Thread started 12 Oct 2012 (Friday) 18:01
Question about lenses and Filters...
erikfig
Joined May 2012
Oct 12, 2012 18:01 |  #1
Hello All,
I shoot car photography, usually outdoors and just got a CPL to minimize or the annoying reflections. I always have a UV on my lens so the question is:
Can I just use the CPL on top of the UV so I don't need to swapping filters and just put it and take it out with ease? The light is not a concern as I shoot mostly Outdoors but I don't know if the image quality will be affected by having two filters (more glass) at the same time. Filters are Hoya though...
Have anybody do or done that?
You're feedback will be appreciated...
-Erik
Who cares about my gear?
FlickR (external link)
Facebook (external link)
aegid
Joined Apr 2011
Oct 12, 2012 18:07 |  #2
You can. Just be careful not to get them stuck together. Slim CPL stuck on a UV filter is not fun to deal with. There is probably going to be a hit to IQ but not enough to really notice unless you're staring at it 100%.
5d3,17-40,24-105,24 1.4,85 1.4,70-200 2.8 is ii
Nightdiver13
Unabashed nerd!
Oct 12, 2012 18:07 |  #3
I'd use the CPL by itself. The more layers of glass you stack up front, the more you risk image degradation. Sometimes this can't be helped, such as stacking a CPL with an ND filter, but in your case the UV filter is superfluous when the CPL is on there.
Neil
Preeb
Gallery: 151 photos
Joined Sep 2011
Oct 12, 2012 18:16 |  #4
erikfig wrote in post #15114696 (external link)
Hello All,
-Erik
This may be an unnecessary post, but you are aware that the CPL can only reduce reflections from glass or water, not from metal or painted surfaces? I only make this comment because I've met a couple of relatively experienced photographers who were unaware of that limitation.
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
1Tanker
Oct 12, 2012 19:13 as a reply to  @ Preeb's post |  #5
Just use the CPL. Stacking filters can also lead to vignetting, depending on how wide your lens is, or at the widest focal-lengths on some zooms.
Kel
Gear
erikfig
Joined May 2012
Oct 12, 2012 22:35 |  #6
Preeb wrote in post #15114737 (external link)
I bought it for the glass ones specially the windshield and the sides, I take 2 shots and then merge the different shots in post. Thanks though :D
Thanks guys!
1,258 views & 0 likes for this thread, 5 members have posted to it.
1070 guests, 114 members online
