Hello everyone
Let me introduce you to a photographic subject that I'm particularly fond of : Astronomy photography or commonly called Astrophotography. I will explain the steps you need to achieve to get some great shots of the sky.
First, I'll speak about gear, and what you need to get :
- A digital camera, even a point-and-shoot will do ( but a DSLR is better )
- A fast good image quality lens, manual or autofocus ( maximal aperture of f/2.8 or better )
- A sturdy tripod ( one that doesn't move or flex in mild wind conditions )
Now, I got a small "check list" that I do before each session :
- Set the camera to the highest usable ISO setting ( 3200 for the 5DmkII, more on that later on )
- Set your mirror to "lock up" ( cancels any vibrations due to mirror slapping )
- Set your Custom White Balance to a value around 3100-3600 K ( you'll thank me later )
- Set your lens to "manual focus" and focus with Live View at x10 on a bright object ( star or light ) at infinity
- Set your image quality to the highest RAW ( CR2, NEF, etc )
- Check the weather outside, haha.
- The longer your exposure time, the more likely you'll notice "trailing" ( drifting stars )
- The longer your focal length, same as above for a given exposure time, and vice versa
To set your maximum acceptable exposure time ( the less trailing possible ), just shoot and see if it's very noticable or not on your LCD screen at x10. The shorter your focal length, the longer you'll be able to set your exposure time. For example, on a full frame camera, you'll be able to have an exposure of 30 seconds at 14mm, 8 seconds at 85mm, etc.
Next step is to find a reasonably dark site. People living in crowded cities will have a hard time finding one, so just check the internet and Google "XXX light pollution map" where XXX is the country you live in. Weather websites are handy too, especially if you have to drive several hours to get to your dark site ( arriving and seeing clouds, or even rain isn't funny at all, trust me
).So now, you have everything set to be able to capture sky pictures.
Once you have all your raw shots, it's time to process them, and that can be pretty time consuming, espcially if you like nip-picking like me, haha.
You'll find here
Then I open the file in Lightroom and only apply "Lens corrections", to cancel the vignetting and correct the field ( important especially if you merge several images together ), and I right click on the image and "Edit it in Photoshop CS5".
I apply auto tone, contrast and color ( sometimes not all of them, just one or two of those auto features, depending on the result )
![]() | HTTP response: NOT FOUND | MIME changed to 'image/png' |
You can see that the colors are a lot better now, but there are all those purple/magenta fringing due to chromatic abberation. Luckily for us, Photoshop has a great tool to remove that : selective color correction ( it works for daylight pictures as well, most of the time ). Select the magenta color from the drop down menu and adjust the "Magenta" slider to about -75%, Cyan to +50%, Yellow to +100% and Black to +100% as well and you should get this :
A lot better, isn't it ? Now duplicate this layer and set the opacity of the top layer to 60-90% ( depends on the picture, choose 70% for this one ), then adjust the "Curves"
Adjust the "Contrast" of the top layer to 50-70% ( 60% for this image ) :
Adjust "Vibrance" then "Curves"
Resize your image to a better size ( 1920x1280 is good for the web ), "Smart Sharpen" on the top layer to about 30%, 1 pixel, "remove lens blur", flatten the image and you should have this result :
IMAGE LINK: http://www.flickr.com …6/sizes/o/in/photostream/
Those are the major steps I follow, but I often add a little tweaking here and there, and fiddle with the sliders and values to reach what I consider a more pleasing feeling when viewing the image. The best way is to experiment and practice, honing your skills and forming your picture signature, your own take at your image.
I hope you'll find this little guide helpfull, and if you have questions, don't hesitate to ask me right here
You can also check my Flickr and take a look at my Milky Way pictures, most of them ( 99% ) are done using this guide : a DSLR, a lens and a tripod.
