Thread started 07 Oct 2012 (Sunday) 08:52
Recommend me a hiking setup
Morlow
Oct 07, 2012 08:52 |  #1
I'm wondering if anyone has a nice way of carrying your DSLR for longish hikes (8+ miles in a day). I do a lot of hiking here in Yellowstone but even with the OP-Tech strap my neck gets pretty raw after many miles. I'm not very creative so I haven't been able to figure out a better way to haul my camera than just slinging it over my neck and one shoulder. The camera rides comfortably on my midsection but my neck ends up being a little raw. Any ideas are welcome!
Chris Knapp
alpinevisions
Joined Nov 2005
Oct 07, 2012 09:07 |  #2
When I go into the mountains, I usually take at least a day pack. Depending on the lens I have mounted, I will take the smallest case my camera fits into and put it on either the hip belt or chest belt of the pack. If it's not easy to get to I won't take pics but just make sure it's is taped or pinned to the strap or you risk losing it when you take the pack off!
T2I 18-55mm Kit lens, Canon EF-S 17-55mm f/2.8
Larry ­ Weinman
Oct 07, 2012 09:10 |  #3
There are straps by various makers that go over your shoulder and the camera rides down by your hip. You simply slide the camera up the strap when you need it. Frankly I don't think that having a camera flopping around on your hip is much of a solution. One maker of this type of strap is Bostrap. There is also the Cotton Carrier where you wear a vest like apparatus on your chest and the camera connects to it leaving your hands free and getting the weight off of your neck. I never tried either one but the cotton carrier seems like a better solution. There are other manufacturers of both types mentioned above.
7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
Sirrith
Gallery: 50 photos
Joined Nov 2010
Oct 07, 2012 09:19 |  #4
I put mine in my backpack and take it out on location. If you want to have it out the whole time... Look into the Luma Cinch. Very comfortable and won't rub you sore.
-Tom
dodgyexposure
Gallery: 14 photos
Joined Jul 2012
Oct 07, 2012 18:14 |  #5
Lowepro do some smaller bags that fit onto their chest harness - keeps the camera handy and in front.
If you will already have a pack on, then a number of manufacturers (e.g. Op-tech reporter, or op-loops; tamrac; kata) sell straps that allow you to carry the camera on your chest, either directly attaching your camera to the shoulder straps of the pack, or attaching a holster type bag. e.g.:
http://www.tamrac.com/​g_camerastraps.htm (external link) (see N11)
http://optechusa.com/r​eporter-backpack.html (external link)
Cheers, Damien
Russ61
Oct 07, 2012 19:01 |  #6
I struggled with options for a long time until I settled on using relatively inexpensive Op/Tech Reporter/Backpack straps in conjunction with the Uni-loop connectors. Video demo shown here (external link). I retain my neck strap BUT I also feed a Uni-loop onto each side of the camera. This allows me to hang the weight of the camera on my backpack's shoulder straps via the Reporter/Backpack straps. The quick disconnect allows me to readily separate the camera from backpack should I wish to drop the pack and/or go into shooting mode. Clipped in like this, the onerous weight is OFF my neck and displaced onto the pack's straps and therefore my shoulders and hips where it can be comfortably carried all day. I retain the neckstrap around my neck so that its there as soon as I disconnect the Uni-loops connectors. I assume that any 8 mile hike in Yellowstone is in the backcountry and that you'll wisely have a pack with food/water/extra clothing/first aid kit etc.
Lowepro or ThinkTank chest holsters are other options as is the Cotton Carrier.
Morlow
Oct 07, 2012 19:01 |  #7
dodgyexposure wrote in post #15091834 (external link)
After taking a look at those different straps I actually figured out a way to clip my OP-Tech strap to my pack's shoulder strap. It's secure and the camera doesn't bounce around too much either.
Chris Knapp
spyderpig
Joined Mar 2011
Oct 07, 2012 20:48 |  #8
Morlow wrote in post #15091968 (external link)
I was just going to say that. Carabiner to a backpack strap. Maybe one on each side of the camera to keep it from flopping around too much.
I have a big carabiner on one side and a smaller carabiner on the other side and clip it anywhere that's convenient, like my belt loops, backpack, shoulder strap, etc.
T2i | Canon 15-85mm | kit 55-250mm | Sigma 80-400mm
Harsh and honest C & C is ALWAYS encouraged for any of my photos.
ninhja
Oct 07, 2012 21:09 |  #9
I've been using a Lowepro PhotoSport 200 to get my camera in and out relatively quickly. The side access really helps when shooting on the go.
gremlin75
Oct 08, 2012 04:21 |  #10
Morlow wrote in post #15090160 (external link)
Yep, Capture Clip from Peak Designs.
http://peakdesignltd.c​om/capture/ (external link)
Its a camera carrier made for backpackers by a backpacker.
vaflower
Joined Sep 2012
Oct 08, 2012 09:19 |  #11
gremlin75 wrote in post #15093333 (external link)
Look cool.
Fuji XE-1, Zeiss ikon, Hasselblad; I love shooting film as a conceptual idea :)
iazybandit
Joined Apr 2011
Oct 08, 2012 09:56 |  #12
You may want to also look into the B-Grip EVO holster with the travel kit. Its the same concept as the Peak Design Capture Clip..made for backpackers. I had the Capture and although it was sturdy, it didn't feel comfortable with with long/heavy lenses and a gripped body. The B-Grip has an extended base on the holster to give support.
Canon :: R5 | R6 | RP
Glass :: RF 15-35 f2.8L IS | RF 24-70 f/2.8L IS | RF 70-200 f/2.8L IS | RF 35mm f/1.8
FEEDBACK
FS: 3D Printed RF 35mm Lens Hood | PakPod Tripod
Morlow
Oct 08, 2012 10:06 |  #13
This looks like a really nice option. You can even retain your tripod plate. I was thinking this replaced it but you can order it with an RC2-compatible plate.
Chris Knapp
frs
Oct 08, 2012 20:45 |  #14
This is also similar to Spider holsters
http://www.spiderholst​er.com/ (external link)
I think the attachment point of the Spiderholster is compatible with the Carryspeed slings so you can switch easily...
iazybandit
Joined Apr 2011
Oct 08, 2012 21:18 |  #15
frs wrote in post #15096635 (external link)
Correct, the ballhead locknuts are similar and will work with the Carry Speed. Unfortunately, I wouldn't use the Spider Holster for hiking.
FEEDBACK
5,808 views & 0 likes for this thread, 17 members have posted to it.
1601 guests, 141 members online
