Thread started 08 Oct 2012 (Monday) 22:50
Canon 50mm 1.4 lens too soft under f/2?
Excelisus
Oct 08, 2012 22:50 |  #1
I’m trying to understand the merits of a Canon 50mm f/1.4 lens. I got that lens because of the low f-stop; however, when I took pictures yesterday using f stops below 2 (Canon T2i, shutter 1/80-1/150, cloudy, but during the day, 20ft and 2 ft from objects), the objects come out to be extremely soft, almost full of noise and unusable. Am I doing something wrong or can this lens not produce sharp photos below f/2.8? I tried the very same photos with f-stops above 3 and they came out much sharper, but still no sharper than my kit lens of 18-55mm. Any clarification would be appreciated.
mike_d
Oct 08, 2012 22:54 |  #2
I do find my 50/1.4 to be a bit soft under f/2 but noise is a factor of the ISO and exposure, not the lens. Mine's pretty sharp at f/2 and very sharp when stopped down even more. Are you sure you're seeing actual softness and not just slightly missed focus? Its easy to miss focus at f/1.4 and 2' to the subject since the DOF is so thin.
Excelisus
Oct 08, 2012 23:00 |  #3
I might have missed focus at 2' since the DOF is 0.02ft (external link), but the tree I photographed was about 20 ft or more away and I did spot focusing on the trunk. I'll see if I can post the pictures here later.
kin2son
Joined May 2011
Oct 08, 2012 23:28 |  #4
yes post some samples with exif intact...
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
dscri001
Joined Dec 2011
Oct 08, 2012 23:36 |  #5
Yeah mine is sharp wide open but does better at larger distances. Images closer than ~4 feet or so are just a tiny bit softer but I have to be little more careful with focusing.
-Tyler I II
EOS 6DII, EF 16-35mm f/4 ISL, EF 35 f/1.4L II, EF 85 f/1.8, EF 70-200mm f/2.8L
Excelisus
Oct 08, 2012 23:43 |  #6
What's the best way to post photos here?
mike_d
Oct 08, 2012 23:45 |  #7
Excelisus wrote in post #15097298 (external link)
You can attach pictures to a post or upload them somewhere (I use Photobucket) and post a link.
ieatstars
Gallery: 23 photos
Oct 08, 2012 23:48 |  #8
That's the lens I shoot with the most, and it's always been sharp for me wide open. Curious to see your examples.
PS I know you said it was cloudy, but why were you shooting at 1/80 and f/1.4?
Be my fan on F a c e b o o k! (external link) :D
Excelisus
Oct 08, 2012 23:54 |  #9
The problem is that this site has a 150kb limit. I have to edit the photos to post them later. I was using f/2 and 1/400 actually. ISO 100, full resolution. I see the extreme softness when I zoom 100%.
kin2son
Joined May 2011
Oct 08, 2012 23:56 |  #10
most people use flickr. Then copy and paste the BB code.
1Tanker
Oct 08, 2012 23:59 as a reply to  @ ieatstars's post |  #11
I find halation and CA's can be problematic any wider than f/2.. outdoors. Indoors or when not in strong sun, i can get away with 1.8 and 1.6. F/1.4 (for me)is only reserved for specific situations(when i must have shallowest DOF).. and focus is ultra-important when wide open.
Maybe you can try MF with LV, and eliminate the possibility of front/back focus, or missed focus on your part? Let's see some examples first though. ;)
Edit: Yes, use Flickr or Photobucket, for hosting.
Kel
Gear
Excelisus
Oct 09, 2012 00:17 |  #12
See the attached. These are only at 50% zoom.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/10/2/LQ_618611.jpg
Image hosted by forum (618611) © Excelisus [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/10/2/LQ_618612.jpg
Image hosted by forum (618612) © Excelisus [SHARE LINK]
ieatstars
Gallery: 23 photos
Oct 09, 2012 00:20 |  #13
Whoa.. those are really bad. How long have you had the lens / has it always been like this? Might be worthwhile to get it recalibrated.
Excelisus
Oct 09, 2012 00:22 |  #14
Just bought it online a week ago. A friend of mine was trying to explain that it was me who did something wrong maybe with the shots. I thought these are unacceptable too. And what do you mean by recalibration?
Excelisus
Oct 09, 2012 00:25 |  #15
These same shots done with f/3 look fine, comparable to my kit lens, but at 2 or below, they're like that.
12,746 views & 0 likes for this thread, 27 members have posted to it.
1078 guests, 175 members online
