Thread started 01 Oct 2012 (Monday) 18:55
Photozone review of the new EF 28mm f/2.8 USM IS
996gt2
Oct 01, 2012 18:55 |  #1
http://www.photozone.d​e …74-canon28f28isff?start=1 (external link)
For the $800 asking price and considering that a 28mm f/2.8 is a relatively un-ambitious lens, I was expecting something a little better. Corner sharpness is excellent when stopped down but could be better at larger apertures. Not to mention the lack of a lens hood, case, or rear dust seal despite that high price.
IMAGE: http://www.photozone.de/images/8Reviews/lenses/canon_28_28is_ff/28mm_distortion.png
IMAGE: http://www.photozone.de/images/8Reviews/lenses/canon_28_28is_ff/mtf.png
Buy/Sell Feedback
5Dc, 50D, Tokina 12-24 f/4, Tamron 28-75 f/2.8, Sigma 50mm f/1.4, 430EX
nightcat
Oct 01, 2012 19:19 |  #2
The numbers at 2.8 compare favorably to the same numbers of the very expensive and highly regarded Zeiss 28mm 2.0, which of course is manual and has no IS.
996gt2
Oct 01, 2012 19:45 |  #3
nightcat wrote in post #15067082 (external link)
Not quite. The Zeiss is the sharper of the two.
Canon:
Zeiss 28mm f/2 for comparison:
IMAGE: http://www.photozone.de/images/8Reviews/lenses/zeiss_zf_28_2_5d/mtf.png
But we all know that Zeiss lenses have a built-in luxury tax, so price-wise it would be more appropriate to compare the EF 28mm f/2.8 IS with the $700 Nikon 28mm f/1.8 G. It may lack IS, but it's a 1.33 stops faster and sharper than the more expensive EF 28mm IS. I'm not trying to turn this into a Canon v. Nikon debate by any means; rather I simply wanted to present the Nikon 28mm as a basis of comparison.
IMAGE: http://www.photozone.de/images/8Reviews/lenses/nikkor_afs_28_18_d3x/mtf.png
Buy/Sell Feedback
nightcat
Oct 01, 2012 21:01 |  #4
996gt2 wrote in post #15067193 (external link)
Not the center ratings at f2.8 and f4
The center rating is better for the Canon at f2.8 and f4. To me, that's surprising. The Nikon's numbers are very impressive.
Zlatko ­ Batistich
Joined Sep 2009
Oct 01, 2012 22:17 |  #5
I'm not sure it's clear that the Zeiss is sharper. The charts indicate that each lens is sharper is some measures. It just depends on which aperture you choose.
Also, the comparison with the Nikon may not be valid. As Photozone states: "Please note that the tests results are not comparable across the different systems!"
noisejammer
Oct 01, 2012 22:41 |  #6
I suspect the weak corners might be a field curvature issue - the Zeiss 28/2 suffers from this too.
My other observation is that the lens has quite a lot of focus shift as it is stopped down. (something like 20mm when going from f/2.8 to f/5.6.) This is quite a lot and there's no reason it could not be compensated for in the focusing algorithm.
Several cameras and more glass than I will admit to.
KenjiS
"Holy crap its long!"
Gallery: 622 photos
Oct 02, 2012 01:10 |  #7
nightcat wrote in post #15067488 (external link)
While we're talking centers, What about Canon's 28mm f/1.8? This is the most direct comparison after all... Given you can get the 28mm f/1.8 for almost HALF (its $450 right now at B&H) what the 28mm f/2.8 costs i think it warrants consideration, So lets look at the numbers:
At f/2.8 (Center/borders/extrem​es) 28mm f/1.8 on left, 28mm f/2.8 on right
3521/2561/1674 VS 3600/2843/2563
and at f/4
3702/2721/2749 vs 3729/2955/2844
The f/1.8 also has less distortion, 2.01% vs 2.41%
And less vignetting, .83 vs 2.12 at f/2.8...
Not to be really mean, But I frankly dont see why you'd spend more on the 28mm f/2.8, The f/1.8 does most of its tricks at least as well, Sometimes better and leaves you with a lot of money in your pocket..it also opens up to f/1.8 allowing for creative effects or because you need f/1.8... The only thing i think the f/2.8 might do better is flare, Because the f/1.8 is kinda bad when it comes to flare performance at times... But regardless..is that worth the extra cash?
The only justification i can see is for video....but even then...
Deviantart (external link)
nightcat
Oct 02, 2012 05:37 |  #8
I think Canon overpriced this by $200. Same for the new 24mm. If IS means a lot to you for a certain application, then it's an interesting option. In the 28mm range there are other good lenses available at a lesser price. If you include manual lenses, there's a lot of great 28mm options out there.
TweakMDS
Oct 02, 2012 05:47 |  #9
KenjiS wrote in post #15068317 (external link)
and at f/4
This makes me feel much better about my 28 1.8 (even though I already knew it was much better than it's reputation leads us to believe).
I think the main problem with lenses like the 28 1.8 is that people ONLY judge it on it's ability to shoot wide open, and while it's good at f/2 and great at f/2.8 and further stopped down, the mere fact that it's hazey and soft-ish wide open gets it a bad rep.
Another issue is that if you're in need of a 28mm that you mostly shoot at smaller apertures, most current zoom lenses already do this very well and there's not much need for an extra prime in the bag to do the same thing.
I use my 28 1.8 at f/1.8 - 2.8 and for the rest I use the 17-40 or 24-105. Maybe a luxury problem, but that's how it works for me. The L zooms aren't even that much more expensive.
Some of my lenses focus beyond infinity...!
~Michael
Gear | Flickr (external link)
"My featured shots" (external link)
KenjiS
Gallery: 622 photos
Oct 02, 2012 12:28 |  #10
^- thats how I use my 28mm f/1.8.. though I shoot it on a crop cam as opposed to full frame, When I go full frame I'm not thinking of getting rid of it because i like the idea of a fast wide prime like the 28mm for creative effects.. and the only other choice is the 24mm f/1.4L which is several magnitudes more expensive...
2ndviolinman
Joined May 2011
Oct 02, 2012 12:54 |  #11
You cannot compare the Imatest Canon and Nikon mtf numbers straight across as the D3X sensor has somewhat higher resolution than the Canon's, and Imatest give system resolution, not lens resolution. Other factors, such as default sharpening and contrast differences between the bodies make cross platform comparisons pretty meaningless.
David
5Dc, 5Dii, Canon 16-35 f/4L IS, 40/2.8 Pancake, 85/1.8, 100/2.8 Macro, 135/2.0L, 200/2.8L, converted 35mm TS, Sigma 50/2.8 Macro, 70/2.8 Macro, Zeiss ZE 21/2.8, Zeiss Contax 28/2.8, 50/1.7 & 85/2.8, Jena 135/3.5, Voigtlander 90mm f/3.5 APO, Canon 28-135.
Zlatko ­ Batistich
Joined Sep 2009
Oct 02, 2012 13:31 |  #12
The new 28/2.8 IS is a higher quality lens. At f/2.8, the corners are much better. I don't see what the 28/1.8 does "at least as well" except for going to a wider aperture. The 28/2.8 is great for stills, especially for photojournalism and events. It works very well when shot indoors at f/2.8, with some flash if needed. The 28/1.8 has a great look, but is notorious for fuzzy corners wide open and requires stopping down to about f/4 to avoid them. The relative lack of flare of the 28/2.8 is very valuable for stills. The IS function is great for stills too. I don't see how these benefits only have justification for video.
996gt2
Oct 04, 2012 20:56 |  #13
SLRgear has also just tested the new Canon 24mm and 28mm IS lenses.
I think that neither one is truly impressive given the price, but the 28mm is the better of the two. The 24mm f/2.8 IS does not perform well at f/2.8.
28mm IS:
24mm IS:
Keeping in mind that these are prime lenses, and expensive ones at that, I just can't feel very excited about their performance. When a newly introduced $800 prime lens comes onto the market, one would at least expect it to outperform zoom lenses that have been available for several years (a decade in the case of the 24-70L).
On the Nikon side, the 14-24mm @ 24mm blows away the 24mm IS:
On the Canon side, the 24-70mm Mk. I also does better than both of these lenses:
Buy/Sell Feedback
Zlatko ­ Batistich
Joined Sep 2009
Oct 04, 2012 21:51 |  #14
996gt2 wrote in post #15081255 (external link)
I have both lenses and find that they perform very well at f/2.8. Lensrentals.com found that both of them substantially outperform the original 24-70L zoom at center and on average. See the first chart on this page:
http://www.lensrentals​.com …imes-why-did-they-do-that (external link)
This is consistent with what I see.
The Nikon 14-24 is undoubtedly an outstanding lens, but it's huge (and much more expensive). I think that one point of these new lenses is their small size & weight. They are wonderful small lenses for photojournalism and video.
jorkata
Joined Sep 2009
Oct 04, 2012 23:57 |  #15
Zlatko Batistich wrote in post #15081509 (external link)
According to LensRentals, the 28mm/IS is sharper than the 24mm/IS.
Is this your experience as well?
I got the 24mm/IS but I'm still curious to know how it compares with the 28mm/IS in the 'real world'.
Thanks.
8,534 views & 0 likes for this thread, 11 members have posted to it.
1395 guests, 110 members online
