Thread started 27 Oct 2012 (Saturday) 11:14
Buying a new lens. Thoughts?
tbsguy18
Joined May 2012
Oct 27, 2012 11:14 |  #1
I decided to purchase a new lens to somewhat cover all my focal lengths. I was getting by just fine with what I have, but I've been shooting more landscapes and the the 50mm just isn't wide enough all the time, especially with a crop sensor. Even with some of the portraits I do, I find myself having to back up too far. It's exhausting (or I'm lazy?) And I usually run out of room when I'm shooting inside.
I have a Sigma 28-70, but it's just too soft.
I kind of narrowed down my search to the 30mm range and like the following lenses:
Canon 28mm 1.8 (external link)
Sigma 30mm 1.4 (external link)
Canon 35mm 2.0 (external link)
They all fit into my budget, but I wanted to get some feedback/advice from the POTN community before I pull the trigger. I open the floor to any comments, suggestions, preferences, etc...
Gripped Canon 60D 50 f/1.8---17-50 f/2.8---70-200 f/4 L
michgirl
Gallery: 13 photos
Oct 27, 2012 11:22 |  #2
When I had my crop, I had the Canon 28mm f/1.8 and did use it a lot. Great for almost anything. If you get too close with it, it does distort. I would stand back a bit and crop later. Absolutely a great lens. I found this lens too wide for full frame though, and sold it.
Robin
Canon 6d / EF Lens: 24mm-105mm / 40mm f/2.8 / 28mm f/1.8 / 50mm f/1.8 / 85mm 1.8 / EF 70-300mm II USM
Canon T6i / EFs Lens: 24mm Pancake / 18-55mm STM / 18-135mm STM / 55-250mm STM
FEChariot
Gallery: 13 photos
Joined Sep 2011
Oct 27, 2012 11:22 |  #3
I would go with the 30/1.4 of those choices but if you want to do landscape and the widest you have now is 28mm, I would get the Tamron 17-50/2.8 non VC instead.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
tbsguy18
Joined May 2012
Oct 27, 2012 11:36 |  #4
FEChariot wrote in post #15175443 (external link)
I was thinking about that one too. I had it on my Amazon wish list.
This one right? ----> Tamron 17-50 (external link)
Lexar
Joined Aug 2012
Oct 27, 2012 12:29 |  #5
I went crazy thinking about this and ended up with the Sigma 30. My main motivation was that I wanted something for low light and my 50mm was just way too long for indoors.
Reasons are:
1. Canon 28 - received a lot of reviewing saying that its not sharp.
2. Canon 35 - looked like a winner.. but I had a 50 f1.8 so this would of been a little too close in distance also I wanted as wide as possible. I also recently started shooting the 50 wide open and found the bokeh very busy and read that the 35 is even worse due to the 5 blades.
3. Tamron 17-50 or Sigma 17-50 was a good range but overlapped to much with my 15-85. Also after lots of testing realized that f2.8 vs f3.5 open or even f4 at 50mm is really not a huge difference for low light.
So I ended up with the Sigma 30mm and could not be happier.. at f2 its sharp and f2.8 it is sharper then any other lens I have.
Also in low light its great and lets me take shots that I could not normally. I also had an AMAZING bokeh.
Canon R7 | RF 18-150 | RF 100-400 | Canon 70D | 15-85IS | Σ17-50/2.8 | Σ30/1.4 | 40/2.8 Pancake | 100/2.0 | 55-250STM | 430EXII
tbsguy18
Joined May 2012
Oct 27, 2012 12:41 |  #6
Lexar wrote in post #15175603 (external link)
Reasons are:
Awesome thanks for the advice!
If you didn't already own the 15-85, would you have gone with one of the 17-50?
Lexar
Joined Aug 2012
Oct 27, 2012 12:57 |  #7
That's hard to say.. it depends what you need.
I upgraded from my kit lens 18-55 to the 15-85 because I wanted more range and faster focus. I usually use the camera for walking around, traveling, events, etc... I always felt that 55 was too short and kept wanted to swap lenses.
With the 15-85 I find the range perfect. I no longer need a UWA since 15 is great and unless I really want a zoom the 85 is perfect.
I realize everything in photography is a compromise :)
If I get a 17-50 I would still not have a real low light prime and I would likely switch more to a zoom and maybe even feel a need for UWA. (This of course is my opinion)
Lots of people are very happy with the 17-50 as a general purpose and say its better because its f2.8 and already has good enough low light and a good bokeh.
jerbear00
Joined Mar 2011
Oct 27, 2012 14:01 |  #8
Landscape on crop = 10-22 for wider perspective
If your looking for a fast walkaround prime though get the sigma 30. It isn't as sharp as other stopped down but the performance nearer the wide open end is fantastic
5d3 & Lens CoLLector
Gear List/Feedback
amfoto1
Oct 27, 2012 14:51 |  #9
The 28/1.8 is just fine on a crop camera. It's slightly soft in the corners wide open, but that only shows up on FF cameras.
The Sigma 30/1.4 is a good alternative, except it's bigger, heavier and an awful lot of them seem to need to go in for focus calibration or get exchanged. With a 60D, you don't have Micro Adjust, so can't make the adjustments yourself.
35/2 just isn't wide on a crop camera... and it's too close to 50mm.
Another lens you might want to consider is the Canon 20/2.8. I really like it on a crop camera, but use it on both FF and crop.
If you want wider than that, there aren't many primes... Probably will have to consider a zoom. The Canon 10-22 is excellent. The Tokina 12-24 is very nice, too.
bubbygator
I can't tell the difference
Location: Sarasota, sunlight, butterflies, fish, Gators, and Seminoles
Oct 27, 2012 15:32 as a reply to  @ amfoto1's post |  #10
The IQ on the 28/1.8 is excellent - it can easily be cropped to format as you wish. Many times I've shot a "fair" crowd/group shot and later in processing found a really good section (action/expression) for a crop pic. I guess that wouldn't apply to architecture.
The avatar is my middle grandson. (the TF can't tell the difference, but the fish is frowning and the kid is grinning)
wimg
Oct 27, 2012 19:11 |  #11
You could also consider a good used 24 F/1.4L Mk I, if your budget suffices and you can find one. It is a great lens on APS-C, and the rendering is absolutely marvelous. Bokeh is very good too, especially for a 24 mm lens.
Other than that, based on my own experience, I would certainly also consider a 28 F/1.8. That is a little undervalued gem, IME.
Kind regards, Wim
artyH
Oct 27, 2012 19:30 |  #12
The 35F2 is a fine lens, with excellent resolutions ...my most used lens.
AF is accurate and the lens is good at F2.
I use it on my 60D and T2i.
1,619 views & 0 likes for this thread, 9 members have posted to it.
1081 guests, 157 members online
