Thread started 17 Oct 2012 (Wednesday) 11:55
Err 5 Help
cdiver2
Joined Feb 2012
Oct 17, 2012 11:55 |  #1
I have a 7D and never used the on board flash....untill I get into the middle of Africa and find the flash will not come up. I have turned the camera off and back on with no luck, I took the batterys out and it. still will not come up. Is there a way around this without sending it back.....its cramping me with a lot of photographs.
ny sugestions will be appreciated.
Yogi ­ Bear
Oct 17, 2012 19:12 |  #2
From Canon DLC:
"Err 05: Built-in flash obstruction (external link)
The camera detects that the built-in flash has not reached its normal, raised position for flash shooting, and is halting operation until the obstruction to the flash is cleared, or the flash is pushed back down to its OFF position."
Have you tried pushing the flash down? It sounds like it may be in between up and down?
Canon EOS 7D | EF-S 17-55mm f/2.8 IS USM | EF-S 55-250mm f/4.0-5.6 IS |
EF 100-400mm f/4.5-5.6L IS USM | 250D | EF-S 10-22 mm f/3.5-4.5 USM | 580 EX II |
rrblint
Gallery: 84 photos
Joined May 2012
Oct 17, 2012 20:53 as a reply to  @ Yogi Bear's post |  #3
Inside the hotshoe rails(on the right as the camera is viewed from behind, I think) is a microswitch that detects when an external flash is attached. This switch sometimes gets stuck in the down position making the camera think that a flash is in the shoe, and thus it thinks that it can't raise the inboard flash.
This switch can usually be freed by prying it gently with a thin bladed knife.
Mark
amfoto1
Oct 17, 2012 22:00 |  #4
rrblint wrote in post #15136230 (external link)
This is correct and usually solves the problem.
A wooden toothpick will work, too.
cdiver2
Joined Feb 2012
Oct 20, 2012 07:53 |  #5
Thanks guys I am at the end of the trip now and have had no internet connection but will look for the microswitch before sending it for repaire
1,209 views & 0 likes for this thread, 4 members have posted to it.
Err 5 Help
1064 guests, 102 members online
