Thread started 06 Oct 2012 (Saturday) 11:29
Shopping Day Today: Which of these 3 options?
The ­ Dark ­ Knight
Joined Apr 2012
Oct 06, 2012 11:29 |  #1
Have a roughly $1000 budget, going to spend it today and then probably won't add camera equipment for a while. My current equipment is a 60D, 50mm 1.8, 18-55 IS, 70-300 IS.
I mostly shoot people with the occasional landscape/wildlife/spo​rts thrown in (but vastly infrequent to shooting people). Also planning/ hoping on going FF in about a year.
I definitely appreciate all opinions and help, but I am ONLY considering 1 of the following 3. So no mix/match, substitute other lenses, used, etc. Thanks!
1. 17-55mm
2. 15-85, 430 ex ii
3. 430 ex ii, 35mm f/2, 85mm 1.8
I am leaning towards (3), but I'd appreciate thoughts! Thanks!
FEChariot
Gallery: 13 photos
Joined Sep 2011
Oct 06, 2012 11:51 |  #2
If you don't have a speedlite, it should be tops on the list IMO. Given that, a standard zoom is most people's most used lens so I would rather have a good one there than some prime covering the standard zoom range and having to rely on the 18-55 for the rest. So of your options I like #2 best, but I would personally change the 15-85 for the Sigma 17-50/2.8, but you didn't want to hear about other options.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
runninmann
what the heck do I know?
Gallery: 47 photos
Joined Feb 2006
Oct 06, 2012 11:54 |  #3
I believe if I had the gear you already own and my only purchasing choices were the three you listed, I'd go with #3.
Seapup
Joined Aug 2012
Oct 06, 2012 12:01 |  #4
runninmann wrote in post #15087266 (external link)
+1.
Canon 5D2 | 60D | A620 | SD850 IS | SD4000 IS
Canon 10-22 f/3.5-4.5 | 17-55 f/2.8 IS | 50 f/1.4 | 100 f/2.8L Macro IS | 70-200 f/2.8L IS II | 100-400 f/4.5-5.6L IS
sk8n
Gallery: 6 photos
Joined May 2012
Oct 06, 2012 12:03 as a reply to  @ runninmann's post |  #5
Based on your existing gear, preference for portrait shots and the three options listed, I would go with option 3. If you went with option 1 you could sell the 18-55 and add something else.
Canon EOS 7D EOS 5D Mark III | Canon EF 100-400mm f/4.5-5.6L IS USM EF 70-200mm f/4L IS USM EF-S 10-22mm f/3.5-4.5 USM EF 24-105mm f/4L IS USM EF-S 17-55mm f/2.8 IS USM EF 100mm f/2.8L Macro IS USM EF 85mm f/1.8 USM EF 16-35mm f/4L IS USM EF 135mm f/2L USM EF 24-70mm f/2.8L II USM | Canon Speedlite 600EX-RT Speedlite 430 EX
jimewall
Oct 06, 2012 12:40 as a reply to  @ sk8n's post |  #6
For most shooters, my suggestion is the camera and lens followed by a flash. Then more lenses. So I'm with the any option that has a flash. I would rather have the two lenses in option 3 than the others given your current set-up. So I'm with the others in option 3.
Thanks for Reading & Good Luck - Jim
GEAR
Lohmo
Joined Dec 2011
Oct 06, 2012 15:14 |  #7
The Dark Knight wrote in post #15087197 (external link)
I say 3.
Canon 5Dc || Canon 7D || 8-15mm 4L Fisheye || 50mm 1.8
artyH
Oct 06, 2012 15:17 |  #8
I went with option 3 myself, for my 60D. I am not so fond of flash, but I do make use of it when I need to.
I like to use the 35f2 and 85f1.8 for people photos and events. Another possibility for people photos is the 24-105L. It is great outside for events and portraits.
For natural light photos indoors at night, the 35f2 will work great. The longer 85f1.8 is a fine lens.
I recommend trying one addition to your kit at a time. This may give you time to learn the lens or flash, and provide more buying pleasure over a longer time frame.
flowrider
Gallery: 127 photos
Oct 06, 2012 15:34 |  #9
#3 although I found the 85 kind of long on the 60D. On a full frame though, WOW, phenomenal.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
rick_reno
Oct 06, 2012 18:37 |  #10
I like #3
frugivore
Gallery: 11 photos
Oct 06, 2012 18:50 |  #11
#3 from those options.Flash > all other gear in most circumstances.
birder_herper
Oct 06, 2012 19:11 |  #12
#3 no doubt.
Rush87
Oct 06, 2012 19:36 |  #13
If you're going full frame in a year, #3 without a doubt.
I'd personally substitute the 35mm f/2 for a 28mm f/1.8 (I own both).
2,388 views & 0 likes for this thread, 13 members have posted to it.
2821 guests, 182 members online
