Thread started 09 Oct 2012 (Tuesday) 10:00
I need help and critique
deviangel
Joined Aug 2012
Oct 09, 2012 10:00 |  #1
IMG_3443 (external link) by DeviAngelMKD (external link), on Flickr
IMG_3442 (external link) by DeviAngelMKD (external link), on Flickr
IMG_3437 (external link) by DeviAngelMKD (external link), on Flickr
Canon 6D | Canon 85mm f/1.8 USM | Canon 50mm f/1.4 USM |
https://500px.com/devi​angel
erikfig
Joined May 2012
Oct 09, 2012 10:07 |  #2
Since your photos don't have any exif, I cannot give you any feedback. Now, they are clearly UNDEREXPOSED... I can barely see anything on them. I would highly recommend to practice before you start watermarking your photos for the sake of your reputation.
What camera are you using? Settings? Lens?... etc etc
We need more info so we can further assist you :D
Who cares about my gear?
FlickR (external link)
Facebook (external link)
LV ­ Moose
Moose gets blamed for everything.
Gallery: 223 photos
Oct 09, 2012 10:09 as a reply to  @ erikfig's post |  #3
Wayyyy too dark. If they look good on your monitor, it's set too bright.
Moose
Gear... Flickr (external link)...Flickr 2 (external link)...
Macro (external link)...Hummingbirds (external link)
Aircraft (external link)
winters19
Oct 09, 2012 10:10 |  #4
Underexposed. Lacking ambient lighting. Get a flash and bounce that sucker off the ceiling! A cheap YN465 works wonders!!!
Canon 7D -Sigma 30mm F1.4 EX DC- -Canon 28mm F2.8- -Canon 50mm F1.8-
alazgr8
Joined Apr 2012
Oct 09, 2012 12:34 |  #5
Enable image editing on your profile. -rick
Rick S.
My Gear = Canon 50d ~ EF 100 f/2.8L IS USM Macro ~ EF 100-400 f/4.5-5.6L IS USM ~ EF-S 17-55 IS USM f/2.8 IS ~ EF 70-300 f/4-5.6 IS USM ~ EF 28-135 IS f/3.5-5.6 IS USM
deviangel
Joined Aug 2012
Oct 09, 2012 13:16 |  #6
Canon 60D ... the thing is that my lap top has HD screen I don't notice the difference and its not set to dark :/
Canon 60D 18-55 ...
I suck at image editing I wish I could knew how
Ramon-uk
Gallery: 61 photos
Oct 09, 2012 13:25 |  #7
deviangel wrote in post #15099354 (external link)
What are you saying .... do these look alright on your laptop, if so then how do other peoples pictures look on the same laptop.
How do they look on the rear LCD screen of the camera before you download them to the PC.
We need more detailed information before we can understand your problem.
lehmanncpa
Joined Aug 2012
Oct 09, 2012 13:30 |  #8
Canon 60D 18-55 ...
These images have nothing to do with HD screens on laptops or image editing. The images are underexposed due to improper lighting at the time the shutter release button was pressed. This may be due to either equipment or user error. An example of equipment error would be a faulty flash unit. An example of user error would be improper settings on your camera or with your lighting equipment.
The LCD screen on the back of your 60D should have told you these images were underexposed when you took them.
Now, suppose you needed to fix these, it may be possible to extract some detail from these images, but that process may add noise and make the image appear more grainy, especially in the shadows (which is the majority of the image). If you took them in RAW format, you may be able to recover more detail with less noise than if they were originally saved as JPG format.
Alex
Feedback
Photography (external link)
deviangel
Joined Aug 2012
Oct 09, 2012 13:41 |  #9
lehmanncpa wrote in post #15099420 (external link)
How wouls the screen show me if they are underexposed
deviangel
Joined Aug 2012
Oct 09, 2012 13:41 |  #10
Ramon-uk wrote in post #15099403 (external link)
The problem is simple I suck in taking pictures :)
lehmanncpa
Joined Aug 2012
Oct 09, 2012 14:04 |  #11
deviangel wrote in post #15099452 (external link)
The most obvious is that the image would be dark. Another way is to use the histogram - that's the image that looks like a graph. Read the owner's manual to learn to use these tools. However, even before you took the image, the meter on your camera should have told you that the image was too dark. Do you know what mode you were shooting in? P, Av, Tv, M, etc?
deviangel wrote in post #15099457 (external link)
I don't think you suck. Photo # 2 is nicely composed and captures a very interesting image. It's easy to learn the technical aspect of photography. It's much more difficult to learn the artisitc side. I think you understand the artistic side from your compositions and subjects' faces, you just need help with the technical side.
Alex
Feedback
PixelMagic
Oct 09, 2012 14:37 |  #12
By learning how to read the histogram(s).
Sevillian
Oct 09, 2012 15:11 |  #13
PixelMagic wrote in post #15099692 (external link)
+1 - Photos are WAY to underexposed. I would re-shoot these and avoid trying to rescue them with editing.
jack ­ lumber
Oct 09, 2012 17:24 |  #14
All the shots in your Flickr are under exposed, you need to learn about "the Triangle".
http://digital-photography-school.com …re-in-digital-photography (external link)
Keep at it shoot and post,!
There is a fine line between "hobby" and "obsession"
5D-20D-7D gripped- all canon-28MM 1.8 - 50MM 1.8 -17-40 L -100MM 2.8 macro -70-200MM L F4- 100-40MM L -1X4 teleconverter-Sigma 20-40MM 2.8:D 580 EX 11 flash- manfrotto tripods and monopods.
L.J.G.
"Not brigth enough"
Oct 09, 2012 17:32 |  #15
You will also find this (click here) (external link) site is great place to learn more about exposure & photography in general.
Lloyd
Never make the same mistake twice, there are so many new ones, try a different one each day
Gear Flick (external link)r
2,834 views & 0 likes for this thread, 12 members have posted to it.
1062 guests, 104 members online
