Thread started 27 Dec 2005 (Tuesday) 08:45
Monitor Calibration
Kristy
Gallery: 31 photos
Location: A dream world where nothing is what it seems.
Dec 27, 2005 08:45 |  #1
Hello all... I have a question about calibrating my monitor. I don't have any nice software addition and am just using the adobe gamma thing.
Problem is that is is asking me what my Phosphors are and I have no idea what that means???
I'm using a HP 17" LCD... I hear LCD's are more difficult to calibrate?? Problem is that my last batch of developing did not turn out as on my screen... frustrating when I spend so much time getting things to look a certain way. My prints were much darker and more saturated than what I see on my monitor.
Any advice?? And does anyone know what a "Phosphor" is??
Life is not measured by the number of breaths we take,but by the moments that take our breath away.
~George Carlin
Kristy :D 5D MkIII, 24-70 / f2.8 L, 2 AB800's, and some modifiers.
My Website Page (external link)
dbump
Joined Apr 2003
Dec 27, 2005 17:30 |  #2
Phosphors are the chemical elements of a CRT monitor--you have an LCD display, which does not use phosphor to generate light and color.
I've read reputable authors who suggest that the stock manufacturer's display profile is better for LCDs than trying to calibrate them visually, using Adobe Gamma.
Instead, you might look at a hardware calibrator, like ColorVision's spyder (make sure to get a newer version that specifically mentions it works with LCDs). If your budget is a bit more flexible, spyders from Monaco/X-rite and Gretag Macbeth are very well reviewed:
http://www.drycreekpho​to.com …tor_calibration​_tools.htm (external link)
(more great info at that site too)
If you want even more info, check "Real World Photoshop CS2" by David Blatner and Bruce Fraser
http://www.amazon.com …n=507846&s=book​s&v=glance (external link)
It's has a great intro to color management in the first few chapters. If you want to drink from a fire hose, try Fraser's "Real World Color Management."
7D, G10, 17-55 f/2.8 IS, 70-200 f/2.8 IS, 100 Macro, 50 f/1.4, 430EX II
There are no wrong notes
--Thelonious Monk
Robert_Lay
Dec 27, 2005 17:39 |  #3
Dear Kristy,
Don't feel bad about problems with an LCD monitor. Mine has really noticeable shifts in contrast and brightness with no more than a few inches of head movement up and down. Not only that, but the little patterns that they want you to adjust so that they "blend in" - they don't - no matter what you do.
Mine is a ViewSonic 17" model VX 710. As soon as I get around to it, I'm going to swap it out for a different make and model, and if that doesn't work I'm going back to glass bottle.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
redbutt
Joined Aug 2001
Dec 27, 2005 17:43 as a reply to  @ Robert_Lay's post |  #4
Get absolutely as far back as you can (litterally so you can barely operate the keyboard and mouse), and squint your eyes when you make the adjustments to the patterns. You will see the blending MUCH better.
epolevne
Dec 27, 2005 18:07 as a reply to  @ redbutt's post |  #5
Kristy-
Your monitor will almost always look brighter than room-lit prints because a monitor is actually a light source while your print just reflects the light of the room. To make prints look better make sure there's a lot of light on the picture. If it's a good print you'll see more detail and better colors.
Where did you get the prints done? Do they have an option for "don't touch my colors" (I've seen it called TrueColor among other things)? Of course if the tech doing the printing edits the pictures then all bets are off :-)
Robert-
My wife and I went to several stores looking for LCDs that would allows us to sit next to each other at the desk and see the same colors. The best looking bunch that we saw in person were the Apple displays.
Online research indicated that Dell uses the exact same LCD panel in its FPW series, being several hundred dollars cheaper than Apple we now have 2 Dell 2005FPWs. The biggest downside is that it has problems displaying pure black, but other than that there's 0 color shift for at least a 90 degree viewing angle (after that it's only slight).
Epolevne
5D, 300D w/grip, 550EX, Kit 18-55, Tokina 12-24/4, Tamron 28-75/2.8, 85/1.8, 70-200/2.8L IS, LowePro CompuTrekker Plus AW Backpack
Robert_Lay
Dec 27, 2005 20:04 as a reply to  @ redbutt's post |  #6
Thanks, I'll try the squinting!
Bob
Kristy
Gallery: 31 photos
Dec 29, 2005 00:22 |  #7
Thanks guys... I've been researching and trying to calibrate to the actual photo on my desk.... UUUGGGHHH.... I decided to just buy a calibration tool. It will save me trouble in the long run, I believe. I found Monaco XR Pro on special at www.chromix.com (external link) and have decided to give it a try... hopefully all will be well. I'll post my findings when it arrives.
Thank you again for the very informative posts and also for the time you spent answering my questions...
oh, and by the way... I get my developing done at WHCC... I was doing fine with them until my last set of prints came in.... they re-ran my order and when they came back looking exacly the same, I realized I had a problem and not them... Oh the woes.... I'm avoiding any editing right now because it seems like a waste of time if they prints are not what my monitor is telling me I'll get.
~George Carlin
pxl8
Dec 29, 2005 02:17 |  #8
Here's what I did to match my Sony LCD for sRGB.
I used the 2.2 gamma charts on this page: http://www.photoscient​ia.co.uk/Gamma.htm#men​u (external link)
I adjusted the gamma curves for each channel in the gfx card driver until the squares all looked grey and thus blended. It took some time and I used 3 points on each curve to do it but the final result is that when I print with sRGB the prints are a perfect match.
One thing to note when using these charts on a LCD monitor is that moving them up or down a pixel changes how they look due to the way the RGB cells are laid out in the monitor. I double checked I had them in the right place by viewing them at 200% as well as 100%. That probably doesn't make sense - but it will if you try it.
-- PXL8
1DmkIV, 5DmkIII + 135mm f/2L, 24-70mm f/2.8L, Sigma 35mm f/1.4
guitarman3
Dec 29, 2005 03:27 as a reply to  @ pxl8's post |  #9
Kristy, I think you're on the right track with monaco. I just got the non-pro version and it's amazing what it can do for an LCD screen. I too, have waited a while to process a big batch of photos for fear that they will come out way off color-wise. Now I can do it confidently. You've made the right choice in IMHO.
Dennis
40D and grip, black XT, EF 17-40L, EF 50mm 1.8 II, Canon 100-400L, Canon 1.4X, Sigma 1.4x TC, Canon 580EX, Canon RC-1 Remote, Stofen Omni Bounce, Manfrotto 681B w/ 486RC; 3021BPro w/ 488RC
http://dsdphotos.zenfo​lio.com (external link)
dbump
Joined Apr 2003
Dec 29, 2005 07:28 as a reply to  @ guitarman3's post |  #10
Dennis,
If you bought the non-Pro version in the last month or so, check out their rebate offer--they'll send you a free upgrade to the Pro version of the software.
I'm having trouble reaching their site right now, so I can't give you the exact link, but it should be right on the Optix page at www.monacosys.com (external link).
--Thelonious Monk
sony23
Dec 29, 2005 13:31 as a reply to  @ Robert_Lay's post |  #11
Robert_Lay wrote:
Dear Kristy,
Robert
If your going to upgrade your Viewsonic with another model I would suggest one that I just got which has srgb built in and it is so easy to calibrate my home printer and lab printers, its a ViewSonic 19" model VA1912w widescreen.
Bruce
Kristy
Gallery: 31 photos
Dec 29, 2005 16:50 as a reply to  @ dbump's post |  #12
dbump wrote:
Dennis,
I'm having trouble reaching their site right now, so I can't give you the exact link, but it should be right on the Optix page at www.monacosys.com. (external link)
If you're taking advantage of the rebate do it soon because I believe it expires on Dec 31st. :) Great deal, Great offer!! :)
~George Carlin
Robert_Lay
Dec 29, 2005 17:03 as a reply to  @ sony23's post |  #13
sony23 wrote:
Robert
Bruce
Very interesting - I wasn't planning on purchasing any new monitors, because I have too many sitting around already gathering dust. I am seriously thinking of backing up to one of my 17" glass CRT types just to see if it is really any easier.
Nonetheless, I appreciate the input. Maybe things will look different 6 mos down the road.
Thanks,
Bob
2,661 views & 0 likes for this thread, 8 members have posted to it.
Monitor Calibration
2306 guests, 135 members online
