Justiss Goldmember 1,083 posts Likes: 2 Joined May 2009 Location: Guilford, CT More info | Oct 09, 2012 06:21 | #1 |
tmoore323 Goldmember 1,945 posts Likes: 4 Joined Oct 2010 More info | Oct 09, 2012 06:25 | #2 Try burning it some...
erikfig Goldmember 2,151 posts Likes: 203 Joined May 2012 Location: Orlando, FL More info | Oct 09, 2012 06:27 | #3 tmoore323 wrote in post #15097945 Try burning it some... ^^This... or use a brush with lower brightness and paint it over. You needed some fill flash on that one also. Who cares about my gear?
Oct 09, 2012 06:28 | #4 Do you have Lightroom? You could try moving recovery/highlights slider to the left and see if that helps some. 5D III / Canon 50mm 1.4 / Canon 50mm 1.8 / 17-40L / 135L / 85L 1.2 II / 70-200L 2.8 IS
Oct 09, 2012 06:33 | #5 |
Oct 09, 2012 06:42 | #6 I would be inclined to do a tighter crop and get rid of it that way. Ian
johndoorley Senior Member 364 posts Likes: 3 Joined Jan 2011 More info | Oct 09, 2012 06:54 | #7 perhaps a little cloning. just a rough shot - about 3 minutes. Image hosted by forum (618638) © johndoorley [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Spike44 Goldmember 2,155 posts Likes: 3 Joined Dec 2007 More info | Oct 09, 2012 08:31 | #8 You don't have exposure problem as much as a yellow cast problem.
Oct 09, 2012 08:53 | #9 |
PixelMagic Cream of the Crop 5,546 posts Likes: 6 Joined Nov 2007 Location: Racine, WI More info | Oct 09, 2012 14:41 | #10 You have bigger problems than the grass; the photo needs serious color correction.
Oct 09, 2012 14:49 | #11 |
Sevillian Member 173 posts Joined Jan 2009 More info | Oct 09, 2012 15:08 | #12 PixelMagic wrote in post #15099704 You have bigger problems than the grass; the photo needs serious color correction.
Oct 09, 2012 15:14 | #13 |
Sevillian Member 173 posts Joined Jan 2009 More info | Oct 09, 2012 15:15 | #14 There seems to be a blue tint (you can see it on the guys face) - A warmer color edit would benefit this capture.
Oct 09, 2012 15:17 | #15 |
| Latest registered member is semonsters 878 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
