Does in camera sharpening generate additional noise? Also would reducing any color channels or any other settings help to reduce noise as well?
Oct 27, 2012 19:32 | #1 Does in camera sharpening generate additional noise? Also would reducing any color channels or any other settings help to reduce noise as well? Wes
windpig Chopped liver More info | Oct 27, 2012 21:46 | #2 The best way to reduce noise is to not underexpose. Would you like to buy a vowel?
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Oct 28, 2012 04:32 | #3 Any sharpening makes the existing noise more visible; and some noise always exists, even at ISO 100, especially in the shadows, although at low ISOs it is hardly visible. Whether the sharpening makes the noise visible and/or objectionable depends on how much noise there is without the sharpening and (more importantly) the standards of the viewer. (Personally, I like a bit of noise and often add a little film-like grain to images.) OTOH, noise reduction reduces sharpness - the two are opposite sides of the coin and finding the best balance between them is difficult. Elie / אלי
kfreels Goldmember 4,297 posts Likes: 11 Joined Aug 2010 Location: Princeton, IN More info | Oct 28, 2012 18:23 | #4 Sharpening involves the contrast between the pixels as well as a the area around the pixel contrast area referred to as the sharpening halo. With in-camera sharpening you only have control over the contrast portion. You can't change the size of the halos. I am serious....and don't call me Shirley.
Oct 29, 2012 01:08 | #5 calypsob wrote in post #15176687 Does in camera sharpening generate additional noise? Also would reducing any color channels or any other settings help to reduce noise as well? Actual pictures from a Canon 60D that has enhanced sharpening applied in camera using Picture Styles.
No noise issues. No exposure issues, either.
Oct 29, 2012 03:20 | #6 Geez you guys hit the nail on the head. I need to ask questions in general photography more often. The reason I asked is because I have been doing widefield shots of the milky way and I do median stacks of multiple exposures to remove iso 1600 noise. Sharpening the night sky has always produced strange results for me, normally I do highpass sharpening but I am usually unsatisfied with the results when dealing with stars because it creates extremely sensitive and funky halos. I have been tweaking my WB, and color settings alot lately trying to dial in a good custom setup for stacking and I think I am going to try turning the sharpness down all the way after some of the things I just learned in this thread. It seems that median stacking pre-sharpened images with the objective of removing noise is counterintuitive. TZALMAN, you are right about the blue channel, it is always the noisiest channel when I edit RGB separately in CS5, red is a trouble maker as well. Wes
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Oct 31, 2012 06:06 | #7 calypsob wrote in post #15181268 Geez you guys hit the nail on the head. I need to ask questions in general photography more often. The reason I asked is because I have been doing widefield shots of the milky way and I do median stacks of multiple exposures to remove iso 1600 noise. Sharpening the night sky has always produced strange results for me, normally I do highpass sharpening but I am usually unsatisfied with the results when dealing with stars because it creates extremely sensitive and funky halos. I have been tweaking my WB, and color settings alot lately trying to dial in a good custom setup for stacking and I think I am going to try turning the sharpness down all the way after some of the things I just learned in this thread. It seems that median stacking pre-sharpened images with the objective of removing noise is counterintuitive. TZALMAN, you are right about the blue channel, it is always the noisiest channel when I edit RGB separately in CS5, red is a trouble maker as well. why not use RAW, many stacking programs like Helicon Focus can use RAW files
Nov 05, 2012 15:32 | #8 watt100 wrote in post #15189896 why not use RAW, many stacking programs like Helicon Focus can use RAW files I only use RAW Wes
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Nov 05, 2012 16:56 | #9 calypsob wrote in post #15210590 I only use RAW OK, so why worry about in-camera sharpening
Nov 06, 2012 19:31 | #10 watt100 wrote in post #15210916 OK, so why worry about in-camera sharpening Well I have been trying to get the least amount of noise possible so that when I make big prints like 20x30's there is as little grain as possible. When you shoot the milky way it gets tricky to decipher noise from the actual stars so I am just making as many precations as possible. RAW does offer alot of flexibility but it has its limits which is why I asked about in camera sharpening causing noise. At this point I have made a picture style with the sharpening set to zero when I plan to stack images. Now I just have to wait for all these clouds from Sandy to dissipate so I can test out my adjustment. Wes
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Nov 06, 2012 22:45 | #11 In-camera sharpening applies only to JPEGs produced by the camera. If you're working with the RAW files then the in-camera sharpening is irrelevant. RAW does offer alot of flexibility but it has its limits In the world of image processing, there's nothing a camera can do that you can't do in post. "If you're not having fun, your pictures will reflect that." - Joe McNally
Nov 07, 2012 04:24 | #12 Curtis N wrote in post #15216613 In-camera sharpening applies only to JPEGs produced by the camera. If you're working with the RAW files then the in-camera sharpening is irrelevant. I'm particularly curious about this sentence:In the world of image processing, there's nothing a camera can do that you can't do in post. As previously pointed out, when working with a RAW file, you can do selective noise reduction first, then selective sharpening, with a level of flexibility that no camera preset can approach. Another significant factor that hasn't been pointed out yet in this thread: Downsizing is an extremely effective noise reduction tool. If you have resolution to spare (more than maybe 240 pixels per inch at your intended print size), then you can apply noise reduction, then downsize, then sharpen. The order in which you perform those actions is of paramount importance. Curtis are you saying that picture styles do not work on .CR2 RAW files? Also I was not aware of downsizing to remove noise. Is there a specific procedure you could refer me to for downsizing? Wes
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Nov 07, 2012 06:23 | #13 The only camera settings that are going to directly affect what a RAW file records as image data are the three exposure setting values, Shutter Speed, Aperture and the ISO sensitivity. Having HTP set will also affect the image as it changes the way the in camera light metering sets the exposure for any given ISO value. HTP effectively causes the camera to expose to the left (appears darker than it needs to). Canons DPP software is able to deal with this but other RAW conversion software is either strictly dumb or only knows to boost the image brightness for you to compensate, if it knows to look for the HTP flag in the EXIF data. All other in camera processing options have NO effect on the raw image data in a RAW file. As all RAW files include a fully processed JPEG conversion as an embedded preview, the in camera settings do affect the preview. As with HTP that I have already mentioned Canon's DPP RAW converter is able to pick up the settings used to generate the JPEG preview in camera and apply the same settings as the default conversion. This is why DPP often "looks better" by default than using software by third parties. Third party software such as Adobe's LR or PS's ACR module also tend to use a much lower level of processing by default, as they assume that the photographer will be making their own adjustments to the image.
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Nov 07, 2012 06:56 | #14 Alan's response was pretty comprehensive, and accurate. "If you're not having fun, your pictures will reflect that." - Joe McNally
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Nov 07, 2012 07:07 | #15 As far as downsizing to reduce noise, the concept is simple enough. When you downsize an image the computer has to interpolate between neighboring pixels and somehow average them to create a new pixel. If there is one "rogue" pixel in a group (digital noise), it becomes less noticeable when averaged with its neighbors. "If you're not having fun, your pictures will reflect that." - Joe McNally
| Latest registered member is semonsters 1609 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
