Thread started 28 Oct 2012 (Sunday) 13:26
Wireless fluorescent light??
DJR222
Joined Feb 2012
Oct 28, 2012 13:26 |  #1
Anyone know how this fluorescent light is wireless?
http://500px.com/photo​/5120591 (external link)
http://500px.com/Danie​lRoy (external link)
DavidR
Oct 28, 2012 13:45 |  #2
It's not wireless, the wires are hidden or cloned out.
Sony a9II
mike_d
Oct 28, 2012 13:50 |  #3
DavidR wrote in post #15178959 (external link)
That or the shoot was done under some super high voltage transmission lines. :lol:
DJR222
Joined Feb 2012
Oct 28, 2012 13:56 |  #4
Do you know what kind of cables it is to set up the lights like that? obviously it has no housing and i've seen some other projects like this and you could see the cables in it but i can't seem to find where to get them
DavidR
Oct 28, 2012 14:11 as a reply to  @ DJR222's post |  #5
It would be a DIY type job. Remove the housing and extend the wires.
Sony a9II
katodog
Oct 28, 2012 14:13 |  #6
Ask the guy who shot the photo, worst thing that happens is he tells you.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear- Flickr (external link) - Facebook (external link) - Smoke Photography - - Sound-Activated Paint
Stuperfox
Gallery: 12 photos
Oct 28, 2012 14:33 |  #7
katodog wrote in post #15179030 (external link)
Almost, the worse thing that happens is what you already know now.
I have seen these before, they are acutally strobe but they are a few hundred dollars each. You mount a speedlite inside them and use that. I dont remember the name though but they are hella expensive for that they are. I do have the broncolor light stick but that is only 18" long but that is $3000 without a power pack.
Nick
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
isoMorphic
Oct 28, 2012 21:32 |  #8
I can see a faint wire on the one near the pillow.
Jarhed27
Joined Feb 2012
Oct 29, 2012 06:57 |  #9
That light might not even be lit - possibly really good post work.
Nice pic / concept regardless.
Canon 60D, Gripped, a bunch of consumer glass, and a really cheap tripod.....
katodog
Oct 29, 2012 07:05 |  #10
Looking at one of the other photos it looks like he's got the socket taped to the light bulb. All you'd really have to do is strip the innards from a fixture, then tape the ends to the bulb and plug it in. IF you taped the wires to the side of the bulb, and made sure the model held the light so the wires were behind the bulb you'd never see them.
In this shot you can see the yellow wires n the bed. Light fixtures normally have yellow and red wires, tape the red ones to the back of the bulb and clone out the yellow ones, you'd never see them...
http://500px.com/photo​/5120589
The slight rectangular look on the near end of the bulb is the socket, a simple bi-pin socket that almost disappears if you wrap it in black electrical tape. The brightness of the light would "hide" it most of the way, and since your focus isn't directly at the light you probably wouldn't notice the socket. You could even go so far as to mount the sockets to a piece of flat bar stock; it would hold the sockets more firmly so you wouldn't have to worry about them coming loose while shooting. I can take apart one of my fixtures and take some pics, so a possible solution to the question of how it's done can be seen...
Luckless
Joined Mar 2012
Oct 29, 2012 11:14 |  #11
There are also a few options for tubes with a socket on a single end. Coaxial tubes (One tube inside the other. arc goes down the centre tube, hits a back plate, is then allowed to arc down the outer tube, insulated by glass from the inner. And bent tubes, where a tube is bent in a big U and stuffed inside a larger diffuser to give the appearance of a single tube.
Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
Flickr: Real-Luckless (external link)
flyingphotoman
Jan 23, 2013 19:09 |  #12
For some reason, I can't keep my mind thinking about that fluorescent tube!!
1,833 views & 0 likes for this thread, 9 members have posted to it.
1090 guests, 169 members online
