Just seeing if Anyone try the Sigma 105mm OS macro? How is it? Does it compare to the canon L?
Modigity Senior Member 505 posts Likes: 2 Joined Apr 2011 Location: Pacific Northwest More info | Oct 16, 2012 13:44 | #1 Just seeing if Anyone try the Sigma 105mm OS macro? How is it? Does it compare to the canon L? Morgan Ellis
vsg28 Senior Member 493 posts Joined Aug 2012 Location: Houston, TX More info | Oct 16, 2012 14:27 | #2 Not bad for $769 new, go for it. I had the Sigma 150 OS and it was way better. Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
jimewall Goldmember 1,871 posts Likes: 11 Joined May 2008 Location: Cleveland, Ohio More info | Oct 16, 2012 15:19 | #3 vsg28 wrote in post #15130384 Not bad for $769 new, go for it. I had the Sigma 150 OS and it was way better.
Thanks for Reading & Good Luck - Jim
vsg28 Senior Member 493 posts Joined Aug 2012 Location: Houston, TX More info | Oct 16, 2012 19:50 | #4 I meant the 150 OS was better than the 105 OS in terms of IQ. In fact, nothing can beat the Sigma 150 OS for macro IQ- not even the 180 OS they just released. But for me, the 100 L was way easier to handle in terms of better IS (1 stop), versatility and weight (half the weight) compared to the Sigma 150 OS. Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
Oct 16, 2012 20:19 | #5 I rented both the Sigma 150 and the Canon 180. The Sigma was better than the Canon 180. Everyday use: 7D2, 1.4x v3 Canon TC (sometimes the 2x v2 Canon TC), Canon 500mm f4 L IS USM; 6D, 24-105L
vsg28 Senior Member 493 posts Joined Aug 2012 Location: Houston, TX More info | Oct 16, 2012 20:21 | #6 Not surprised, I may pick up a non-OS Sigma 150 if I ever need more reach than what my 100 L will give me. At $500 max used, that is a fantastic deal. Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
jimewall Goldmember 1,871 posts Likes: 11 Joined May 2008 Location: Cleveland, Ohio More info | vsg28, thanks for the clarification. Thanks for Reading & Good Luck - Jim
CountryBoy "Tired of Goldmember label" 5,168 posts Joined May 2006 Location: Okie More info | Oct 16, 2012 20:43 | #8 vsg28 wrote in post #15131697 Not surprised, I may pick up a non-OS Sigma 150 if I ever need more reach than what my 100 L will give me. At $500 max used, that is a fantastic deal. I'm going to put mine up for sale at $550 , so I guess that will leave you out , lol .... Hi
vsg28 Senior Member 493 posts Joined Aug 2012 Location: Houston, TX More info | Oct 16, 2012 21:08 | #9 jimewall wrote in post #15131783 vsg28, thanks for the clarification. You have used both the 150OS and new 180OS? How close is the 180 to 150 in IS and handling? I don't need a 150 FL, but can use a 180 FL. Is it worth the chunk cash they are asking for it (in your opinion)? Is the 180 OS worth the extra money over the 150 OS? Simply put- No. You gain very little FL but at the cost of much more weight. To keep it at f/2.8, Sigma has massive lens elements in the lens which made it unwieldy for me at least. Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
| Latest registered member is zachary24 1449 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
