Thread started 03 Oct 2012 (Wednesday) 00:59
Used 35L, play in front of lens
Mark
Dammit I need sleep
Oct 03, 2012 00:59 |  #1
Hi all,
I just bought a used 35L off ebay for $900... it looked to be in alright condition (about the same as all my other gear just scrapes on the metal)
It arrived today, and I noticed that the whole front half of the lens has alot of play in it, like it will twist very easily about <5mm but substantial enough to notice either way, making a kinda clunk, and also can wobble around a bit...
The images seem pretty damn nice, although it could just be my love for the 35L in general speaking there.
Is this normal?
Mark
drive_75
Oct 03, 2012 01:22 |  #2
Mark wrote in post #15073164 (external link)
Hi all,
Is this normal?
Not exactly sure what you are talking about but it doesn't sound like normal. Mine is pretty solid.
Mark
Dammit I need sleep
Oct 03, 2012 03:14 |  #3
Basically, if you hold the lens mount part, or mount it to a lens for that matter, and hold the red ring part, then twist it or wobble it it twists the whole front half of the lens (including inside of the distance scale) a decent amount?
Is it worth sending back? My concern is that when I drop it, the whole front half will just fall off or something because something internal has been weakened enough for this to happen. Or it could be as simple as a screw somewhere is a tad loose...
Mark
Mark
Dammit I need sleep
Oct 03, 2012 03:16 |  #4
It's just like this
http://www.youtube.com​/watch?v=W_XIYVqC5N4 (external link)
Except it also twists.
Actually, no, i'm pretty sure it is very bad now, I can see into the lens between in the hole that forms near the focus ring.
Mark
cfvisuals
Joined Mar 2011
Oct 03, 2012 03:27 |  #5
Mark wrote in post #15073388 (external link)
It's just like this
That's a loosen part.
I guess you can probably send it into Canon and try to repair it. I think it shouldn't cost a lot, if parts aren't broken. What's expensive are the lenses inside. As long as they are fine, you just have to pay labor fee for putting your 35L back into solid form.
5∞ portfolio (external link)
Mark
Dammit I need sleep
Oct 03, 2012 03:46 |  #6
calvinjhfeng wrote in post #15073401 (external link)
Yeah, I get the feeling it's just a loose screw or broken plastic tab. I'll take it down to my local repair shop tomorrow, Canon are useless in WA.
I sent the seller a message indicating the problem but haven't gotten a response, not sure if he will.
Given all the electronics work well, there isn't crap through it, and IQ seems good in controlled situation (obviously wouldn't be if I'm holding it by the end in portrait where it bends) I think I'll just get it repaired and be happy. Don't really want to deal with resolution centre or any of that...
Edit: just disassembled it, found part YA2-3071 was broken (two of the plastic bits the mount screws into were cracked) which fortunately is shared with the 24LI and 100 Macro, so I can hopefully find it locally. If not, it's only $50 online, all is good. :)
Mark
Sir_Loin
Oct 03, 2012 07:19 |  #7
I'd personally send it back to the seller as its quite clearly broken! :(
EOS 1D4, 5D3, EF 24-70mm f/2.8L II, EF 70-200mm f/2.8L II IS, EF 50mm f/1.8 STM, EF 85mm f/1.2L II * EOS R6, RF 24-105mm f/4.0-7.1 * EOS M5, EF-M 11-22mm f/4.0-5.6 IS, EF-M 18-55mm f/3.5-5.6 IS, EF-M 55-200mm f/4.5-6.3 IS, EF-M 22mm f/2.0, EF-M 28mm f/3.5 Macro IS * FL-F 300mm f/5.6 FLUORITE, FD 55mm f/1.2 ASPHERICAL, FD 24-35mm f/3.5L, FD 50mm f/1.2L, FD 300mm f/2.8L, FD 50-300mm f/4.5L
pdrober2
Joined Nov 2010
Oct 03, 2012 21:07 |  #8
Sir_Loin wrote in post #15073788 (external link)
i wouldnt even mess with it. Send back, or file a claim. Ebay always sides with the buyer.
Fujifilm X-T1 | 23 | 27 | 56 | 90 | 55-200
Feedback
Mark
Dammit I need sleep
Oct 04, 2012 05:57 |  #9
Just got the part and replaced it today, was only $33 and it feels great now, still have to test it a bit more but all seems very well!
Mark
jra
Oct 04, 2012 08:00 |  #10
Congrats on a great lens....glad it was an easy fix :)
1,837 views & 0 likes for this thread, 6 members have posted to it.
916 guests, 109 members online
