idealhobbies wrote in post #15178398
I have an 18-55mm IS II kit lens that's quite loud when focusing. I have 2 of them (2 cameras) and 1 is
significantly louder than the other. Suggestions or ideas? Is there something that needs lubed (can you lube a lens?) or is something going south? It's my daughters camera, and I really can't replace the lens anytime soon.
If one 18-55 IS kit lens is SIGNIFICANTLY louder than the other, then there must be some sort of a problem. It's not worth worrying about though because a used lens can be bought for $100 or less. Just keep using it and hope it doesn't fail completely. If it does fail, or you get tired of the noise, just buy another used one.
