or churches... how do you guys do it?
I mean with strobes you obviously cant use ETTL and let the strobe decide how much power to give you depending on the cameras exposure settings.
Do you guys put reflectors on your strobes and point them upwards and bounce them from ceilings?.. or do you use them straight towards the subjects?
The only way i can think of is.. having 4 strobes in 4 corners of a hall pointed towards the roof and setting their power manually and getting a light meter and taking readings in different areas of the room and as long as all the readings are within half a stop of difference then you're good to go.. is this what you guys do?
for example setting strobes so you get 1/200 at f/2.8 and ISO 400 around the whole reception hall.. in some areas f/2.5 and in others f/3.2 at max? That way if you need a shot at f/4 then you just bump the ISO by 1 stop.. and if you need f/2 then you'd go down to 100 ISO and so on.
