Thread started 03 Oct 2012 (Wednesday) 18:40
switch from a 24-70 to a 24-105?
chuckmiller
Gallery: 65 photos
Joined May 2012
Oct 03, 2012 18:40 |  #1
Is the addition of IS (I can't hold a camera still for squat anymore) worth the reduction from 2.8 to 4?
I shoot outdoors far more than inside and I usually stop down a bit to increase sharpness. So, I'm thinking I won't miss the f/2.8. How much does the 24-105 f/4 have to be stopped down to increase sharpness?
Retired from Fire/Rescue with 30 years on the job - January 2019
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Oct 03, 2012 18:54 |  #2
I shoot the 24-105 anywhere from f/4 to f/16 and don't have any problems with sharpness at all. I wouldn't have any qualms about making the switch. But the IS and extended reach are much more important to my shooting than the f/2.8 would be....YMMV
jimewall
Oct 03, 2012 19:13 as a reply to  @ Snydremark's post |  #3
If you can't hold still anymore then the IS should help for non-moving subjects and it could be a good switch for you. The IS giving better than the 1 stop in aperture for non-moving subject. With the added benefit of a greater range in FL.
If you shoot mainly active subjects, then maybe learning to use flash effectively would be a better solution than a lens with IS.
Thanks for Reading & Good Luck - Jim
GEAR
Invertalon
Oct 03, 2012 19:15 |  #4
24-105 is an excellent lens! I just recently sold it for the 24-70 II after years. Always excellent results. Very versatile.
-Steve
Facebook (external link)
Fester
Joined Sep 2011
Oct 03, 2012 19:19 as a reply to  @ jimewall's post |  #5
The beauty of good lenses is resale. They hold their value better than cars or electronics. As long as we keep them in like new shape.
Ho wmuch do you want for your 24-70?
pdrober2
Joined Nov 2010
Oct 03, 2012 20:41 |  #6
mine is sharp wide open
Fujifilm X-T1 | 23 | 27 | 56 | 90 | 55-200
Feedback
JRET
Oct 03, 2012 22:04 |  #7
Snydremark wrote in post #15076462 (external link)
.... the IS and extended reach are much more important to my shooting than the f/2.8 would be....
my sentiments exactly
Canon M6ii (black) • Canon M6ii (silver) • EF-M 22 • EF-M 32 • EF-M 11-22 • EF-M 18-150 • EF 35 f/2IS • EF 40 f/2.8 • EF 85 f/1.8 • EF 100 f/2.8L macro • EF 16-35 f/4L IS • EF 70-200 f/4L IS
ZeroSkylineX
Joined Jun 2012
Oct 03, 2012 22:15 |  #8
Which can easily be worked around with by using higher shutter speeds, and for range- in most cases, your feet. You can not substitute aperture. I would stick with 24-70. But again, that's your shooting needs so it may be more suitable.
Canon Rebel 600D/T3i | 580EX II
Sigma EX 10-20mm f/3.5| EX 17-50mm f/2.8 OS| EX 50mm f/1.4| EX 70-200mm f/2.8 II
500px (external link)
Snydremark
Gallery: 66 photos
Oct 03, 2012 23:15 |  #9
ZeroSkylineX wrote in post #15077151 (external link)
There isn't always enough light for higher shutter speeds, and "foot zooming" can mess with perspective or be impossible due to any number of barriers, etc; especially outdoors in an uncontrolled environment. So, you can't really substitute a large aperture for those things, either. IS can let you shoot slower shutters at lower ISOs than just using a larger aperture can, too.
No, one, item out of that list is a full substitute for the other; but, that's why figuring out individual needs is important before buying a lens.
1,524 views & 0 likes for this thread, 8 members have posted to it.
2790 guests, 156 members online
