Is the evaluative metering mode in the 5D3 linked to any selected AF point, or only the center AF point? Thanks
mrmarks Senior Member 822 posts Likes: 11 Joined Jan 2010 More info | Oct 11, 2012 11:01 | #1 Is the evaluative metering mode in the 5D3 linked to any selected AF point, or only the center AF point? Thanks
Oct 11, 2012 11:09 | #2 Nevermind, found the answer on page 171 of the manual. It's linked to all points in evaluative metering mode
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Oct 11, 2012 11:33 | #3 Evaluative metering in Canon cameras has long been BIASED to the AF point used, but also does factor in the brightness of surrounding AF zones as well. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
agedbriar Goldmember 2,657 posts Likes: 399 Joined Jan 2007 Location: Slovenia More info | Oct 11, 2012 15:50 | #4 Upgrading from 30D to 5D3 I was surprised to see that the latter applies a stronger bias to the selected AF point area when One-shot AF is used compared to AI Servo.
Oct 11, 2012 18:33 | #5 agedbriar wrote in post #15109380 Upgrading from 30D to 5D3 I was surprised to see that the latter applies a stronger bias to the selected AF point area when One-shot AF is used compared to AI Servo. Depending on the scene, the reading difference can be substantial. Could you post your test shots?
agedbriar Goldmember 2,657 posts Likes: 399 Joined Jan 2007 Location: Slovenia More info | Oct 12, 2012 02:07 | #6 To determine if your camera does this or not, place the selected single focusing point over an area that is substantially brighter or darker than the rest of the framed scene and check if the suggested exposure parameters change when you switch from One-shot AF to AI Servo and back.
dave_bass5 Goldmember 4,329 posts Gallery: 34 photos Best ofs: 1 Likes: 303 Joined Apr 2005 Location: London, centre of the universe More info | Oct 12, 2012 03:16 | #7 It should also be noted that half pressing the shutter button (to achieve AF and exposure in one shot AF) locks the exposure at the AF point in Evaluative metering mode, whereas the other metering modes are locked at shot time and are taken from the centre of the frame no matter what AF point is used. Dave.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Oct 12, 2012 16:30 | #8 dave_bass5 wrote in post #15111632 It should also be noted that half pressing the shutter button (to achieve AF and exposure in one shot AF) locks the exposure at the AF point in Evaluative metering mode, whereas the other metering modes are locked at shot time and are taken from the centre of the frame no matter what AF point is used. At least, thats how i read it. Ive always thought this was the same for my old 350D, 30D, 40D and 60D although its not something i ever tested. Only if shutter button has factory setting for shutter button (focus and metering) does holding shutter button half way hold the exposure. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
apersson850 Obviously it's a good thing More info | No, because it locks when you lock focus. And if you have that at AF-ON, you don't lock. Anders
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
