Thread started 25 Oct 2012 (Thursday) 13:45
5D Mark II - AF issues? Question
Pepe ­ Guitarra
Joined Jul 2012
Oct 25, 2012 13:45 |  #1
My 5DII has been perfect with the 24-105/4 and the sigma 100-300/4, and the sigma 70-200/2.8 OS, and it worked fine with the 50/1.8 I bought here. However, I have not used the 50/1.8 for about two months. Today, when I put it on, it did not AF. Am I doing something wrong? Have I turned anything wrong? I tried with the other lenses and it is perfect. Any advise before I go crazy.
It's not a photo until you print it! :cool:
Click here (external link), this is myflickr (external link) gallery
windpig
Chopped liver
Gallery: 6 photos
Oct 25, 2012 13:47 |  #2
AF switch on?
Go ahead, spin the wheel.
apersson850
Oct 25, 2012 14:17 as a reply to  @ windpig's post |  #3
Other lenses, do they work?
Anders
amfoto1
Oct 25, 2012 14:19 |  #4
Operate the AF switch on the lens a few times. Sometimes with periods of disuse some oxidization forms on the metalic contacts inside them, interrupting the connection. Most of those types of switches are "self cleaning" if they are turned on and off a few times.
You also might try cleaning the electronic contacts on the back of the lens and the corresponding pins just inside the front of the camera. Just lightly dampen a clean cloth with some isopropyl (rubbing) alcohol, then carefully wipe the contacts. Be careful to avoid touching the lens optics and the mirror in the camera.
Hopefully one of these will help.
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - ZENFOLIO (external link)
joeblack2022
Joined Sep 2011
Oct 25, 2012 14:21 |  #5
Sounds like a lens issue rather than the camera, do you have another body to test with?
Joel
Pepe ­ Guitarra
Joined Jul 2012
Oct 25, 2012 15:26 as a reply to  @ joeblack2022's post |  #6
Thanks for the input. Other lenses work just fine. I just received my 400/5.6 and it is on the money. However, the nifty fifty does not work now. I am at work now, and I will try the on-off-on-ff several times to see what happens. If nothins, I will clean the 50/1.8 contacts to see if it works. The MF works just fine.
Pepe ­ Guitarra
Joined Jul 2012
Oct 25, 2012 15:27 |  #7
joeblack2022 wrote in post #15168663 (external link)
No, it is in the mail. The 7D should be arriving on Monday. I will try on that one then.
Perfect_10
Joined Aug 2004
Oct 26, 2012 11:18 as a reply to  @ Pepe Guitarra's post |  #8
Your title is misleading .. it should be 50 1.8 II - AF issues ;)
My Gear List  :p
Pepe ­ Guitarra
Joined Jul 2012
Oct 29, 2012 20:33 |  #9
Perfect_10 wrote in post #15172012 (external link)
Well, I got a 7D and the 50/1.8II works just fine. I upgraded the firmware of the 5DII from 2.0.7. to 2.1.2. and the 50/1.8II still does not AF on the 5DII. I notice that the aperture shows as F000. I can MF, but no confirmation. THe 5DII works fine with the Sigmas and the Canon 400/5.6.
I must confess that the reason I purchased the 5DII is to be able to use my old MF SuperTakumar lenses in a FF camera. I bought some adapters that come with a chip and set couple of them up. THey worked fine for a while. I cannot set them up again because the 5DII does not recognized them anymore. I have several adapters, some more expensive than others, but all with the dandalion chip. Did I screw up my 5DII? The 50/1.8II seems fine, and AF fine with the 7D. If you have some idea (I hope is a matter of turning some functions off). I reset the 5DII and still subsist. Is it about time to send the 5DII to Canon? Your input is welcome. Pepe
1,078 views & 0 likes for this thread
Latest registered member is sdc123
714 guests, 372 members online
