if you really think about how the camera works, it's not the megapixels that grant great cropping ability, it's the size of the sensor. The megapixels only determine the size of the image generated by the sensor following after processing of the image. The higher the megapixels, the higher the "density" of the image (higher number of image area per amount of sensor size), but the actual quality of the image is determined by the sensor size.
Take, for example, utilizing a crop sensor and a full frame. You use the 1.6 field of view crop factor because the sensor on an APS-C camera is 1.6 times smaller than the sensor on a full frame--this achieves the effect of making an image from an APS-C camera appeared more "zoomed in", which people may view as a valuable attribute; however, the reality is that cropping the final image from a full frame sensor down to 1.6 times it's original diagonal length achieves the exact same effect as taking a picture with an APS-C camera. The only advantage of an APS-C camera is that you are able to achieve high density images more easily (high number of megapixels per area of sensor). Due to the squaring effect (linear increases in length amount to exponential increases in area), in order to retain the same resolution you get from an 18MP APS-C camera, you'll need to have a full frame sensor that outputs to ~47 megapixels (hopefully I did that right).
Until we get a 47MP full frame (which is pretty inpractical), the 18MP APS-C will continue to have a "resolution advantage" (although be careful with the term "resolution", its actually a politically incorrect term, "pixel density" is more correct) over full frame cameras. This arguably makes them better for taking giving one a range advantage with the 1.6 FOVCF, but, for the reasons I just explained, density only helps so much, as you're typically more limited by the sharpness of your lens. If density were more important than sensor size, we would all be using cell phone cameras with ultra high megapixels (okay maybe not, but you get the point).
All of this being said, does the statement "zoom's aren't necessary anymore as we can crop easily with those full frame sensors" hold much water? In a way, yes it does, granted that you're willing to live with an image that does not live up to its full potential. again, pixel density aside, cropping the final image is effectively exactly what we do with APS-C cameras; however, if you have the ability to zoom in (or shoot at longer focal lengths), you retain the (relatively) full quality of the image whist not having to move in closer to your subject. Also, different focal lengths meter a scene differently (subject to background ratio), and obviously grant different depths of field.
