I ordered a set of extension tubes and am wondering if I use them with a lens that has image stabilization (or OS, VC etc) will this make a difference? Should I disable the stabilization, or will it help me?
Oct 22, 2012 00:11 | #1 I ordered a set of extension tubes and am wondering if I use them with a lens that has image stabilization (or OS, VC etc) will this make a difference? Should I disable the stabilization, or will it help me? Canon 6D & 7D. Panasonic GX85 and a number of ever changing lenses.
ceriltheblade Goldmember 2,484 posts Likes: 4 Joined Mar 2007 Location: middle east More info | Oct 22, 2012 07:51 | #2 i am interested in hearing this answer too 7D/5dIII
ceriltheblade Goldmember 2,484 posts Likes: 4 Joined Mar 2007 Location: middle east More info | Oct 23, 2012 04:06 | #4 thanks for that answer - but that wasn't the question 7D/5dIII
N4505 Mostly Lurking 17 posts Joined Sep 2012 Location: Athens, Greece More info | Oct 23, 2012 04:20 | #5 ceriltheblade wrote in post #15157704 thanks for that answer - but that wasn't the question the question wasnt the tripod - but rather the ETs I don't think you read the whole answer my friend.
IS works fine with ETs. Edward Jenner
KidMorbid Mostly Lurking 14 posts Joined Oct 2012 Location: Kentucky More info | Oct 26, 2012 15:15 | #7 I would just keep IS on. Why turn it off even with a tripod? It doesn't hurt quality at all does it? Canon 60D, Canon 24-105L, Canon 50 1.8, Canon 55-250, 430EX II
TheLostVertex Senior Member 520 posts Likes: 2 Joined May 2009 Location: Fl More info | Oct 27, 2012 12:22 | #8 |
Kid Morbid wrote in post #15172936 I would just keep IS on. Why turn it off even with a tripod? It doesn't hurt quality at all does it? I have a set of ET's and haven't changed my IS on any of my shots. Although new lenses are supposed to have tripod sensing IS, this is only sort-of true. If you half-press the shutter and let the IS settle down it (probably) won't go wonky. But certainly if you just take the shot as IS is starting up or are automatically focus stacking you can get blurred shots. Edward Jenner
LesterWareham Moderator More info | Nov 03, 2012 03:30 | #10 TSmith8779 wrote in post #15152510 I ordered a set of extension tubes and am wondering if I use them with a lens that has image stabilization (or OS, VC etc) will this make a difference? Should I disable the stabilization, or will it help me? A full contact set like Canon or Kenko ones will still operate the IS, however the effectiveness of traditional IS falls off with increasing magnification. Gear List
| Latest registered member is semonsters 1667 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
