Ralph III wrote in post #15085938
Hey If you scroll through the 70-300mm Di VC thread alone
But I have checked that thread, and I've done so more than once, since I was considering buying the tamron myself at one point. I did not notice any increase in IQ in the shots posted compared to the shots in the 55-250 thread. Same goes for the flickr groups for both lenses.
I really like Bryan's site (Digital Picture). However, you're incorrect in regards to the comparison between the lenses and obviously didn't look through the details.
What details? I merely posted a comparison tool, not a review.
You also have to take into account the fact that the tamron is being tested on a 1DSIII, which gives it an advantage over the 55-250 on a 50D.
None-the-less, the Tammy wins with the chart comparisons.
Really? I was under the impression one buys a telephoto lens more for the long end than for the short end. At least, for me the long end matters more (although ideally they would be equally good).
B) Canon 55-200mm @ 200mm and 5.6
Tamron 70-200mm @ 200mm and 5.0
Both lenses are close or equal at Center focus.
The Tamron is clearly superior at both Mid-Frame and Corners.
I'm going to take a leaf out of your book here; my copy of the 55-250 is not that bad at the edges. So where does that leave us?
C) At 70mm, 100mm, and 135mm; the Tamron 70-300 Di VC absolutely blows the Canon 55-250mm away in each of the three categories.
I wouldn't really call that "blowing away", it is definitely better, but how much of that is attributable to the cameras used?
I mean the Canon is a good lens as noted but it has been the input of those who have owned both that states the Tammy is superior in every way, including overall image quality.
Since I have said I know several who have owned both and who state the IQ is not much of an improvement (in fact there are some on this forum who say this too), how can you say that conclusively? At best it would be acceptable to say there is sufficient copy variation in both the 55-250 and 70-300 VC and that on average the 70-300 is a bit better, at the short end, and equal or worse at the longer end.
But all this is beside the point. I never said the tamron was worse than the canon. I just said that in view of the fact that many people on this forum will eventually upgrade, it makes more sense to me to go with the cheaper option so your overall expenditure is less when the upgrade happens.
You will also note that I said if an upgrade is not on the horizon, the tamron is the better choice.
So you don't need to feel the urge to defend your purchase, since I am not attacking it.
