Thread started 05 Oct 2012 (Friday) 14:06
Default camera picture settings - question??
Je5ter
Joined Sep 2012
Oct 05, 2012 14:06 |  #1
I'm sorry if this has been asked before but I did a search and couldn't seem to come up with an answer to my question with pages and pages with the search word "picture" in it so I figured I'd ask :p
When selecting a default picture setting ie: landscape, portrait, neutral, faithful, monocrhome..... What is the ideal setting to choose if you plan on post processing them after and why? If I'm shooting a landscape should I have it on "landscape" or one of the neutral settings as I do like to edit my pictures a bit afterwards. Thanks!!
Check me out on Facebook!! https://www.facebook.c​om/TheMiddleofSomewher​e (external link)
WaltA
Gallery: 10 photos
Joined Feb 2006
Oct 05, 2012 14:28 |  #2
What software are you using for editing? I think only Digital Photo Professional uses the picture styles that were set in camera.
Walt
400D, 5D, 7D and a bag of stuff
Je5ter
Joined Sep 2012
Oct 05, 2012 14:36 |  #3
I use Lightroom 4 and shoot in RAW.
mike_d
Oct 05, 2012 14:38 |  #4
Je5ter wrote in post #15084175 (external link)
The picture styles don't affect the raw file. They do affect the jpg preview on the back of the camera though. I leave mine on neutral.
Je5ter
Joined Sep 2012
Oct 05, 2012 14:46 |  #5
OK so basically it doesn't do anything once you have inported the RAW files to the computer, the only thing it effects is the preview on the camera's screen??
mike_d
Oct 05, 2012 14:48 |  #6
Je5ter wrote in post #15084209 (external link)
Pretty much. If you were shooting jpgs out of the camera, then the picture style would definitely affect those. But the great thing about raw files is that you get all the data before any processing is done.
Also, since it affects the preview on the camera's LCD, it also affects the RGB histograms which can give you misleading information. For example, when I shot with my friend's camera, I kept getting a spike in the red channel. Then I figured out he had it set to portrait.
Mark1
Oct 05, 2012 14:55 |  #7
I shoot raw as well. I keep mine zeroed out (faithful or neutral) unless I know the result will be a final edit in B&W, then I will use the monochrome setting to make sure there is enough definition in all the colors.
Je5ter
Joined Sep 2012
Oct 05, 2012 14:55 |  #8
mike_d wrote in post #15084218 (external link)
Cool thanks man, appreciate it!
birdfromboat
Location: somewhere in Oregon trying to keep this laptop dry
Oct 06, 2012 14:21 |  #9
Mark1 wrote in post #15084256 (external link)
+1 faithful as a golden retriever and then just use the jpegs for quick culling and focus checks and bring home the raws
5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Looking through a glass un-yun
BigAl007
Gallery: 556 photos
Oct 06, 2012 15:59 |  #10
You must remember that the Canon Picture Styles do not carry forwards to the Adobe RAW converter be it ACR or LR. Adobe do though have equivilant settings that in LR4 ACR7 change the way the initial zeroed settings look for a conversion. Some of the choices for Canon include Adobe Std, Camera Std, Camera Faithful etc. The styles that have "camera" in the title vary settings by manufacturer and model.
Alan
RAW ­ RAW ­ RAW
Joined Mar 2011
Oct 06, 2012 16:32 |  #11
What does work is assigning a picture style on import to Lightroom. I shoot raw and at import I apply a modified landscape picture style. This is then a starting point for my pp. I still get all the raw info and I get a start on the pp. The majority of my pics suit this as a starting point for pp.
watt100
Oct 06, 2012 18:45 |  #12
BigAl007 wrote in post #15087941 (external link)
Alan
that's how I think it works, but you have to be aware of the initial settings in camera RAW
tzalman
Fatal attraction.
Oct 07, 2012 05:50 |  #13
Alan
The "Camera ...." profiles have the same names as the Canon Picture Styles, but there is a difference. The Picture Styles are not only profiles, they are also presets for contrast, saturation and sharpening - not extreme, but also not inconsiderable amounts of each. The LR/ACR settings are only profiles, they do not affect the settings in any of the other sections of the module, which are, by default, fairly mild.
By the way, Alan, you write "The styles that have "camera" in the title vary settings by manufacturer and model," but it is also the case that the Adobe Standard profile is customized and unique to each model.
Elie / אלי
BigAl007
Gallery: 556 photos
Oct 07, 2012 17:00 |  #14
Thanks Eile I did not know that Adobe Standard changed across different models. I have been using Adobe Standard as it seems to be the most consistent across both my 300D and 20D for initial "look". I do occasionally try the different styles and they do have differences which are sometimes useful if I'm not sure where to go with the look of a conversion.
Alan
tzalman
Fatal attraction.
Oct 07, 2012 19:31 |  #15
Eric Chan, who is like the main honcho for LR/ACR, recently did a video interview for The Luminous Landscape and one of the things he said surprised me. I had always figured that the profiles were prepared by testing several units of each camera and averaging the results, but he revealed that only one unit is used. That puts Adobe's profiles at the level of the canned profiles supplied by makers of monitors - at best. Your own camera could be pretty far along the bell curve from the Adobe profile. This makes profiling your camera, especially for non-standard light sources, using the Color Checker or QP Card methods, a more attractive proposition.
Elie / אלי
2,818 views & 0 likes for this thread, 9 members have posted to it.
1667 guests, 132 members online
