Thread started 16 Oct 2012 (Tuesday) 04:03
Yongnuo rf-603 c3 related
kaddafy
Oct 16, 2012 04:03 |  #1
Hi everyone!
So my question is:
I have a canon 1d MKIIN with a canon 580EXII and two NISSIN 860 MARKII,
And want buy a set of yongnuo rf-603 c3 triggers!
Anyone knows if this settings will work together?
Thanks in advance for any reply!
DavidR
Oct 16, 2012 05:30 |  #2
The RF-603 triggers will work with your camera and with your flashes in manual mode.
Sony a9II
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Oct 16, 2012 08:08 |  #3
As mentioned above, you lose E-TTL... even if you mount a flash on the camera with the trigger in between - there is no E-TTL pass-through.
That's fine depending on your use, especially considering the price, but just be aware :)
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
ksbal
Gallery: 374 photos
Best ofs: 9
Oct 16, 2012 12:16 |  #4
yes, the 603's will work with all of those.. in manual only. yn-622c will work with ettl, and some other modes, you may wan to read up on the 622s here:
YN622 Guide https://docs.google.co​m/open?id=0B77...FpqNk​pBYXBHajA (external link)
Godox/Flashpoint r2 system, plus some canon stuff.
kaddafy
Oct 17, 2012 08:43 as a reply to  @ ksbal's post |  #5
Thanks for the help!
I want the triggers for downhill mountain bike photography and skate photography!
I dont know if this triggers are capable to help me out on those situations!what do you guys think?
dmward
Gallery: 29 photos
Oct 17, 2012 08:51 |  #6
The triggers will fire the flash guns. That's all they will do.
If you want ETTL capabilities then you need to consider the YN-622c triggers. They will support ETTL between the camera and the flash units you own.
protege
Oct 17, 2012 09:39 |  #7
kaddafy wrote in post #15133379 (external link)
I have the RF603C myself. You may encounter a problem in that the triggers only support up to 1/250th shutter speed. They do not support High Speed Sync. Also, they are not 100% reliable. I'd say more between 80-90% reliability. Still great for amateur photography though.
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Oct 17, 2012 09:57 |  #8
One other thing to note that I've just thought of is the lack of screw on the triggers, so if you're mounting a flash onto the trigger, and then the trigger onto the camera, it can wobble a bit. Ideally I use these for a totally off-camera setup.
ksbal
Gallery: 374 photos
Best ofs: 9
Oct 17, 2012 13:45 |  #9
Yes, if 1/250'th will stop the action enough.. I think the yn-622 will be a better fit if you need shutter speeds above that and are shooting canon.
BrickR
Joined Mar 2011
Oct 17, 2012 15:10 |  #10
I thought the 603s could reach 1/320 and 602s only 1/250? (I have 602s and 250th is the max for sure. I have one set of 603s but haven't tested 320th yet)
I have one 602 trigger that was unreliable and found that the on/off switch was "loose" and wouldn't stay firmly in the "on" position, which is why is wasn't firing reliably. A tiny piece of tape to ensure it stayed all the way in "on" solves that...when it happens; it doesn't happen all the time. On a side note: the speedlight batteries will die LONG before the trigger batteries do when left on, so taping it "on" isn't an issue.
My junk
The grass isn't greener on the other side, it's green where you water it.
DavidR
Oct 17, 2012 15:38 |  #11
BrickR wrote in post #15134897 (external link)
The 603 like the 602 is nothing more than just a wireless on/off switch to fire the strobe. The best it could ever do is the top sync speed of your camera, in your case 1/250.
Sony a9II
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Oct 17, 2012 16:01 |  #12
ksbal wrote in post #15134562 (external link)
I shot MB for 10 years, and found that 1/800th was needed. I used HSS of courfse, which could still deliver the fill light to get under helmet hoods, in forest or full sun.
I wish the YN-622C (not a mistyped YN-602) had been available! Their rapid response time would be very useful.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
kaddafy
Oct 20, 2012 06:56 as a reply to  @ CliveyBoy's post |  #13
I had a canon st-e2 before for this kind of shots and i never think about off taking a shot at 1/250 because i had HSS!
But does the pocket wizards plus II have HSS? A friend of mine have them and they really stop the motion!
I think i'll consider the yn 622 just because they do HSS cause i dont use ETTL just manual!
2,289 views & 0 likes for this thread, 8 members have posted to it.
1160 guests, 162 members online
