Thread started 29 Sep 2012 (Saturday) 08:52
Time for some prints
DigitalDon
Joined Aug 2012
Sep 29, 2012 08:52 |  #1
I have taken the pictures with my Canon T3i, doctored them up in PS Elements and I want to take my SD card to Wal-Mart to see if prints look anything like the pictures on my computer. Question is what format is Wal-Mart be capaible of printing, can they make prints from PS files, camera raw or do I need to do Jpegs and what size do they need to be.
Thanks, hope all is having a great weekend
(EOS RebelT3i EF-S 18 - 55 IS II Kit) (EFS 55 - 250 mm lense f/4-5.6 IS II) (YONGNUO YN 565EX flash)
ejenner
Gallery: 98 photos
Joined Nov 2011
Sep 29, 2012 10:25 |  #2
You definitely want to output .jpeg or .tiff in sRGB. Aside from that I don't know what Wall-Mart will want.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
DigitalDon
Joined Aug 2012
Sep 30, 2012 09:54 |  #3
ejenner wrote in post #15057628 (external link)
Thanks for the info
Clark
Sep 30, 2012 09:58 |  #4
I would try to find someplace other than walmart too. Every print I have tried there, the colors are way off.
Um... Hi
DigitalDon
Joined Aug 2012
Sep 30, 2012 11:31 |  #5
Clark wrote in post #15060780 (external link)
Thank you Clark, I don't know about walmart but I do know my printer is junk when it comes to pinting photos.
jra
Sep 30, 2012 11:35 |  #6
I agree.....I've made prints at Wal-mart on a number of occasions when all I needed was something quick and cheap. I've found that Wal-mart is a hit or miss in the color area and you may get a nasty color cast or a decent image. If you want/need consistent images, choose a printer that focuses more on quality.
Wilt
Sep 30, 2012 13:15 |  #7
Wherever you go to have prints made, tell them NOT to Auto Correct, but print the files as is, else you run the risk of jumping to the wrong conclusions about the print density. Furthermore, improper adjustment of your monitor settings are very likely to fool you as well, unless you have taken steps to evaluate and have set your monitor with tonal scales like this to try to be able to see all 26 steps...
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/grayscale_adjust.jpg
...or unless you have done proper calibration with a calibration tool and software.
Rimmer
Joined Nov 2010
Sep 30, 2012 16:15 |  #8
Just for whatever it's worth, I used to print 8x10s occasionally at Walmart and had good, consistent results. I used their "instant" print service (don't recall what they actually call it) where you insert your media, select what you want printed, and the prints come out in just a few minutes, not their drop-off service. The local Walmart has some kind of HP equipment for this. I haven't used them for the past year or more since I started ordering from Mpix. As they say, YMMV.
Another issue: You wrote about printing your edited photos, but then mentioned taking in your SD card, which would contain your original RAW files I assume, not your edited images. You will want to send JPGs in sRGB color space to whatever print service you plan to use. (Just as an experiment one day I found that the HP devices at Walmart could also handle 8-bit TIFFs, but seemed to choke on 16-bit TIFFs.)
Ace Rimmer -- "What a guy!"
"Smoke me a kipper, I'll be back for breakfast." ;)
DigitalDon
Joined Aug 2012
Oct 02, 2012 07:31 as a reply to  @ Rimmer's post |  #9
Thanks to all for the great info, will be putting it all to practice.
Lobstrosity
Joined Aug 2012
Oct 02, 2012 09:57 |  #10
Costco does a pretty decent job for prints if you need them done locally. You can upload online at costcophotocenter.com and then go pick them up in a couple of hours - very handy.
Canon EOS 7D | Canon EF 135mm f/2L USM EF 70-200mm f/4L USM | Sigma 17-50mm f/2.8 OS HSM
lookingforaname
Oct 02, 2012 11:20 |  #11
walmart has been AWFUL for me. I did side by side comparisons of Walmart, walgreens, snapfish, shutterfly, and then the ones recommended here frequently: adorama pix, mpix.com, and a local photog shop, and the last three were SOOOOOOO much better and not significantly more expensive. I recommend mpix as the easiest solution. It's really worth the extra change.
June Day Photography - Junedayphoto.com (external link)
2,527 views & 0 likes for this thread, 8 members have posted to it.
1047 guests, 105 members online
