Thread started 16 Oct 2012 (Tuesday) 22:06
venting
m52
Gallery: 53 photos
Oct 16, 2012 22:06 |  #1
At the begaining of this year I posted about a "sanity check LUT failed" error message when i tried to run spyder 3. After contacting Datacolor reloading and upgrading, no fix. With the help of a POTN member tried unloading and reloading the Radeon Hd 5700 display adapter, no change. Seams the problem may be the operating system. I decided to hold off reloading it untill last week (work related reason). I took my harddrive a Dell dimension i7 into work and the I.T. department tried to run a couple of internal fixes. than tried to run the spyder using there monitor, same error message. Imaged the system, reloaded the operating system and than loaded the spyder 3 and upgraded to 4. Ran the spyder it worked. Took the harddrive home loaded PS5, Lightroom3, windows works and logitech. ran the spyder to calabrate my Dell U2410, and I get the error message. So thinking it was the logitech I tried to uninstall it and than run the spyder, error message. I went back to I.T. reload OS, PS, lightroom and works then the spyder 3 and upgraaded to 4. Still get the error message. Have a Dell SE198WFP monitor tried the spyder on it same error message. The spyder works on my Dell laptop and it has the same software. Its probably all a waist of time since i'm partialy color blind, but if I have the tools to do it right then I would like to at least try. Not much on giving up. Is thier another color calibration system that will work with my system? any way to rent it first to see if it works before buying?
Sorry about the long rant.
Randy
isoMorphic
Oct 17, 2012 01:07 |  #2
m52 wrote in post #15132105 (external link)
Sounds like a glitch in the matrix rather then the device and you need to isolate the problem. In the future create a system backup after each step until you find the cause. Then roll back the system settings rather then using the uninstaller (especially for drivers) when you do. It will save you time and lots of headaches doing it this way rather then depending on someone else to keep fixing you up.
René ­ Damkot
Oct 17, 2012 07:26 |  #3
Very hard to read post, so I might have missed something, but you could try different software maybe?
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Gil ­ Bean
Oct 17, 2012 16:01 |  #4
René Damkot wrote in post #15133160 (external link)
now, Meneer Damkot, play nice. You may have trouble reading the post but please do not blame it on m52.:lol:
Just kidding you! :)
Gil
G3, G6, G12, T2i + kit lens & accoutrements
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Oct 17, 2012 21:50 |  #5
Gil Bean wrote in post #15135103 (external link)
Gil
René is one of the best troubleshooters on this forum. If you come here for help & can't be bothered to make your question easy to understand...
m52
Gallery: 53 photos
Oct 17, 2012 23:12 |  #6
Thanks isomorphic, next time i'll try your sugestion. what do you mean by glitch in the matrix?
Thanks Rene, sorry about the confusing post. what other color calabration softwware would you recomend?
Just kidding you!
Gil
Thanks PhotosGuy, I'll have to work on my wording skills along with my computer skills
Randy
isoMorphic
Oct 18, 2012 01:13 |  #7
m52 wrote in post #15136757 (external link)
Driver conflict due to the fact you can't just simply uninstall drivers. There is a program called driver cleaner that could possibly fix you up.
René ­ Damkot
Oct 18, 2012 08:41 |  #8
BasICColor Display4 (external link) or ColorEyes Display Pro (external link) both have a trial.
I use the (free) DispCal/ArgyllCMS (external link) to calibrate my second monitor (cheap TN screen) because it get's it closer to my main Eizo then MonacoOptix does. But it takes more then an hour to do so…
I'd try isoMorphic's solution first though.
Gil ­ Bean
Oct 18, 2012 17:01 |  #9
PhotosGuy wrote in post #15136455 (external link)
PhotosGuy,
If you noticed, I said "Just Kidding You". I have great respect for René. I have "snapped" at 2 people (actually more than 2) and René Very Politely reminded me not to be such a grouch. In one post I wrote, "now someone will tell me to "Play Nice". The next post was from René. It simply said "yeah, play nice". I believe it had a smile. I was simply saying Hello to René, which is why I used :D:lol: and "Just kidding". There was absolutely no seriousness to my comment to René. Please, look a little closer at my post. The humor should be obvious.
Gil
m52
Gallery: 53 photos
Oct 18, 2012 21:18 |  #10
Thanks isoMorphic, I tried driver sweeper before reinstalling windows, should I run driver sweeper again?
BasICColor Display4 or ColorEyes Display Pro both have a trial.
I use the (free) DispCal/ArgyllCMS to calibrate my second monitor (cheap TN screen) because it get's it closer to my main Eizo then MonacoOptix does. But it takes more then an hour to do so…
Thanks Rene, I'll try driver sweeper than try one of your sugestions.
Randy
PhotosGuy
Joined Feb 2004
Oct 18, 2012 23:31 |  #11
Gil Bean wrote in post #15140037 (external link)
PhotosGuy,
Gil
Actually, I was referencing the "You may have trouble reading the post but please do not blame it on m52." part, and addressing m52, not the other part of your comment. I've seen a lot of questions in huge blocks of text like M52's, & often wonder why we should be expected to donate time to solve a problem when they can't be bothered to hit the Enter key once in as while?
René ­ Damkot
Oct 19, 2012 03:41 |  #12
Play nice guys… :lol:
What's an M52? The BMW or the tank?
PhotosGuy
Joined Feb 2004
Oct 19, 2012 09:28 |  #13
René Damkot wrote in post #15141876 (external link)
Take your pick:
1. A highway in Michigan & South Lancashire.
2. The OP's username. ; )
3. Messier 52 (also known as M 52 or NGC 7654) is an open cluster in the Cassiopeia constellation.
4. A Canon VIXIA HF M52 Full HD Camcorder
5. Low Distortion High Level Measurement Microphone.
6. Yugoslavian M52 Series Fragmentation Grenades
7.iVIS HF M52/HF M51 概要 - キヤノン (external link)
Mike
ugly when I'm sober
Gallery: 51 photos
Oct 19, 2012 09:32 |  #14
Quis custodiet ipsos custodes?
Or, who moderates the moderators?
:p:p:p:lol:
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
Gil ­ Bean
Oct 19, 2012 16:06 |  #15
PhotosGuy wrote in post #15141415 (external link)
Frank,
OOPS, I did it again:oops: (not reading closely). BTW, I was not "giving you a hard time". I simply wanted you to know I was not insulting René but merely "cutting up".
Regretfully, I am guilty of not hitting the "enter" key. I have asked (many times) a question that I could have easily found an answer to had I taken a bit more time to look, read, searched Google instead of here, and etcetera. When someone points out the obvious, I want to beat my head against the wall and crawl under a rock. I feel sooo stoopid.
Gil
5,974 views & 0 likes for this thread, 6 members have posted to it.
venting
1293 guests, 125 members online
