Thread started 09 Oct 2012 (Tuesday) 14:21
Exposure Setting 600d
Pumba
Joined Aug 2012
Oct 09, 2012 14:21 |  #1
Sorry for the simple question, but i'm confused, On my 600d set in M mode the only change i can make to the exposure is a bracketed exposure where 3 lines appear under the compensation bar, I cant seem to move it as one bar for one photo?
When i go into the menu screen and exp comp/AEB the +/- icon isnt highlighted as it is in Av mode where i can change it via the left and right buttons, and on the quick menu via the wheel.
Is there a setting i cant find to change it from AEB to single in M mode? or am i trying to do something i cant do?
Sorry if it seems confusing im struggling how to put it into words :oops::oops:
6d, 70d, 70-300L, [COLOR="Black"]100L Macro, 40mm 2.8 STM, 580exii, 430ex and still NO idea
John ­ from ­ PA
Joined May 2003
Oct 09, 2012 15:41 |  #2
Are you basically trying to set some exposure compensation while in "M" (manual)? If that is what you are trying to do, I don't think it is possible. Just simply dial in what you desire by setting aperture or shutter speed.
RTPVid
Oct 09, 2012 16:08 |  #3
There was a previous thread on this topic. The bottom line is that "exposure compensation" as used by Canon means adjusting the auto-exposure calculated by the camera by a set amount +/-. Since M mode, by definition, has no auto-exposure calculated by the camera, the exposure compensation setting is not used.
You set the exposure in M mode. If you want +1 stop over what the meter says, just open the lens up one stop, slow the shutter by one stop, do each by 1/2 stop, or whatever combination you choose.
Tom
apersson850
Gallery: 35 photos
Oct 09, 2012 18:24 as a reply to  @ RTPVid's post |  #4
When you in M mode have set the exposure such that the meter scale at the bottom of the viewfinder (which in AE modes is a compensation scale, but in M mode a light metering scale) is at the center, you've set exposure the same way as the camera would have done, had you used the P mode or whatever.
When you change a setting so the meter needle moves away from the center, you are doing the same thing as exposure compensation would have done in an automatic mode.
Anders
2,330 views & 0 likes for this thread, 4 members have posted to it.
1429 guests, 127 members online
