Thread started 16 Oct 2012 (Tuesday) 10:12
Manual focus screen
doidinho
Oct 16, 2012 10:12 |  #1
I'm interested on hearing from people that use the manual focus screen with their camera. I would be using it on my 5D2 with my 85 1.8 most of the time and mostly for closer in shots of people.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
John ­ from ­ PA
Joined May 2003
Oct 16, 2012 10:21 |  #2
I assume you mean the LCD, in which case I do use it on my 60D quite a bit. The screen, having the swivel feature lends itself to focusing nicely.
doidinho
Oct 16, 2012 10:24 |  #3
Nope, I'm talking about the focus screen. The thing in your viewfinder where you see the af points. Thanks for the reply though.
Robert McCadden
MM (external link)
Wilt
Oct 16, 2012 11:03 |  #4
Changing the focus screen to the Canon ones have CFn settings to compensate the screen to restore accuracy of the metering system.
Changing the focus screen to the aftermerket ones have no CFn settings, no compensation of the screen brightness to restore accuracy of the metering system, so there can be 3EV of metering error particularly in Spot/Partial mode
vsg28
Joined Aug 2012
Oct 16, 2012 11:07 |  #5
I had one for my 60D, a inexpensive 45 degree double shift and microprism style from eBay. It was wonderful for my macro work. I have a 7D now, and once Magic Lantern is released with focus peaking I will get a focus screen for this too.
The exposure errors only happen with lenses slower than f/4. Even my 24-105L was accurate. The area outside the center is a bit darker owing to the prism diffraction, but that can't be helped.
Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
Dawicka2
Joined Feb 2012
Oct 16, 2012 11:08 |  #6
I have a split screen in my 1dmk2n and could not live without it.
Actually makes my 55mm f1.2 nikon lens usable... along with the rokinon 85mm (wide open). For the 20 bucks... it is well well well well well well well well well well well well worth it. :)
Magic lantern'd T2i, a 1d2n, 15-85, rokinon 8 and 85mm, nikon 55 f1.2, sigma 24mm f1.8 and Tokina 400mm creeperPrime.
Ramon-uk
Gallery: 61 photos
Oct 16, 2012 11:13 as a reply to  @ Wilt's post |  #7
If you are asking about the Canon Super Precision matte screen then I can recommend it. I use one in a 50D and can achieve spot on manual focus at f1.8 in most lighting situations. It is reputed to be slightly darker than the standard screen but I have found the difference to be so slight that it is not noticeable.
I would advise against using one of the non-Canon split image screens, I have tried various makes and found them all less than satisfactory, although they focus well, most of them need shimming to get them in the correct position, they black out at smaller apertures and upset the metering.
doidinho
Oct 16, 2012 14:13 |  #8
Wilt wrote in post #15129632 (external link)
Ramon-uk wrote in post #15129688 (external link)
Thanks for the info guys. It is indeed the Canon Super Precision matte screen I am considering and will likely get.
Robert McCadden
MM (external link)
paulkaye
Joined Nov 2010
Oct 16, 2012 15:23 |  #9
Dawicka2 wrote in post #15129659 (external link)
Ok, so who's right? I'd really like to get the Samyang 35mm 1.4, but recognise that manual focus without a decent screen is going to be a non-starter. As an old Pentax Spotmatic user with its huge viewfinder and fantastic split image screen, that's the direction I'd like to take, but Ramon-uk's comments are a concern. Does the precision matte screen deliver the goods in terms of accurate focussing?
Paul
5DII, 50mm 1.4, 17-40L, 85mm 1.8, 24-105L IS, 70-200L f4 IS, 100-400L, 100 f2.8 Macro
gibbit1
Oct 16, 2012 15:28 |  #10
I just bought the super-precision screen for my 5dmkII, and I really love it. It does make the viewfinder a bit darker when using my 70-200mm f/4, but it's not too bad. I can focus my Pentax Super Tak 50mm f/1.4 so easily now, whereas before it was very difficult. Easy to install, too.
"Everything will be alright. I'm from the government and I'm here to help."
Gear: EOS 5DMKII; EOS 400D (infrared converted); Canon 24-105mm f/4 L; Sigma 17-35mm f/2.8-4 EX; Canon 70-200mm f/4 L; Canon 135mm f/2.0 L; Pentax SMC Takumar 50mm f/1.4 with EOS adaptor, Rokinon 14mm f/2.8; only enough knowledge to be a clear and present danger to society.
paulkaye
Joined Nov 2010
Oct 16, 2012 16:00 |  #11
gibbit1 wrote in post #15130596 (external link)
Does the Tak 50 1.4 focus to infinity on the 5dmkii without fouling the mirror?
Paul
Wilt
Oct 16, 2012 16:31 |  #12
paulkaye wrote in post #15130572 (external link)
It seems that many folks who want better precision of manual focus overlook meter error simply since they only put the meter into Evaluative mode, they'd often never discover meter error.
Hey, lots of folks use manual adapter legacy lenses, and never realize the meter error which can be demonstrated with stopped-down aperture metering with those lenses, too! https://photography-on-the.net …hp?p=15006557&p​ostcount=6
The failure to realize there is an error is itself NOT proof that an error condition does not exist, unfortunately, and it goes unacknowledged.
oldvultureface
Gallery: 85 photos
Oct 16, 2012 19:32 as a reply to  @ Wilt's post |  #13
I have Canon's Ef-S screen in my 50D and get about a 90% manual focus hit rate with the 50mm f/1.8. Otherwise, using the standard screen focusing manually or with the camera's AF, focus is inconsistent at best. I do think it was worth the money.
LowriderS10
Oct 16, 2012 22:13 |  #14
I, personally, would not use anything other than the Canon screens for the simple fact that if you get the Canon, you can use the CFn to compensate for the screen (I have an Eg-D in my 5D2)...after all I've read about aftermarket screens messing with metering, I'm not taking chances :)
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
doidinho
Oct 16, 2012 23:01 |  #15
LowriderS10 wrote in post #15132131 (external link)
What are you using the custom function to compensate for?
Robert McCadden
MM (external link)
3,617 views & 0 likes for this thread, 13 members have posted to it.
Manual focus screen
1061 guests, 104 members online
