POTN forums are closing 31.12.2023. Please see https://photography-on-the.net/forum/showthread.php?t=1530921 and other posts in that thread for details.
Thread started 21 Oct 2012 (Sunday) 20:29
YN-622 trigger: AF beam adjustment
maximme
Joined Oct 2012
Oct 21, 2012 20:29 |  #1
just like to share my experience with adjusting the AF beam that was hopeless
aiming outside of the lens Centre AF point.
the way to open up YN-622 radio trigger has been explained nicely here.
The thing that caught me was the 5th short screw that was covered with
some sticker.
Without this work done here by Cliveboy, i wouldn't have gotten it opened.
https://photography-on-the.net …ead.php?t=12125​30&page=55
Once the 5th screw is released, the covers come off nicely.
The laser is held by 2 small screws and has a bottom plastic support.
Its this plastic support that comes handy when you need to adjust the laser.
I inserted something springy below this plastic support so that it pushes the laser up.
You will need to loosen the 2 screws holding the laser first.
THEN, using this springy support, you can then very slowly adjust the laser
by tightening the 2 screws.
This will raise or lower the laser by just that tiny bit.
You will need to go back and forth testing your lens at various distance
to see how much to tighten or loosen.
Dont worry about the case screws cause as long as you dont use too much force,
they come off and go in rather easily.
MAKE sure you use the correct size phillips screw driver. Think its the smallest size.
have fun.
maximme
Joined Oct 2012
Oct 21, 2012 23:51 |  #2
i would like to add
the AF pattern is dots rather than lines like that of canon.
In some distance and zoom positions, the AF zone end up in between the dots, ie,
as good as no AF beam.
that's the problem of using dots.
Whortleberry
Joined Dec 2011
Oct 22, 2012 04:27 |  #3
It's a Phillips #0 screwdriver - there are #00 and #000 also available in even modest "Jeweller's screwdriver" sets. Incidentally, the 0.375" case screws are for the corners of the case and the 0.25" is for the centre. Removing the centre scew also auto-destroys the membrane date-of-manufacture label and voids the warranty.
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
wambam
Oct 22, 2012 06:19 |  #4
Hi thanks for the info,
I would like to have a go at this, as mine are set too high.
The ' springy thing ' have you any suggestions pls?
maybe a piece of sponge?
maximme
Joined Oct 2012
Oct 25, 2012 06:17 |  #5
i cut a small strip from a plastic name card...pretty thick plastic n hardy...folding it made it springy
wambam
Oct 30, 2012 17:45 |  #6
maximme wrote in post #15166956 (external link)
Ok thanks
Whortleberry
Joined Dec 2011
Jan 23, 2013 07:18 |  #7
Here (external link) are a few pics showing access to and configuration of the laser AF assist source (and one or two other things too).
110yd
Joined Jan 2005
Jan 23, 2013 08:21 |  #8
I received 4 YN-622C triggers recently. Thus far it looks like three of the units have an alignment issue. I hope to try the units on a different body to see if the problem is slop in the hotshoe or if it is truly the YN-622C units. With a 40D all four units were putting up a pattern that was high and to the left of the center auto focus point of the camera. My first impression would give the units a good grade, with a quick test with two flashes. Today I should be able to exercise the units a little more in terms of how they behave with some studio lights.
Regards,
110yd
Aries86
1 post
Joined May 2013
May 22, 2013 05:03 as a reply to  @ 110yd's post |  #9
It's lovely. Thanks for showing the steps of how it was created.
Aries86
frugivore
Gallery: 11 photos
Nov 20, 2013 06:16 |  #10
maximme wrote in post #15151761 (external link)
some sticker.
have fun.
Whortleberry wrote in post #15153010 (external link)
Thanks to both of you. I have one that I bought just to use as an AF assist that has this problem. I'll try to fix it tonight.
kenwood33
Nov 16, 2016 20:39 |  #11
I just tested all four of my triggers and 3 of them are aiming slightly higher-left to the center, but still usable. I notice one of the red beam pattern is much bigger than the other 3.
Gearlist
7,826 views & 0 likes for this thread, 7 members have posted to it.
1586 guests, 101 members online
