Thread started 28 Dec 2005 (Wednesday) 16:06
Canon 14mm 2.8 L
JoeTwelvePack
Dec 28, 2005 16:06 |  #1
Am wondering about this lens.
As posted earlier, I'm taking a trip to UK in the Summer and need a wing angle for London and landscapes.
Would this do it?
Also, it has a rear filter. I've never had a lens with one. Is it hard to use and are there several manufacturers of the actual filters or is this a Canon-only issue?
Thanks for all your help!
Ole Joe
20D / 24-70 2.8L
"Everything's dangerous, if you're stupid!"
Jon
Joined Jun 2004
Dec 29, 2005 10:30 |  #2
It's a good wide-angle for a 20D. It takes a gelatin filter (thin sheet of coloured gelatin or plastic which is cut to fit the holder). Gelatin filters have been around for longer than glass ones; they're widely available, either as photo filters (3" or 4" square) or as theatrical lighting gels,which can be in quite large sheets. Mind you,your local Ritz won't be able to sell you one, but most quality camera stores will stock the commonest ones and be able to get the less-frequently-used ones.
Jon
Cocker Spaniels
JoeTwelvePack
Dec 29, 2005 12:13 as a reply to  @ Jon's post |  #3
Thanks, Jon, for taking the time to respond.
Not sure if I'm going to pull the trigger or not, but it's good to know that the filters are available from other manufacturers.
Ole Joe
20D / 24-70 2.8L
Pekka
El General Moderator
Gallery: 36 photos
Best ofs: 7
Joined Mar 2001
Dec 29, 2005 13:27 |  #4
Just a thought: use the money for 14mm to trade your 20D to 5D and you'll get virtually same FOV with your 24-70, and most likely with better quality.
The Forum Boss, El General Moderator
AMASS 2.5 Changelog (installed here now)
scr7b
Dec 29, 2005 13:34 as a reply to  @ Pekka's post |  #5
YES! What Pekka said, or get a 10-22...
5D, 24-70L, 17-40L, 85 f/1.8, 420EX, various other toys...
I want to die peacefully in my sleep like my grandfather. Not screaming in terror like his passengers.
Rob612
Dec 29, 2005 14:21 |  #6
SOunds reasonable, considering the cost of the 14 that becomes a 22.4 seems much a better choice getting a 5D. The quality is absolutely superb.
jjonsalt
Dec 29, 2005 15:48 as a reply to  @ Pekka's post |  #7
Of course then you will need a 100mm lens for the 5D.
Jon
Joined Jun 2004
Dec 29, 2005 17:33 |  #8
Yeah, but the 100's cheap compared to the 14. And that still has him only needing 2 lenses, plus the discontinuity is at the tele end, where it's less messy, rather than at the wide end.
Jon
Cocker Spaniels
CorruptedPhotographer
Dec 30, 2005 00:19 |  #9
If he decides that landscape is more his thing, then he should switch his 20D for a 5D. But the 5fps on the 20D is a killer!!!
Member since 2005 ^_^
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Dec 30, 2005 08:31 |  #10
I just bought the 10-22 and am really loving it. I know it is not compatible with non-crop bodies, which was one thing that made me heistate for so long, but it really is a great lens.
Doc Klepper in the USA
I
JoeTwelvePack
Dec 30, 2005 09:03 |  #11
Guys,
That's an interesting thought, as it had not crossed my mind.
I'll think about that one.
Hmmmmmm.
Ole Joe
20D / 24-70 2.8L
the.digital.guy
Dec 30, 2005 10:05 as a reply to  @ rklepper's post |  #12
I'll second that..........the 10-22mm lens is outstanding!!!!
MrChad
Joined Aug 2004
Dec 30, 2005 12:54 as a reply to  @ the.digital.guy's post |  #13
I love the 10-22mm, just not sure that lens would be a must have lens for one trip. It's a very extreme lens, I find it most useful for tight spaces as aposed to landscapes. You need to be relatively close to the landscapes to use this lens with any detail IMO.
The 16-35mm f2.8 would be on my list, one of the 3 best zooms you could own IMO. It would give you the same speed, and greatly increase the wide angle view for from what the 24-70L has now.
I tend to think 5D prices will drop a bit in the future, likely not before your trip. Just thought I'd add another silly choice.
I kaNt sPeL...
[Gear List]
jjonsalt
Dec 30, 2005 21:55 as a reply to  @ rklepper's post |  #14
Even Ken Rockwell, the Nikon lover, thinks that lens is the best. http://www.kenrockwell​.com/canon/1022.htm (external link)
MrChad
Joined Aug 2004
Jan 02, 2006 22:13 as a reply to  @ jjonsalt's post |  #15
Every review I have ever seen about this lens states it is the best thing since sliced bread for the ultra wide APS-C frame. It takes amazing shots, I'm very glad I sprang for the 10-22mm Canon instead of the 3rd party lens. I had to sell my film body to finance this lens, no regrets the pictures are wonder.
I wish all Canon non-L's could be this light and this good.
I kaNt sPeL...
[Gear List]
3,858 views & 0 likes for this thread, 10 members have posted to it.
Canon 14mm 2.8 L
1926 guests, 101 members online
