Thread started 30 Sep 2012 (Sunday) 05:48
Wide Angle Lense Use On Groups
uneek78
Joined Nov 2011
Sep 30, 2012 05:48 |  #1
Would using a wide angle lens lower than a 24mm be bad on people are a large group? I'd say from 1 person to 30 tops. Or how much lower can I go until I see major distortion?
Gerard Payne | www.gerardpayne.com (external link)
Canon Rebel T1i | Canon 50mm f/1.4 | Canon 24-105L |Canon 55-250mm f/4-5.6
SkipD
Joined Dec 2002
Sep 30, 2012 06:11 |  #2
uneek78 wrote in post #15060155 (external link)
I'm sure you are thinking of perspective distortion. This is not caused by focal length choice. Instead, it is caused by your choice of camera position relative to the group (and the subsequent choice of focal length to fill the frame).
Please read our "sticky" (found in the General Photography Talk forum) tutorial titled Perspective Control in Images - Focal Length or Distance?.
Skip Douglas
frugivore
Gallery: 11 photos
Sep 30, 2012 07:58 |  #3
In addition to the perspective distortion that Skip mentioned, you can also run into rectilinear correction distortion which causes the outer track of the imaging circle to become 'stretched', so it's best to keep your subjects away from the sides of the frame.
Then there is barrel distortion which is a result of this correction (or lack thereof). Both of these can be adjusted with software, but perspective 'distortion' cannot be. At least I'm not aware of any software that does this.
FrostMonolith
Joined Aug 2012
Sep 30, 2012 09:40 |  #4
I don't think that "wide-angle-barrel-distortion" thing is mentioned either. If so, zoom the lens at a tighter focal length.
Calvin is me.
"Passion vs Technique" is not different to "Loving vs To Love"
T3i | 10-22mm f/3.5-4.5 USM | 35mm f/2 | 50mm f/1.4 USM | 70-300mm f/4-5.6L IS USM | Full Weaponry | DigitalRev (external link) | New Blog (external link)
"Nope, the white squares doesn't do any worse than the red dots"
2n10
Gallery: 79 photos
Joined Sep 2012
Sep 30, 2012 10:00 |  #5
frugivore wrote in post #15060371 (external link)
DxO Optics Pro has some tools that could be a possibility. Haven't used them in this context though.
John
Equipment
My Portfolio (external link)
Wilt
Sep 30, 2012 16:17 |  #6
I have found, using multiple format sizes, that the diagonal AOV of 74 degrees is pretty safe for group shots without noticeable induced perspective distortion...
17mm on APS-C, 28mm on FF, 47mm on 645 are safe FL for group shots
uneek78
Joined Nov 2011
Sep 30, 2012 19:17 |  #7
Thanks all! Great info!
Zlatko ­ Batistich
Joined Sep 2009
Sep 30, 2012 19:43 |  #8
Wilt wrote in post #15061970 (external link)
I agree. 28mm on FF is about as wide as you can go and still have people near the edges look normal. 24mm and wider is tricky — people toward the edges start to look wide, so you may end up backing up and cropping to avoid that effect.
hollis_f
Oct 01, 2012 05:39 |  #9
2n10 wrote in post #15060789 (external link)
I have. Indeed, trying to slim down the people at the edge of an UWA crowd shot was the only reason I ever used DxO Optics. Now the same correction of anamorphic distortions is available as a standalone app or PS/LR plugin - Viewpoint - and I shal probably never load DxO Optics again.
Here's an example...
This is what can happen to somebody standing on the edge of a large group -
IMAGE: http://www.frankhollis.com/temp/Viewpoint%20unchanged.jpg
And this is after one-click in ViewPoint
IMAGE: http://www.frankhollis.com/temp/Viewpoint%20Processed.jpg
Not hard to figure out which is the preferred image.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
1,592 views & 0 likes for this thread
Latest registered member is JohnBlackburn
2965 guests, 223 members online
