Thread started 14 Oct 2012 (Sunday) 12:46
Will EOS Utility work for 2 different model cameras?
Hulka
Oct 14, 2012 12:46 |  #1
I have a 5D and I just purchased a 7D. Can you use the EOS Utility to down load the pictures from both cameras or will it only work for one model?
I have a 40D that I have tried to use like that but it never worked. I just pulled the CF card out of the camera or went into it via "my computer."
Any suggestion will be appreciated.
http://www.flickr.com/​photos/61517977@N03/ (external link)http://www.flickr.com/​photos/61517977@N03/ (external link)
windpig
Chopped liver
Oct 14, 2012 13:06 |  #2
The newest version has always worked with my 40D, 7D, 5DII, 5DIII
Go ahead, spin the wheel.
Christiaan_BT
Oct 14, 2012 14:10 |  #3
Depending on what software you are running... I personally havent had any success in OSX or windows running canon utility for the 5Dc. 5d2, no problem, but the 5d you can only transfer images from. Something about canon snow bothering to support an older model camera with newer sotfware. Stupid i think...
7d should work no problems though...
Canon 5D3 | Canon 1V HS | 16-35L f2.8 | 35L f1.4 | 24-70L f2.8 II | 135L f2.0 | 70-200L f2.8 | Σ 105 Macro | Nifty Fifty & many trinkets to match!
tkbslc
Oct 14, 2012 14:15 |  #4
Sure does. You can even have different import settings based on camera model.
You could try Zoombrowser, too. That's what I use because my other Canon is not an EOS so EOS utility won't work with it.
Taylor
EOS Rp | iPhone 11 Pro Max
LeeRatters
Oct 14, 2012 16:12 |  #5
When I plug the 5D2 in & switch on Utility always says "camera not recognised" so I shut down & re-open & it's fine then.
450D it never seems to start quick enough & the camera goes into stand by & all the options are dead so have to reawaken it :)
>> Flickr << (external link)
>> Instagram<< (external link)
Hulka
Oct 14, 2012 17:14 |  #6
I am running windows Vista and when I bought the 5D, used, I already had the current EOS Utility running at the time. It would not recognize the camera, so I had to find the older software and that rendered the 40D useless per-say. (could not use EOS utility anymore.) I have PS Elements 10 but have not been successful in trying to download pictures from it. Just trying figure out options so when I get it I will not be frustrated like the 5D. I might just go through my computer and download them that way.
flyingbarron
Gallery: 15 photos
Oct 14, 2012 20:13 |  #7
I needed to upgrade the EOS Utility after getting a 7D with firmware 2.0.3, once I did that then there were no problems.
80D | EF-S 18-135 IS USM | EF-S 10-18 STM IS | EF-S 24 2.8 | EF 50 1.8 STM | 430EX II
Space History & Tech at https://flyingbarron.m​edium.com (external link)
3,454 views & 0 likes for this thread, 6 members have posted to it.
862 guests, 165 members online
