dennis--thank you very much as well.
-Randy
René ­ Damkot
Sep 28, 2012 16:18 |  #7
RandMan wrote in post #15054936 (external link)
I'm an assistant and image editor mainly. Which involves some idle time behind a Mac ;)
You're welcome :)
1,299 views & 0 likes for this thread, 3 members have posted to it.
1061 guests, 102 members online
