Thread started 09 Oct 2012 (Tuesday) 00:22
Merging timelapse images
TitusvilleSurfer
Oct 09, 2012 00:22 |  #1
I took two 25 second timelapse images of a rocket last night and am having trouble merging them together. If I had an external shutter release handy I would have used it, but I didn't trust holding the shutter in bulb mode with my hand. Any ideas? I have RAW versions but they are huge, so hopefully I can edit them myself using dinosaur Photoshop 7.0. Thank you.
IMAGE: http://i145.photobucket.com/albums/r236/TitusvileSurfer/IMG_9169.jpg
IMAGE: http://i145.photobucket.com/albums/r236/TitusvileSurfer/IMG_9170.jpg
50D | G11 | 50mm f/1.4 | 70-200 f/2.8 IS | 580exII
René ­ Damkot
Oct 09, 2012 08:01 |  #2
Load into PS as layers, set the top layer to blend mode difference and line them up manually.
Then set blend mode to normal again and mask as needed (I'd probably go for the lower part of the left and the top of the right image, using the shore as the boundary.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
TitusvilleSurfer
Oct 10, 2012 14:37 as a reply to  @ René Damkot's post |  #3
I have no trouble lining them up at all, it's the actual blending. I'll try to do it tonight and post the result so you can see my trouble.
doidinho
Oct 10, 2012 15:03 |  #4
Just set the top layer (the one with the rocket and exhaust trail in it) to the lighten blend mode and that should be a good start for you. The end result will essentially be the second picture you posted; however, the blast for the first picture will also be there. It looks like you missed a second or two, so you may have to clone in a bit between the blast and the exhaust trail on your final image.
If that doesn't make sense you send me links to the full size pics in a PM I can do it for you this evening if you like.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
kirkt
Oct 10, 2012 21:03 |  #5
See if they can launch the rocket for you again, so that you can make sure you have your shutter release with you.
That must have been a pretty awesome sight to see in the dark.
kirk
Kirk
doidinho
Oct 11, 2012 01:25 as a reply to  @ kirkt's post |  #6
Here is what I came up with using the lo-res files.
IMAGE: http://farm9.staticflickr.com/8188/8076217920_53bcdc83f4_o.jpg
IMAGE LINK: http://www.flickr.com …/27883438@N07/8​076217920/  (external link)
rocket_retouch (external link) by Doidinho (external link), on Flickr
Robert McCadden
MM (external link)
1,793 views & 0 likes for this thread, 4 members have posted to it.
703 guests, 128 members online
