How much of a difference will 1.4 get me versus 1.8? Say I'm using 1.8 with 1/20th for shutter at 100 iso what kind of shutter speed would i get with 1.4? I'm trying to decided if the 50 1.4 is worth it, in terms of aperature, compared to the 1.8.
Poe Goldmember 1,956 posts Likes: 15 Joined Oct 2005 Location: Modesto, CA More info | Dec 27, 2005 16:03 | #1 How much of a difference will 1.4 get me versus 1.8? Say I'm using 1.8 with 1/20th for shutter at 100 iso what kind of shutter speed would i get with 1.4? I'm trying to decided if the 50 1.4 is worth it, in terms of aperature, compared to the 1.8.
guitarman Senior Member 875 posts Likes: 1 Joined Jun 2005 Location: Canada Ontario More info | Dec 27, 2005 16:06 | #2 Poe wrote: How much of a difference will 1.4 get me versus 1.8? Say I'm using 1.8 with 1/20th for shutter at 100 iso what kind of shutter speed would i get with 1.4? I'm trying to decided if the 50 1.4 is worth it, in terms of aperature, compared to the 1.8. If thats all that matters then get the 1.8. There is more to it than that as far as the differences to those lenses. The 50 1.4 is every bit worth it and to me is just as good a value for money as the 1.8 version. But thats because I value the other differences, such as better more solid build, faster more accurate focus and a much nicer bokeh, atleast in my opinion. Terry
condyk Africa's #1 Tour Guide 20,887 posts Likes: 22 Joined Mar 2005 Location: Birmingham, UK More info | Dec 27, 2005 16:13 | #3 I've seen decent bokah with both so not sure if that critique re. the 1.8 is entirely valid. Many use it as a reason to get the 1.4 but I dunno. I've never used the 1.4 so this is just an observation of shots I've and shots I've taken in the past. I guess it's a personal cost/benefit thing. https://photography-on-the.net …/showthread.php?t=1203740
guitarman Senior Member 875 posts Likes: 1 Joined Jun 2005 Location: Canada Ontario More info | condyk wrote: I've seen decent bokah with both so not sure if that critique re. the 1.8 is entirely valid. Many use it as a reason to get the 1.4 but I dunno. I've never used the 1.4 so this is just an observation of shots I've and shots I've taken in the past. I guess it's a personal cost/benefit thing. I've owned both. The 1.8 has circular looking rough bokeh. To some that may be fine and may be even preferred. I don't like it. The 1.4 has a much smoother looking bokeh similar to that of the 70-200L F2.8 IS that I have also owned. I find most people that buy the 1.8 because its cheaper than most filters I've bought and gives an excellent sharp photograph. Nothing wrong with that. I also beleive you get much more for the extra money with the 1.4. Terry
guitarman Senior Member 875 posts Likes: 1 Joined Jun 2005 Location: Canada Ontario More info | Here is an example just to illustrate.
The 1.4 version.
Terry
SteveParr should have taken his own advice 6,593 posts Likes: 2 Joined Feb 2005 Location: San Diego, CA More info | Permanent banI've got the 50mm f/1.8, but will be upgrading to the f/1.4 version. Steve
SuzyView Cream of the Crop More info | Dec 27, 2005 17:27 | #7 This has been debated in the forum a lot of times. It's really up to the individual because the 1.4 is twice or more the price of the 1.8. How often are you going to use it? Do you have low light issues? Does construction matter to you? I just purchased a 1.4 and used it for 3 shoots. It is a sharp lens, really fast, and just so small, you can hardly believe it. I never considered the 1.8 because most of the people who have opinions on the two say the 1.4 is worth the extra money. I just went for it. My husband blames the forum people. It's okay. Suzie - Still Speaking Canonese!
Pekka El General Moderator More info | Dec 27, 2005 17:35 | #8 See (on old post) https://photography-on-the.net ….php?p=406267&postcount=2 The Forum Boss, El General Moderator
Dec 27, 2005 17:47 | #9 Thanks for that link pekka. Seem that the f/1.8 will be just fine. I'm not particularly looking for the USM and build of the f/1.4. I'm looking for a lens that will be effective in low light of restaraunts and such, where a flash wouldn't be appropriate. Based on that table which is ISO 100, with the jump to 200 or even 400, the f/1.8 seems to satisfy my needs and is a bargain in terms of price.
JRabin Goldmember 1,496 posts Likes: 1 Joined Aug 2004 Location: NJ More info | Dec 27, 2005 18:05 | #10 Poe wrote: ...Say I'm using 1.8 with 1/20th for shutter at 100 iso what kind of shutter speed would i get with 1.4?... Poe. No one answered your question. The difference is about 2/3 of a stop so you would only obtain 1/30 (1/20 - 1/25, 1/30) with the f/1.4 vs. f/1.8.
uktrailmonster Senior Member 466 posts Likes: 1 Joined Oct 2005 Location: UK More info | Dec 27, 2005 18:07 | #11 Here's a link to a lab test for the 1.8. There is also a test of the 1.4 on the same website. There isn't much in it regarding image quality, but the 1.4 is a tad better. So for the extra money you get better build quality, a nicer MF ring, a slightly wider max aperture and perhaps a small improvement in image quality. Personally, I can't justify the difference in price. That's a call only you can make. Canon 7D, Canon D30, Canon G2, EF 24-85 F3.5-4.5, EF 75-300 F4-5.6 IS, EF 300 F4 L IS, EF 85 F1.8, iMac 24" + Canon i9100
JRabin Goldmember 1,496 posts Likes: 1 Joined Aug 2004 Location: NJ More info | Poe wrote: ...looking for a lens that will be effective in low light of restaraunts and such, where a flash wouldn't be appropriate... Based on that EV reading, shooting ambient light @ f/1.8, you will need at least ISO 800 for a shutter speed of 1/160 minimum to avoid blurry ugly facial gestures and hand movements of people in a restuarant.
rklepper Dignity-Esteem-Compassion 9,019 posts Gallery: 2 photos Likes: 14 Joined Dec 2003 Location: No longer living at the center of the known universe, moved just slightly to the right. Iowa, USA. More info | guitarman wrote: I've owned both. The 1.8 has circular looking rough bokeh. To some that may be fine and may be even preferred. I don't like it. The 1.4 has a much smoother looking bokeh similar to that of the 70-200L F2.8 IS that I have also owned. I find most people that buy the 1.8 because its cheaper than most filters I've bought and gives an excellent sharp photograph. Nothing wrong with that. I also beleive you get much more for the extra money with the 1.4. I agree. The bokeh from the 1.4 seems much more pleasing to me. Doc Klepper in the USA
guitarman Senior Member 875 posts Likes: 1 Joined Jun 2005 Location: Canada Ontario More info | uktrailmonster wrote: Here's a link to a lab test for the 1.8. There is also a test of the 1.4 on the same website. There isn't much in it regarding image quality, but the 1.4 is a tad better. So for the extra money you get better build quality, a nicer MF ring, a slightly wider max aperture and perhaps a small improvement in image quality. Personally, I can't justify the difference in price. That's a call only you can make. http://www.photozone.de …ses/canon_50_18/index.htm I think it all comes down to maybe how much you use the lens. If you use it alot, some of the minor annoyances of the cheaper version can become unbearable. I agree with the poster that said the 85 1.8 is better. I love that lens. Some don't like the longer focal length on a 1.6 crop though and feel that the 50 provides more use indoors where space is limited. Terry
grego Cream of the Crop 8,819 posts Likes: 2 Joined May 2005 Location: UCLA More info | guitarman wrote: I've owned both. The 1.8 has circular looking rough bokeh. To some that may be fine and may be even preferred. I don't like it. The 1.4 has a much smoother looking bokeh similar to that of the 70-200L F2.8 IS that I have also owned. That's because the 50 1.4 has more blades than the 50 1.8, giving it that chance to give a smoother bokeh. It's pretty just like the 70-200 IS's bokeh. Poe wrote: Thanks for that link pekka. Seem that the f/1.8 will be just fine. I'm not particularly looking for the USM and build of the f/1.4. I'm looking for a lens that will be effective in low light of restaraunts and such, where a flash wouldn't be appropriate. Based on that table which is ISO 100, with the jump to 200 or even 400, the f/1.8 seems to satisfy my needs and is a bargain in terms of price. One advantage the 50 1.4 has, its more accurate in low light/more consistent and less likely to hunt. Now how often does that happen? I don't know, but if that's not a concern to you, go with the 1.8 if all the other things don't concern you either. Go UCLA
| Latest registered member was a spammer, and banned as such! 1995 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
