I thought raw was uncompressed, full info, how can that be because when I save to a Tiff from Lightroom the files are absolutely huge, like 40 MB or something. What is Tiff adding to these pics to make the files so big?
guitarjeff Senior Member 674 posts Likes: 10 Joined Feb 2012 More info | Oct 09, 2012 15:45 | #1 I thought raw was uncompressed, full info, how can that be because when I save to a Tiff from Lightroom the files are absolutely huge, like 40 MB or something. What is Tiff adding to these pics to make the files so big?
Stone13 Goldmember 1,690 posts Likes: 8 Joined Aug 2009 Location: Huntersville, NC More info | Oct 09, 2012 15:58 | #2 tiff is a natively uncompressed file format, raw files are compressed. However, tiffs can also be compressed with either Zip or LZW compression. Ken
RobDickinson Goldmember More info | Oct 09, 2012 16:08 | #3 Yeah raw is compressed, using lossless compression. www.HeroWorkshops.com
Jim_T Goldmember 3,312 posts Likes: 115 Joined Nov 2003 Location: Woodlands, MB, Canada More info | Oct 09, 2012 19:51 | #4 For each pixel, you need 24 bits of information. (That's 8 bits for red, 8 bits for green and 8 bits for blue).
Numenorean Cream of the Crop 5,013 posts Likes: 28 Joined Feb 2011 More info | Oct 09, 2012 19:54 | #5 guitarjeff wrote in post #15100014 I thought raw was uncompressed, full info, how can that be because when I save to a Tiff from Lightroom the files are absolutely huge, like 40 MB or something. What is Tiff adding to these pics to make the files so big? If you save with layers they get even larger. I have a few 600MB TIFF files floating around.
BirdsofBC " eye candy, pure and simple" More info | Oct 09, 2012 19:55 | #6 Jim_T wrote in post #15101000 For each pixel, you need 24 bits of information. (That's 8 bits for red, 8 bits for green and 8 bits for blue). There are 8 bits in a Byte. So each pixel contains 24 bits / 8 = 3 Bytes. With 3 Bytes per pixel, an 18 Megapixel (million pixel) image will have 18 million pixels X 3 Bytes = 54 Megabytes. As Stone 13 points out, there are some compression schemes for TIFF, but they aren't nearly as efficient as the lossy compression used in JPEG or the non-lossy compression Canon uses for RAW. Because of this TIFF files will always be large by comparison. Note that 18 Megapixel JPEG images also contain 54 Megabytes of information even though the file size is only 4-6 Megabytes. The JPEG images are uncompressed by your JPEG viewing or editing program. They inflate to the full 54 Megabytes in your computer's video memory locations when you want to view or edit them.
TeamSpeed 01010100 01010011 More info | Oct 09, 2012 20:00 | #7 If I understand JPG correctly, the file is more of a command structure that says "for the next X pixels, display them as RGB(A,B,C)", and depending on the compression factor, it will find similar colored consecutive pixels within a tolerance based on that compression factor, and make them all the same color. Past Equipment | My Personal Gallery
apersson850 Obviously it's a good thing More info | I haven't studied exactly how they do. Maybe that's not even disclosed, but I guess it is, since third party software suppliers do open Canon's RAW files as well. Anders
Oct 10, 2012 11:08 | #9 Great replies guys, thanks much
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Oct 10, 2012 16:52 | #10 Jim_T wrote in post #15101000 For each pixel, you need 24 bits of information. (That's 8 bits for red, 8 bits for green and 8 bits for blue). There are 8 bits in a Byte. So each pixel contains 24 bits / 8 = 3 Bytes. With 3 Bytes per pixel, an 18 Megapixel (million pixel) image will have 18 million pixels X 3 Bytes = 54 Megabytes. As Stone 13 points out, there are some compression schemes for TIFF, but they aren't nearly as efficient as the lossy compression used in JPEG or the non-lossy compression Canon uses for RAW. Because of this TIFF files will always be large by comparison. Note that 18 Megapixel JPEG images also contain 54 Megabytes of information even though the file size is only 4-6 Megabytes. The JPEG images are uncompressed by your JPEG viewing or editing program. They inflate to the full 54 Megabytes in your computer's video memory locations when you want to view or edit them. ^ You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Oct 10, 2012 17:58 | #11 12 bits = 4,096 values Elie / אלי
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Oct 10, 2012 18:38 | #12 Thanks for correcting my stupidly bad binary conversion...I shudda known better, only involved in technical applications of computing for my whole career. I guess that's why I don't do it any longer, and left the software development to the engineers! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Oct 10, 2012 22:56 | #13 Don't forget that TIFF files can also be 16bits per colour per pixel as well. That's 48 bits or 6 bytes per pixel which can make an 18Mpix image run to nearly 103Mb.
Oct 11, 2012 05:38 | #14 guitarjeff wrote in post #15100014 I thought raw was uncompressed, full info, how can that be because when I save to a Tiff from Lightroom the files are absolutely huge, like 40 MB or something. What is Tiff adding to these pics to make the files so big? Which is one very good reason for not keeping tiff files. Keep the raw file and the various recipes for creating jpegs or tiffs if at all possible. Frank Hollis - Retired mass spectroscopist
TeamSpeed 01010100 01010011 More info | Oct 11, 2012 06:22 | #15 hollis_f wrote in post #15107269 Which is one very good reason for not keeping tiff files. Keep the raw file and the various recipes for creating jpegs or tiffs if at all possible. Correct, keep a copy of the DPP installation at a very minimum in any photo gallery archive, so that hopefully if you have a catastrophe, you can go to the backups and bring up the software and the raws to reproduce any photo. I do that with my taxes as well, a CD that contains the tax software and all related electronic records accompany my paper items so I have almost everything to reproduce what I filed (or almost all). Past Equipment | My Personal Gallery
| Latest registered member is semonsters 1463 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
