Hi group,
I have a problem with my Canon 60D. I have set under the "C" setting, a user defined option with ISO forced at 100, 2 second timer, forced Av and +/-1.3 bracketing.
Now, when I use the "C" setting, sometimes the bracketing works and sometimes it does not.
It ALWAYS takes 3 shots, and all the other settings work. But, when I look at the 3 photos in PS, the aperture/timing is always the same for all 3 shots. However, in the meta data for the shots, it does show either "--", "-1.33" or "+1.33" in the exposure setting. All 3 photos look that same.
Sometimes, it does work - and I get the above, but the 3 photos have different exposure durations (so one is darker, one is lighter than the middle) as I would expect.
Do I need to reset something after every set of 3 (such as change setting to Av then back to C, or switch camera on/off)?
Confused.
