Thread started 02 Oct 2012 (Tuesday) 14:57
Is it possible to shoot faster than 1/200 with a 430exII?
Ace ­ and ­ Deuce
Joined Feb 2012
Oct 02, 2012 14:57 |  #1
"Is it possible to shoot faster than 1/200 while using a 430exII flash?"
I was just wondering if there was a way around this, and how. To be honest, I've had my camera about 9 months now, but there's still a lot of the 'technical' stuff that befuddles me.
Thanks,
~Ace
Sacadelic
Joined Apr 2011
Oct 02, 2012 15:01 |  #2
That would have to do with your cameras sync speed. On the T3i it is 1/200. On others it is a little faster, or a little slower. you can shoot in High Speed Sync(HSS), and that should allow you to shoot faster, but you are going to lose power when you do that. Watch this video. It should help.
http://www.youtube.com​/watch?v=is1JMu_khbs (external link)
-Sac
Feedback
Yogi ­ Bear
Oct 02, 2012 17:34 as a reply to  @ Sacadelic's post |  #3
P16 of the 430 EX II manual explains how to use High Speed Synch, which is what you need:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/10/1/LQ_617641.jpg
Image hosted by forum (617641) © Yogi Bear [SHARE LINK]
Canon EOS 7D | EF-S 17-55mm f/2.8 IS USM | EF-S 55-250mm f/4.0-5.6 IS |
EF 100-400mm f/4.5-5.6L IS USM | 250D | EF-S 10-22 mm f/3.5-4.5 USM | 580 EX II |
Nature ­ Nut
Joined May 2012
Oct 02, 2012 17:46 |  #4
HSS loses some flash power but not so much it becomes a problem. It will go through batteries a bit quicker though.
Adam - Upstate NY:
Ace ­ and ­ Deuce
Joined Feb 2012
Oct 02, 2012 18:26 |  #5
Wow, thanks! I looked through the manual when I got it, then put it in the box & stored it away. I guess that's where I should've checked first.
Thanks again!!!
windpig
Chopped liver
Oct 02, 2012 19:01 |  #6
You actually loose quite a bit of power going into HSS, 2.5 to 3 stops of power.
Go ahead, spin the wheel.
stsva
Gallery: 45 photos
Oct 02, 2012 20:19 |  #7
windpig wrote in post #15071909 (external link)
+1. And the more you increase the shutter speed, the more flash power you lose.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
Yogi ­ Bear
Oct 03, 2012 17:28 |  #8
Ace and Deuce wrote in post #15071784 (external link)
Thanks again!!!
Kinda hard to look it up in the manual when you don't know what it's called!
You're welcome. Let us know how it works for you.
Ace ­ and ­ Deuce
Joined Feb 2012
Oct 03, 2012 20:21 |  #9
Yogi Bear wrote in post #15076150 (external link)
I guess that's true, Yogi, but I still feel kinda silly, lol.
Thanks again, everyone!!
jerbear00
Joined Mar 2011
Oct 03, 2012 20:30 |  #10
Ace and Deuce wrote in post #15070945 (external link)
Thanks,
~Ace
Yes
5d3 & Lens CoLLector
Gear List/Feedback
Perfect_10
Joined Aug 2004
Oct 03, 2012 23:38 |  #11
Thanks again!!!
Or you could just go to the Canon site and download pdf's for all the kit you have .. it's easier to just 'scan' thru pdf's when you need an answer.
My Gear List  :p
dexy101
Gallery: 93 photos
Oct 04, 2012 02:40 |  #12
Perfect_10 wrote in post #15077429 (external link)
And for the purists among us, it saves opening up the manual and messing it up :)
And now you can have it on your smartphone.
Tiberius
Oct 04, 2012 03:20 |  #13
No you don't. You lose about a stop of power switching to HSS, but after that you are able to use a wider aperture with the faster shutter speed, so it balances out.
My photography website!PHOCAL PHOTOGRAPHY (external link)
JohnB57
Oct 04, 2012 03:24 |  #14
dexy101 wrote in post #15077890 (external link)
And for the purists among us, it saves opening up the manual and messing it up.
The real purists don't even get the camera out of the box...
jonneymendoza
Oct 04, 2012 04:48 |  #15
cant use hss when the flash is off camera though unless u use a pocketwizard
Canon 5dmkIII | Canon 85L 1.2 | Sigma 35mm ART 1.4|Canon 16-35mm L 2.8 |Canon 24-70mm L f2.8 | Canon 70-200mm F2.8L MK2 | Canon 430EX MK2 Flickr (external link)
3,642 views & 0 likes for this thread, 13 members have posted to it.
901 guests, 118 members online
