Thread started 25 Oct 2012 (Thursday) 15:00
Dropped 5D MK II with 24-70L.....how !@#&%$ am I?
GOA510
Joined Mar 2011
Oct 25, 2012 15:00 |  #1
For those who care for a story, I'm going to be moving in the next couple months and have known for awhile I have too much stuff. So I decided to donate a bunch of old clothes and shoes and sell various electronics and snowboard gear. Setup my tripod, couple video lights to make it easy and mounted my 5D MK II with 24-70L on my tripod. Couple items in and everything is going as it should, then all of a sudden my 5D falls off the tripod slamming hard onto the hardwood floor below. It sounded like I dropped a 30lb dumbbell onto the floor. My heart dropped from my chest and stopped beating. I looked down and went to grab the camera figuring the lens had broken off the body, and interestingly enough it was still locked on and mounted on the 5D. First thought I had as I picked it up was "Damn Canon builds some tough ****! That was a 5 foot fall with The Brick on it! Awesome!" But right after I finished saying "Awesome!" to myself, I noticed this...
HTTP response: 403 | MIME changed to 'text/plain'
It still had power, still focused but that's as far as I went with seeing what it could do. I detached the lens, turned off the 5D and pulled the memory card and battery. It doesn't look to have any visible internal damage that I can see, but with my luck I'm sure I messed something up internally. Now for the 24-70L, it looked and appeared to have no physical damage. Glass looked fine, nothing broke off or sounded loose inside. It did however have one loose screw on the metal mount that locks it onto the camera body. Screwed that back in and mounted it on my 1D MK III and it still focused away. However, after taking a few photos with it, I think the AF could be off. At most FL's it focused like before, but I did notice at FL 24mm or close to it, it had a hard time focusing or wouldn't.
So I ask, how !@#&%$ am I? I have a CPS Gold membership so Ill atleast save 30% on repairs there, but going off what I've wrote and you can see in the photo, any idea what its going to set me back in repairs? This week has not treated me too well and this event last night really didn't help.
[1D Mark III][5D Mark II][15 2.8 Fisheye][17-40 F4L][24-70L][85 1.2L][70-200 F2.8L IS][300 F2.8L]
emelvee
Oct 25, 2012 15:06 |  #2
One of my classmates had a random crack in her camera (she didn't drop it or anything - it really was the most random thing) somewhat similar to yours. She took it in and I think it cost 200-300? Hope all goes well!
Canon RP | Canon 6D | 70-200 f/2.8 I | 50mm f/1.4 | 16-35mm f/2.8 II | 580EX II x 2
Tumblr (external link)
advaitin
Gallery: 434 photos
Joined Jun 2003
Oct 25, 2012 15:13 |  #3
Cheapest insurance you can buy is either Really Right Stuff or Kirk Enterprises L-brackets specific to your repaired or new camera.
I don't normally drop any camera, but tripped twice in Europe a few years back sending a Canon XTi smashing to concrete each time. Zero damage to camera but some scratches on L-bracket.
Canons to the left, Canons to the right,
We hold our L glass toward the light,
Digitizing in a snap reflective glory
That will forever tell our imaged story.
Saint728
Oct 25, 2012 15:20 |  #4
Just wondering how your camera could have "fallen off" your tripod? Did your tripod tip over or your camera wasn't clipped on right?
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
GOA510
Joined Mar 2011
Oct 25, 2012 15:38 |  #5
emelvee wrote in post #15168836 (external link)
Thank you! Hopefully I get lucky and the repair is in that range :)
advaitin wrote in post #15168860 (external link)
That is definitely something I will be looking into for the future. I've always seen them but classic case of "I'm careful I don't need it right now" :(
Saint728 wrote in post #15168904 (external link)
Take Care,
Cheers, Patrick
I honestly don't know. It was mounted onto a Velbon PH-173 ball head and was fully screwed in. I even remember checking it once or twice during shooting to make sure it hadn't loosened (I was shooting portrait) and it was tight. This Velbon head does have a double-dial setup where one is spring loaded so that the stud can move up and down. I'm guessing this is for a quicker release? I'm not 100% sure which is why I have always doubled checked to make sure everything was secure and tight. My guess in this case would be that the pressure from the camera being in the portrait angle pulled too much causing that spring loaded dial to release? But I still don't see how it can un-screw itself and the threads on the 5D's tripod mount aren't stripped either. Really bizarre and my fault for obviously failing at some point. Here's the head I have (well not for long, getting rid of this head and tripod ASAP!)
900
x
3876
TOO LARGE!
EMBED PREVENTED, IMAGE TOO LARGE:
http://www.occamera.co​m …une212011/velbo​nph173.jpg
Click here to see our image rules.
Pjay
Oct 25, 2012 15:41 as a reply to  @ Saint728's post |  #6
Best of luck with any necessary repairs to your camera body and lens. I always double check the security of the base plate on my tripod before releasing my hold on the camera, if you're in a hurry it might not be engaged fully...
The only significant camera drop I had involved getting tangled in the strap and losing my grip - that was with a D700 with a 105mm macro lens attached. Only damage was a shattered UV filter, no ill effects on either camera or lens (I had the latter checked out by a lens repair specialist just to be sure.). When I'm out and about with my camera, I use a Black rapid sling, but other than that, no more straps/slings for me!
Flickr (external link) http://instagram.com/p​ixels_n_film (external link)
'Photography is a love affair with life.' Burk Uzzle
advaitin
Gallery: 434 photos
Joined Jun 2003
Oct 25, 2012 16:08 |  #7
I use only Arca-Swiss style lens or camera brackets, feet or lens plates and Kirk or RSS (some Jobu) QR clamps, but always with screw tighteners, rather than a lever tightener.
GOA510
Joined Mar 2011
Oct 25, 2012 16:46 |  #8
Pjay wrote in post #15168976 (external link)
Thank you :) I'm thinking I didn't have it fully engaged. Even though it was tight, it clearly wasn't secure enough. My next tripod head purchase will definitely be one with a locking plate. Atleast that way if the camera is going down, its taking the complete tripod setup with it. Glad to hear your drop only damaged the UV filter! The D700 is one of my favorite bodies, I would really hate to ever damage one. As far as straps for me, if the strap isn't around my neck its around my wrist twisted and looped over and over in case the camera comes free. Now Ill probably never take my strap off my neck no matter where its mounted haha
advaitin wrote in post #15169068 (external link)
Next head will definitely have a locking plate as stated above. This was a costly lesson for me. It might not require me to have to fully replace both camera and lens, but its still hundreds of dollars that could've gone elsewhere :(
1,487 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is yourdesignguys
1024 guests, 156 members online
