Mnbruce wrote in post #15149763
I'm curious what the main advantage to this type of screen is?
The articulating screen, when combined with Live View, liberates a photographer from needing to hold the camera at face level and frame each image through the reflex viewfinder. Images can use different angles such as these where the camera was placed at ground level, the image was framed through the articulating screen, and there was no reason to get on the ground.
| Byte size: ZERO | Content warning: NOT AN IMAGE |
It should also be noted that the combination of the articulating screen and Live View allows a DSLR to be operated in the same manner as medium format cameras with waist-level viewfinders such as Hasselblads and Rollieflexes. These cameras were in use as hand-held devices for decades before 35mm film and DSLR's were fashionable.
