Thread started 28 Dec 2005 (Wednesday) 05:40
EF-S lens focal length designation?
Doc ­ Nickel
Dec 28, 2005 05:40 |  #1
I was reading a reference briefly earlier today, which suggested that the 350D's "kit" lens (18-55mm) was the "equivalent" of a 29-88mm lens.
Now, I understand the "crop factor", but I was under the impression that the EF-S lenses, being specifically made for the 1.6-crop bodies, would be designated by the actual focal length. IE, instead assuming the lens will 'act' like a 29mm lens, it will actually be what it says, an 18mm lens.
In other words, if I use an EF-S lens, it provides it's actual stated focal length. And that I only need to consider the "crop factor" multiplication if I'm using a normal EF series lens on the crop bodies.
.... Um, right? :D
Doc.
Doc's Machine (external link). Doc's Smugmug (external link) Photo Gallery. Don't laugh, I'm not paid to do this.
Canon 1DMkIIn | Canon 350Dw/grip | 24-70L f2.8 | 18-55 kit | 50mm f1.4 | 75-300 f4-5.6 | 28-300L IS | Sigma 8mm fish | 430EX | Off-shoe cord II
Next up: 400/5.6 | 16-35 2.8 | 70-200 2.8 and maybe a 1.4 TC
Wishful thinking: 500/4.0
CRE@TE
Dec 28, 2005 06:03 |  #2
No, EF-S is only the mount design. The crop factor still exist.
I got stuff for taking pictures. :o When things are unclear - It's time to refocus. :rolleyes:
My Flickr
http://www.flickr.com/​photos/7605380@N08/ (external link)
SkipD
Joined Dec 2002
Dec 28, 2005 06:27 |  #3
.... Um, right? :D
Doc.
The "crop factor" thing is extremely misunderstood, probably by the majority of folks who buy APS-C cameras (like your 350D).
The focal length of a lens does not change based on what format the camera body that the lens is mounted to uses. Only the field of view changes when you move a lens (EF, for example) from a 35mm body to a 350D. The focal length is still the same.
The "crop factor" is referencing the field of view provided by a particular focal length lens mounted to a 35mm film camera (or a "full-frame" digital camera), and confuses the heck out of most folks who have just purchased a digital SLR as their first "real" camera and have never used a 35mm camera.
There is only one valid reason to consider the "crop factor". That is when someone takes a photo with a 100mm lens on a 35mm camera and you want to calculate what focal length to use to duplicate the shot (from the same position used by the 35mm shooter). Then you would divide the 100mm by 1.6 and choose a 62.5mm lens (if there were one available - or use a zoom) to duplicate the shot. Another example - 80mm lenses are the "standard" recommendation for portrait lenses for 35mm cameras. What focal length duplicates that for your 350D? Divide 80mm by 1.6 and you get 50mm.
What you need to understand about your 350D is that 28mm to 31mm is the approximate focal length of a "normal" lens. Any lens with a shorter focal length is considered wide-angle, and any lens with a longer focal length is considered a telephoto. To understand "how much" wide angle or telephoto, just use the 31mm figure as a reference. For example, a 100mm lens on your 350D is about a 3X telephoto and a 15mm lens on your 350D is about a 0.5X wide angle.
The "normal" focal length for a 35mm camera is 50mm, and you do calculations for how much wide-angle or telephoto based on the 50mm "normal" as a reference when using 35mm cameras (or "full-frame" digitals).
EF-S lenses provide the same ANGLE of view as lenses of the same focal lengths used on 35mm cameras. That is to say, that for a subject that would show up completely in both cameras, the angle defined by the subject's width with the camera as the reference point is the same. EF lenses provide a larger image circle than EF-S lenses. That is because they need to fill a 35mm frame with the image. EF-S lenses are designed to fill only an APS-C sensor with the image, but the ANGLE of view of a 20mm EF-S lens is identical to the angle of view of a 20mm EF lens. The total FIELD of view is different depending on which format body the EF lens is connected to (same would be true for the EF-S, but you can't connect them to a 35mm camera) because the 35mm camera can record more of the image from the lens. An EF-S lens, if you could mount it to a 35mm camera, would produce an image with a dark circle surrounding what image was on the 35mm film, but the size of the subject material that did show up (on the film) would be the same as the size of the image projected by the same lens on the sensor of your 350D.
Skip Douglas
kevin_c
Dec 28, 2005 07:18 as a reply to  @ SkipD's post |  #4
That's got to be one of the best explanations of this subject I've come across.
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
SuzyView
Dec 28, 2005 07:27 |  #5
Serious. Thanks.
SuzyView
Jon
Joined Jun 2004
Dec 28, 2005 10:46 as a reply to  @ SkipD's post |  #6
I had to read this several times to figure out what you're trying to say in this paragraph. The confusion arises from your use of "Angle of View", which classically refers to the total angular field of view of the lens. The Angle of View of any two lenses of the same focal length, whether EF or EF-S, on the same body will be the same. The angle you're referring to here is the angle subtended by an object, which will be constant for a given focal length regardless of the format.
Jon
Cocker Spaniels
SkipD
Joined Dec 2002
Dec 28, 2005 19:39 as a reply to  @ Jon's post |  #7
Yeah, Jon, I know that what I wrote about that is confusing, even to me..... I gave that a lot of thought after I got on the road this morning. What it should it should really refer to is the angle of the light for the image inside the camera rather than outside it. Is that what the words you used refer to? It was late and I didn't really re-read what I wrote until just before leaving for work this morning.
Thanks.
Skip Douglas
Jon
Joined Jun 2004
Dec 29, 2005 10:13 |  #8
The angle subtended by an object - in the attached drawing the red (sensor, AKA 1.6x crop) subtends angle B,the total Angle of View for the lens (in that format). The blue ("film" AKA 1.0 crop) subtends angle C,the total AoV for that lens/format. The tree subtends angle A, and always will for that lens, even as the sensor size changes.
Jon
Cocker Spaniels
Thornfield
Joined Dec 2004
Jan 09, 2006 07:03 |  #9
Even I learned something from this thread. Now where is the aspirin :)
Relationships are like photography, it has to click. :)
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Jan 09, 2006 09:09 |  #10
.... Um, right? :D
Doc.
The stated focal lengths on the EF-S lenses are the actual physical focal lengths.
When you see the phrase "equivalent focal length" read "equivalent angle of view".
So a 10mm on a 1.6 crop has the same angle of view as a 16mm on full frame 35mm.
Macrophotography by LordV
2,316 views & 0 likes for this thread, 8 members have posted to it.
2506 guests, 102 members online
