Thread started 27 Sep 2012 (Thursday) 16:49
What are the difference between these two?
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Sep 27, 2012 16:49 |  #1
I know that both these lenses are considered crappy so no need to discuss that, i've come to the conclusion that i use my 55-250 II 2% of the time i'm out taking photos, it's mainly my 50mm 1.8 and my Samyang 8mm that are mounted.
Therefore i've decided to sell my 55-250 and buy the cheapest telezoom i could find, just to have it in those rare occasions and instead save money for Canons 50mm 1.4.
So, my question is.. whats the difference between these two?
Sigma 70-300/4-5,6 DG CA
IMAGE: http://www.netonnet.se/ItemImages/foto/objektiv/objektiv-canon/sigma-70-3004-56dgca(104078)-Large.jpg
Sigma 70-300/4-5.6 DG APO MACRO
IMAGE: http://www.netonnet.se/ItemImages/foto/objektiv/objektiv-canon/tele/sigma-70-3004-56dgapomacroc(153669)-Large.jpg
Sure the name says MACRO, but according to Sigmas website, they both have "macro".
http://www.sigmaphoto.​com/shop/telephoto-zoom-lenses (external link)
But when i try to find reviews of the Sigma 70-300/4-5,6 DG CA all i get is the macro version with the red ring... or some really old version that looks nothinglike the CA one.
So.. i need help, the price difference between these two are 60 bucks but since i need to save all extra money to get the 50mm 1.4, and the fact that these two seems identical other than the color and the red ring.. there is no argue.
And while i'm at it... i've tried turning off IS on my 55-250 just to get used to it (since the ones above doesent have IS) and i see no problems above 1/80s.. below that it gets blurry when zoomed 250mm.
You people that use lenses without IS.. whats your saying about IS, do you really need it when taking photos handheld?
Thanks!
"High life on low budget"
bent photos (external link)Portfoliobox (external link)
X-Pro1 XF 35 f/1.4
Virto
Joined Nov 2010
Sep 27, 2012 16:53 |  #2
DG CA looks like the newer (current) Sigma finish and uses SLD glass.
The prices are both very low, but I think I'd rather have the more recently designed 70-300mm F4-5.6 DG Macro rather than the red-ring model.
Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
ABR800 - Several flashes, remote triggers, stands, too many and yet not enough lenses
macroimage
Sep 27, 2012 18:09 |  #3
I've used both models a lot. If you want one of these, then spend the little extra to get the one with the APO DG macro designation, ie the red ring version. If you don't you will wish you had later. Buy it used and save even more money.
The APO version is much sharper, especially at the long end. Both lenses have the same mechanics and build. Both have the same slow autofocus. Both can focus down to 0.5x lifesize macro with a good working distance. Both include the lens hood. The APO version includes a nice lens case while the non-APO one does not. The APO version has much better optics, that is the only real difference.
The non APO version is sharp at 70mm and slowly degrades as the focal length gets longer until it is a bit soft at 300mm. The APO version stays quite sharp all the way to 300mm and has much less chromatic aberration. With either lens, don't use a UV filter or protection filter unless it is really needed as few filters have the optical flatness required to not soften the image at 300mm. Do use the hood to improve the picture contrast. Using correction software to fix chromatic aberration helps make any lens look better but especially cheap ones.
With the high magnification, these work nicely for taking pictures of more dangerous insects like hornets where you might not want to get so close with a normal macro lens.
I don't mind not having IS on a telephoto. IS is convenient but not required. I've gotten great shots without it. Keep your shutter speeds up above 1/640s and you'll be fine. Or use a monopod, much less hassle than a tripod but still improves your pictures.
Photo Gear
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Sep 28, 2012 02:30 |  #4
macroimage wrote in post #15051476 (external link)
Just now i found the differences of these two, over at ephotozine they did a review.
The APO version have two more lenses that further remove CA.. other than that, as you said, they are identical.
I can't find it used here in Sweden.. and since i rarely use telezoom or macro for that matter, i think i will be fine with the cheaper version. I do appreciate your well written reply.
X-Pro1 XF 35 f/1.4
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
Sep 28, 2012 05:54 |  #5
hold on you lost me.
why are you selling the 55-250? its a better lens than either of these two and you wont be netting any additional money by selling the 55-250. you will only get about $150 USD for it.
if anything save a bit more for the 50mm and sell the 50/1.8 when the time comes or sell sell the 50/1.8 and the 55-250, buy the lens you want now and worry about a telezoom later.
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Sep 28, 2012 06:39 |  #6
mike_311 wrote in post #15053132 (external link)
I want a tele for those rare occasions, but i also want a 1.4 50mm. If i sell the 55-250 and buy the cheapest possible telezoom and save the rest of the money for a 1.4 and also sell the 1.8 50mm for around $70, this way i can get $110 but still have a telezoom with macrofunctions.
X-Pro1 XF 35 f/1.4
mike_311
Gallery: 18 photos
Joined Mar 2011
Sep 28, 2012 06:49 |  #7
my point was i dont see how you net any real profit from selling the 55-250 and buying the sigma.
you are giving up an awful good lens to make $40, if you could even make that.
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Sep 28, 2012 06:52 |  #8
mike_311 wrote in post #15053209 (external link)
My experience with the 55-250 isent all that good, sure i only used it like 10 times since i bought it.
And i havent used any cheap sigma/tamron.. so it might be god awful if i buy a sigma.
But i don't use it as much as i thought i should.. but yea, i might not get a price for it.
hmmm.. might take this into consideration... thanks.
X-Pro1 XF 35 f/1.4
mike_311
Gallery: 18 photos
Joined Mar 2011
Sep 28, 2012 08:31 |  #9
unless you are sending good money on a telezoom, just keep it, or sell it outright and buy what you want, i.e. the 50mm/1.4.
if you aren't impressed then there is no point in keeping it, let alone buying some other cheap lens just to cover a focal length, buy something you will get use from.
if you look at my lens lineup, i dont have anything longer than 85mm, not becuase i cant afford one, but because i really have no need for one and even if i did have one and wasn't impressed with it i definitely wouldn't want to use it.
i made a decision a while ago not to keep lenses i dont use and in turn sell them and buy what i get use from. no point in keeping a lens on the shelf for "just in case i need it someday". that's what renting is for.
to add: you wont have any problem selling a 55-250, if you buy one of those other lenses you may never get rid of it unless you take a huge loss.
2,127 views & 0 likes for this thread, 4 members have posted to it.
1456 guests, 128 members online
