I wonder if a softbox mounted on my camera would help me with regards to outdoor night shots.
Who makes an affordable and effective model?
DanKearley Senior Member 426 posts Likes: 32 Joined Aug 2012 More info | Oct 06, 2012 19:20 | #1 I wonder if a softbox mounted on my camera would help me with regards to outdoor night shots.
DDL Senior Member 453 posts Likes: 25 Joined Jan 2009 Location: Alberta, Canada More info | Oct 07, 2012 09:02 | #2 What is wrong or needs improvement in the shots? DDL
dmward Cream of the Crop More info | Oct 07, 2012 10:23 | #3 Remember that, unless you are really close, the relative small size of either a bare speedlite or small soft box will deliver essentially the same light to the subject. Its much more useful, as noted above, to get the light farther from the lens axis. David | Sharing my Insights, Knowledge & Experience
rudy_216 Senior Member 299 posts Joined Oct 2008 More info | Oct 08, 2012 07:27 | #4 Have a look at this blog entry
Oct 08, 2012 10:02 | #5 I should experiment with backing the flash away from the subject.... That might be better than these little softboxes.
BrickR Cream of the Crop 5,935 posts Likes: 115 Joined Mar 2011 Location: Dallas TX More info | Oct 09, 2012 12:16 | #6 There is also a strobist type kit that has a mini beauty dish that can be effective had held as well as on camera. My junk
DaveJr Goldmember 1,873 posts Likes: 1 Joined Oct 2006 Location: MN More info | Oct 09, 2012 14:12 | #7 |
DDL Senior Member 453 posts Likes: 25 Joined Jan 2009 Location: Alberta, Canada More info | Oct 09, 2012 20:35 | #8 The strobella looks like it could send some reflected light into the lens possibly off the frame if it isn't retracted far enough. DDL
| Latest registered member is semonsters 1352 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
