Among the canons, what's the best budget option ?
would go for a New one. No second hand. What you guys would suggest.
As i cant mention my budget here as i hv no idea
Write some of your fav macro lenses here. n budget options please
Oct 18, 2012 10:26 | #1 Among the canons, what's the best budget option ?
vsg28 Senior Member 493 posts Joined Aug 2012 Location: Houston, TX More info | Oct 18, 2012 10:39 | #2 1) Kenko tubes on your 50mm Canon 7D w/grip, Canon SX30 IS (modified for IR), Rokinon 14mm, Canon 24-105 L IS, Sigma 50mm, Canon 70-200 F/2.8 L IS II, Canon 100mm L IS, Kenko 1.4x Pro DG, Canon 2x II extender, Yongnuo YN-565EX, Induro CT414 with Induro BHL-3 and GHB-A
CaliWalkabout Senior Member 337 posts Likes: 11 Joined May 2010 Location: Oakland, CA, USA More info | Oct 18, 2012 12:40 | #3 The EF-S 60mm is amazing for the price. 6D, 17-40L, 24L II, 50L, 100L, 70-300L.
NatureNut Goldmember 1,366 posts Likes: 2 Joined May 2012 Location: NY More info | Oct 18, 2012 12:48 | #4 What are you shooting? For critters you may want a longer lens like the 100mm non-L Adam - Upstate NY:
pulsar123 Goldmember More info | Oct 18, 2012 12:50 | #5 + 1 to extension tubes for your nifty-fifty. You can do it even cheaper, by getting non-brand extension tubes with electric wiring from ebay, for 70$. (They are plastic, but so is your 50mm lens...) 6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
NatureNut Goldmember 1,366 posts Likes: 2 Joined May 2012 Location: NY More info | Oct 18, 2012 12:56 | #6 Polaroid also makes a set of communicating tubes that are cheaper than the kenko set. I presently use kenko tubes on my 50 1.8 and its a decent macro setup for larger critters and objects. Adam - Upstate NY:
saintz Senior Member 428 posts Joined Mar 2012 More info | Oct 18, 2012 13:26 | #7 The 28-135 and 28-105 both are cheap and have macro. Not real macro, for insects, but enough for flowers, product shots, etc. Depending what you shoot, these can be cheap alternatives. Sony A6000 | 18-55 | 16-50 | 50 f1.8
sarahwhite Member 63 posts Joined Aug 2012 More info | Oct 18, 2012 13:31 | #8 What about the 100mm 2.8 macro. It's sharp, cheap, usefull ! Photographer at Flanelle Magazine www.flanellemag.com
nightcat Goldmember 4,533 posts Likes: 28 Joined Aug 2008 More info | Oct 18, 2012 14:22 | #9 The 60mm 2.8 and 100mm 2.8 are outstanding, but the best budget bang for the buck macro would be the 50mm 2.5 CM. This is not a 1:1 repoduction macro, but a 1:2. So if you want to photograph the wings on a fly, you'll need a 1:1, but for close ups of flowers or most anything else, 1:2 is fine. Its quite sharp wide open and has some very nice bokeh. And you can buy a used one for about $175.
beareeyeaan Hatchling 7 posts Joined Aug 2012 More info | Using Kenko Tubes + 50mm. It's decent but you're probably better off with 100mm. There's a thread out there on POTN on the kenko tube setup as well. I like pretty things
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Oct 18, 2012 15:34 | #11 ekfaysal wrote in post #15138315 Among the canons, what's the best budget option ? would go for a New one. No second hand. What you guys would suggest. As i cant mention my budget here as i hv no idea Write some of your fav macro lenses here. n budget options please my vote would be for the Tamron 90nn 2.8 macro. consider used, these macro prime lens don't wear out
| Latest registered member is semonsters 1053 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
