Thread started 05 Oct 2012 (Friday) 22:47
Moving from a Sigma 150-500 to Canon 300mm f4 + 1.4x TC combo - makes sense?
hayath
Oct 05, 2012 22:47 |  #1
Probably a ton of threads already, but would like to know first hand experiences if any of us have made the move.
Do you miss the extra 80mm reach? (though I haven't really compared the FoV between the two given that "focus breathing" does make the Bigmos less than 500mm)
Would love to hear back :)
Cheers,
Hayath
Blog (external link) |
Instagram (external link)
crn3371
Oct 05, 2012 22:51 |  #2
I'd be more concerned on whether I'd miss the zoom or not.
hayath
Oct 06, 2012 01:27 |  #3
Thanks, I'm guessing having the 55-250 on the 2nd body should be taking care of that.
I'm hoping the quality jump (if any) would warrant the prime v/s the zoom :)
Hayath
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Oct 06, 2012 10:56 |  #4
hayath wrote in post #15086060 (external link)
I have used both lenses. In my opinion, yes, the quality jump would most definitely make this worth the move.
The extra 80mm is really meaningless, as numerous tests have demonstrated that the Sigma 150-500 does not perform at it's best over 400mm.
If you already limit yourself to 400mm with the Sigma for IQ reasons, then you will actually be gaining 20mm, not losing 80mm.
jimewall
Oct 06, 2012 10:56 as a reply to  @ hayath's post |  #5
I do not have first hand knowledge, but if you don't use your Sigma beyond 400mm, yes (I would think it is potentially a good switch). I haven't used the 300L (f/4), but I'd wonder if with a 1.4X and cropping to reach 500mm that it is better than the Sigma at 500mm. If you don't need the versatility of the zoom, better stabilization, nor the 500mm reach, then I'd go for it. I like the versatility and the 500mm reach. Though I'm still debating picking up a 300L (f/4).
Thanks for Reading & Good Luck - Jim
GEAR
1Tanker
Oct 06, 2012 11:40 as a reply to  @ jimewall's post |  #6
Depends on your usage. If you're going to be at the long end of the zoom, then the 300/1.4x would be better. I made this exact switch. The 150-500 is basically an f/8 lens... for best results, whereas you can have 420/5.6 with the prime. IS is much better on the Sigma, but acceptable on the 300 combo. I can take static shots at 420mm down to ~1/125(on crop)...which is just a little better than 2 stops.
The 300 combo, is far and away.. a better handling setup. The Sigma is big/long/heavy, and i was very unimpressed with the zoom creep.
If you have a 1D series body, you can use a 2x on the prime.. for 600/8(though not the best IQ) and still retain AF..albeit slower, but you're at the limit with the Sigma @500. A 1.4x on the Sig, would put you to 700@f/9 and MF. While i found the Sigma ok at 700(i've tried 1000/13 and 1400/18 as well..more for fun :lol: ), you start to need a lot of light, and MFing that lens isn't as easy as the 300.. for sure.
Kel
Gear
hayath
Oct 07, 2012 13:36 |  #7
Tom Reichner wrote in post #15087075 (external link)
jimewall wrote in post #15087076 (external link)
1Tanker wrote in post #15087232 (external link)
Thanks Tom! I use the Bigmos @ 500mm, f8-f9 and have got decent images (sometimes with support)
Thank you jimewall - that is the precise crossroad I'm at now :D
Thank you Kel! You've got to know the bigmos well and I second each of the points you've noted.
I will be using the long end of the reach almost *all* the time, especially with birds (which is what I primarily shoot with this lens)
What I haven't been able to do is get myself to try the 300 f4+1.4X TC combo and compare how much of a FoV difference does it make :(
Hayath
Brain ­ Mechanic
Oct 07, 2012 13:56 |  #8
I love these threads.....Bigmos at f/8 to f/11 at full 500mm gives very good sharp images:
IMAGE: http://i11.photobucket.com/albums/a198/chaman3872/Fotografia/IMG_6926.jpg
IMAGE: http://i11.photobucket.com/albums/a198/chaman3872/Fotografia/IMG_6931.jpg
IMAGE: http://i11.photobucket.com/albums/a198/chaman3872/Fotografia/IMG_6864.jpg
IMAGE: http://i11.photobucket.com/albums/a198/chaman3872/Fotografia/IMG_5831.jpg
All with a T2i. I cant wait to try my 7D once it gets here.
Gear: a toothed wheel :p
--Oscar--
hayath
Oct 07, 2012 22:55 |  #9
Thank you BM! Those are fantastic results from the lens.
I personally have used the Bigmos and cannot find much fault, but the f8 and it's need for a lot of light is something that's bothering me now (plus the fading sharpness away from the center)
All these shot with the Bigmos :)
http://picasaweb.googl​e.com ….m/Aerobats2?no​redirect=1 (external link)
Hayath
DreDaze
Gallery: 49 photos
Oct 08, 2012 01:43 |  #10
your shots have always been impressive with the bigmos...i'm sure you'll do fine with the 300mm and a 1.4TC...if you don't need the zoom option it seems like a good idea...
Andre or Dre
gear list
hayath
Oct 08, 2012 23:45 |  #11
Thank you Andre! The quality does begin to fall off as the subject to cam distance increases - hoping this combination performs better
Hayath
dfbovey
Joined Mar 2011
Oct 11, 2012 22:35 |  #12
I currently have both the 150-500 and the 400 f/5.6L. Even with a 1.4 extender attached to the 400L, it's MUCH sharper and picks up much more detail than the Sigma. I use the combo on the 1D4 though, I'm not sure which body you're wanting to use the 300L with extender on. If you have a 1D body I would recommend the 400 over the 300 for faster focusing, much better combo for birds in flight.
Canon 1D markIV - Canon 1D markIII - Canon 6D
Canon EF 16-35mm f/2.8L - Canon EF 24-70mm f/2.8L - Canon EF 70-200mm f/2.8L - Canon EF 100mm f/2.8L Macro IS - Canon EF 400mm f/5.6L - Canon EF 500mm f/4L
hayath
Oct 12, 2012 01:39 |  #13
^ Thank you :)
I have a Canon 40D and a TC on the 400 - that combo would lose AF :(
Hayath
samsen
Oct 12, 2012 02:18 |  #14
You are going to have IQ but miss the zoom.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
KenjiS
"Holy crap its long!"
Gallery: 622 photos
Oct 12, 2012 05:59 |  #15
Do it... For birds I find myself on the end of the zoom anyways 90% of the time..
As for the 150-500, There are good copies and there are bad, I owned bad ones, nowhere near as good as the 100-400, Much less the 300 or 400 primes
Deviantart (external link)
4,532 views & 0 likes for this thread, 12 members have posted to it.
2765 guests, 179 members online
