Thread started 28 Sep 2012 (Friday) 18:13
Couple 5D III Questions.
SpartanWarrior
Sep 28, 2012 18:13 |  #1
Hi need to know a few things,
1, in live view mode in low light i see a lot of noise specs is this normal? And that is at ISO 100.
2, i tried using mirror lock up but when I take the picture it exposes for like 20 sec when my exposure is 5sec, and then it doesn't show that a picture was taken,
3, is using live view like using mirror lock up?
Thanks;)
Canon 5D III, EF 24-105 f4, EF 16-35 2.8 L II, EF 70-200 2.8 IS L II, EF 100 2.8 IS L, EF 2x III, EF 1.4x III, 500D 77mm close up filter, Kenko extension tubes set, SpeedLight 600 EX RT, Metz 58 AF-2, Pixel Kings, Benro C3780T Tripod, Benro G3 Ball Head.
www.chrisksphotography​.com (external link)
SpartanWarrior
Sep 28, 2012 18:22 |  #2
#2 i was using a shutter release cable and you still have to enable the camera timer for mirror lock up.
amfoto1
Sep 28, 2012 20:24 |  #3
A lot of noise is most likely due to the long exposure. There are settings to reduce it. Experiment with them. Also don't judge too much by what you see on the camera's LCD monitor. Look at the images on your computer, and perhaps do some more noise reduction if needed.
Long exposure noise reduction doubles the length of an exposure. After the initial shot, the camera takes another of the same length of time with the shutter closed which it uses to identify noise so it can subtract it from the first shot.
Live view is done with the mirror up and the shutter open. There is no need to also use mirror lockup when using Live View.
One exception, if you use Quick Focus while in Live View, the shutter closes and the mirror drops back down momentarily while the camera focuses, then the mirror flips back up and the shutter opens. (The contrast detection method of focus used in Live View is slow, but can be very accurate.)
It's not a bad idea to use a cable switch to make the exposure in Live View. That way you don't touch the camera and accidentally bump it.
Snapshot101
Joined Jun 2011
Sep 29, 2012 00:12 |  #4
OK I have a ? on the 5d MarkIII.
I have the 5d Mark II and a firend of mine has the same- He shoots a lot of HDR photos.
Today he told me that on the 5d Mark II he was only able to do HDR on images that were only 2 stops up or down and when he does this on his 60d he is able to use images great than 2 stops up or down.
On the 5d Mark III is there a limit of 2 stops or is it a higher limit like the 60d?
Thank you.
Sanpshot101
SpartanWarrior
Sep 29, 2012 01:28 |  #5
amfoto1 wrote in post #15056064 (external link)
I dont"t mean noise in the final image, the images look great but noise in live view zoomed in and trying to manually focus my EF 100 2.8 IS L at 1.1 Macro,
Thanks.
SpartanWarrior
Sep 29, 2012 01:31 |  #6
Snapshot101 wrote in post #15056694 (external link)
Thank you.
Sanpshot101
The 5D III can do up to 7 shots for HDR, and it can do 3 shot in camera HDR.
jack880
Gallery: 13 photos
Joined Apr 2011
Sep 29, 2012 03:55 |  #7
SpartanWarrior wrote in post #15056815 (external link)
Thanks.
If theres not much light the data from the sensor will need to be boosted to give you a real time preview on the lcd screen which will create noise.
https://www.flickr.com​/photos/jackhenriques/ (external link)
1DX, 7D, 20D, G7X II, 70-200 f/2.8 L IS II, 24-70 f/2.8 L, 16-35 f/2.8 L II, 50 f/1.8 II, 50 f/1.4, TS-E 17 f/4 L, 8-15 f/4 L, Sigma 17-50 f/2.8, Sigma 8-16 f/4.5-5.6, Sigma 150 f/2.8 macro, x1.4 extender II, Kenko extension tubes, 430 EX II x 2, DJI Mavic Air
Mashimaro
Sep 29, 2012 03:59 |  #8
Thanks.
This sounds normal to me.
My 50D, 7D and 5D2 did this when looking at the LCD during live view in darker situations. Never shows in pictures though as what appears on the LCD.
Canon 5D4 / Sony A7R2 / Leica M240
SpartanWarrior
Sep 29, 2012 04:04 as a reply to  @ Mashimaro's post |  #9
Thanks, ya also stacking my kenko extension tubes made it worse, I was in my kitchen doing some macro shots and it was very low light, so that was the problem.
Snapshot101
Joined Jun 2011
Sep 30, 2012 16:41 |  #10
SpartanWarrior wrote in post #15056824 (external link)
Thank you.
Can the 5dMKIII in camera HDR allow you to use shots that are greater than 2 stops up or down of each other ?
According to my friend that does HDR's with his 5dMKII, the 5dMKII does not allow you to do HDR shots in camera that are greater than 2 stops up or down of each other. His 6od on the other hand will allow for it. I told him I would find out which way it is on the 5dMK III.
Thank you.
Snapshot101
SpartanWarrior
Sep 30, 2012 17:31 |  #11
Snapshot101 wrote in post #15062052 (external link)
Thank you.
Thank you.
Snapshot101
The 5D II doesn't have in camera HDR you can only bracket the shots for HDR -2 0 +2, the 5D III has HDR in Camera -3 0 +3 or you can bracket your 7 shots.
Snapshot101
Joined Jun 2011
Sep 30, 2012 18:12 |  #12
Thank you!
dave_bass5
Gallery: 34 photos
Oct 01, 2012 04:48 |  #13
Might be worth downloading the manual for the 5DMKIII and having a read of it. These questions are all answered in there, even the noise issue in LV.
Dave.
Gallery@http://www.flickr.com/​photos/davebass5/ (external link)
Canon R7 | Canon EOS-M50 | Canon 24-70 f/2.8L MKII | 70-300L | 135L f/2.0 | EF-S 10-18 | 40 f/2.8 STM | 35mm f/2 IS | Canon S110 | Fuji F31FD | Canon 580EXII, 270EXII | Yongnuo YN-622C Triggers.
thallikar
Joined Nov 2011
Oct 01, 2012 06:12 |  #14
Thank you.
Thank you.
Snapshot101
60D does not allow HDR. Your pal is getting confused with HDR vs bracketing exposures.
http://500px.com/thall​ikar (external link)
http://www.flickr.com/​photos/64724969@N06/ (external link)
ItsMike
Oct 01, 2012 06:29 |  #15
As for the HDR...
I always Manually did it.. You are on a tridpod for the most part.. This way is makes it so you can bracket as many shots as you want..
(I use the Exp comp. 0 -1 +1 -2 +2 -3 +3) any more then that requires just some simple math to figure out shutter speeds..
Gear
3,125 views & 0 likes for this thread, 9 members have posted to it.
615 guests, 124 members online
