Thread started 29 Dec 2005 (Thursday) 13:09
night shot help
athos2000t
1 post
Dec 29, 2005 13:09 |  #1
Ok, i'm an absolute rookie here. I've been taking shots with my Rebel for some time now and so far had some good ones with good lighting. Not that long ago i got myself 430ex flash, which is very nice when taking shots of objects in normal lighting conditions. However, couple days ago i was taking shots of my friend in Grand Central, and was trying to get both - my friend and some background, but ended up taking the 430ex off the camera and using built-in flash in "night" mode. How do I use the 430ex to take a good night shot so that background doesn' disappear? I know it's probably something simple, but i just cannot figure it out:oops:
Thanks in advance!
TS
<Rookie>
Digital Rebel
430 ex
EF-S 18-55mm 3.5-5.6, EF USM 75-300mm USM, EF 50mm 1.8, EF 28-135mm 3.5-5.6 USM IS
Titus213
Dec 29, 2005 13:55 |  #2
I put the camera in M and set up the shot based on the ambient light to get the best exposure I can without the flash. Then the flash will light the foreground subject. Just watch that the shot you meter can be hand held without a problem.
If you put the camera in Night mode you can check the f-stop and shutter speed it has selected to use as a guide.
And if I've got this wrong someone will straighten us both out.
Welcome to the forums. It's a great place to learn.
Dave
Perspiring photographer.
ootsk
Joined Jan 2002
Dec 29, 2005 15:38 |  #3
That's probably good advice. Also you can try Av mode...that allows the E-TTl to try to match the background with the subject. This might lead to slow shutter speeds, so a tripod or a steady hand is required.
In Av mode, set the f-stop at the lowest number your lens has, btw.
Murphy66
Joined Nov 2005
Dec 29, 2005 21:46 as a reply to  @ ootsk's post |  #4
1/60, f/5.6 in Manual mode.
Start there and adjust if needed (probably won't need to).
Get a Lightsphere II (it's amazing).
Good luck.
www.marcottephotograph​y.com (external link) is my port and my blog is www.studiomarcotte.com (external link)
1,065 views & 0 likes for this thread, 4 members have posted to it.
night shot help
1584 guests, 137 members online
