Thread started 30 Oct 2012 (Tuesday) 09:51
7d weather proofing
doofuss
Oct 30, 2012 09:51 |  #1
I was down the coast this afternoon takings some pics of a storm front that was approaching.
The wind was blowing a gale and there was lots of sea spray and sand being blown around.
After about half an hour and having taken a few photos, (and a few lens changes) my 7d shut down and wouldn't turn back on. I thought it might have been battery related so I replaced both batteries in the grip.
It then turned on, but shut down again after just a few minutes. Every time I turned it back on it kept shutting down and powering off every couple of minutes. The batteries were reading 100%.
I called it quits and headed back to my car to head home. En-route home I stopped to check out a quiet little bay along the coast (no where near as much wind) and the camera worked perfectly the whole time I was there.
I have no idea why the camera kept shutting down whilst I was on the exposed section of coast, other than possibly poor weather sealing.
Has anybody else ever experienced this sort of problem with their 7d?
Canon 1dx & 7d gripped, Canon EF 100-400mm f/4.5-5.6 L, Sigma 120-300 f2.8 (sports), Sigma 70-200mm f2.8, Sigma 24-70 f2.8, Canon EFS 17-55mm f2.8, , Canon EF 50mm f/1.8, Sigma 8-16mm f4.5 - 5.6, Sigma 2 x teleconverter, Canon 600EX-RT Speedlight.
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Oct 30, 2012 10:06 |  #2
The 7D is not weather proof, it is weather resistant, which is a big difference. One drop of water in the wrong spot can kill it(worse case scenario), but it is still a robust camera.
5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
Sikor7
Oct 30, 2012 10:39 |  #3
I would NEVER consider a lens change under those conditions! As a matter of fact, you may want to remove that lens now (in a dry, calm room) and let the body dry out.
40D w grip
28-300 IS L - 24-105 IS [COLOR=red]L - 100-400 IS L
580 EX - 580 EX II - ST-E2
Nice Canon Back-Pack and some other stuff...
"I think I just stimulated the economy!!!"
OneJZsupra
Oct 30, 2012 10:55 |  #4
Sikor7 wrote in post #15186494 (external link)
This, also what firmware do you have? Do uou have v2.0? Or v2.0.3? The newest fixes a freezing issue with 2.0
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
Scapevision
Oct 30, 2012 12:23 |  #5
I've had this happen to me in Hawaii, it would shut down after a long exposure in 30C. It would act up all the trip, but after I came back in Canada it's totally fine. I suspect there was some issue with metal expansion or something with power contacts. I pinpointed it to be the issue with the battery door (possibly)
scapevision.carbonmade​.com (external link) and on Flickr (external link)
"Amateurs worry about equipment, professionals worry about money, masters worry about light. I just take pictures"
TheFarmer
Joined May 2012
Oct 30, 2012 14:34 |  #6
I'm surprised you were brave enough to change lenses in that condition! My only guess would be something got damp during the process and the camera didn't like it and when it cleared up (when you got to your next destination), it was fine.
The camera body itself is pretty robust with mist/sand sealing but if you're not using a lens with the rubber seal (around the lens mount, most L-lenses have this rubber seal) you could be letting stuff in through there.
And if you haven't seen this, it's a great watch of the 7D! http://www.youtube.com …=RCT-YMgjm9k&feature=plcp (external link)
5DM3 | 35mm F2 | Sigma 50mm 1.4 | 24-105 F4L | Canon GP-E2 GPS | Canon ST-E3-RT | 2x 600EX-RT | The End
amfoto1
Oct 30, 2012 14:55 |  #7
Very risky being out in wet weather with any camera that's not designed and rated for underwater use, without giving it some protection. Salt spray is particularly bad on cameras and lenses (inside an out).
7D has a lot of weather/dust resistant sealing... but it's far from sealed! It's not as good as 1D series, and a bunch of those died at a rainy Super Bowl a few years ago (enough that Canon support ran out of backup cameras). In that case, it turned out the most common cause was water intruding through the memory card sockets... probably while the door was open.
The minor little rubber "seal" on the bayonet mount of some of the L-series lenses mostly just gives false sense of security. There are plenty of other ways that water (and dust) can intrude into the camrea and lens.
If you need to shoot out in nasty weather, do yourself and your gear a favor and get some sort of protective wrap for the camera or make one out of plastic bag(s), gaffer tape and rubber bands.
If a camera acts up in weather, or you know for sure it's gotten soaked, the worst thing you can do is turn it off and back on. You should turn it off, remove the batteries and get to shelter, dry it out for a few days before powering it back up. Continuing to use a wet camera, powering it up and down repeatedly, really risks frying the electronics and destroying the camera.
I had a couple 30Ds get soaked in a downpour a few years ago. With lenses and flashes on both of them. No way to get to shelter for about 15-20 minutes! I immediately powered them down, wiped off the worst of the wet and removed the batteries as soon as I was in a dry place. Then took them home and dried them out for 3 or 4 days... opened everything I could, removed lenses and grips, ran hair dryer on low nearby from time to time. Did the same with the lenses and the flashes. Everything survived just fine.
Now I have plastic bags, rubber bands and gaffer tape, and cheap plastic rain ponchos for myself + the gear in each of my camera bags and backpacks, plus some extras in the car.
doofuss
Oct 30, 2012 19:17 |  #8
Thanks for the info folks.
I was very mindful of doing the lens changes and had set up a small wind-break / shroud behind a very large rock outcrop that afforded a lot of protection from the wind so I could change lenses over without too much fear.
At the moment I only have firmware version 2.0.0, so I am hoping it may be as simple as Seoul4Korea said above that 2.0.3 fixes a "freezing" problem with earlier firmware versions.
I am fortunate enough to live near the coast in Perth Western Australia, but I believe many websites rank us as the 3rd windiest city in the world. Even on scorching hot Summer days we will have 30 knot plus sea-breeze winds hit the coast in the afternoons.
Unfortunately strong winds is something I have to contend with nearly every time I head to the coast to take photos.
If you do a Google Image search and type in Greenough Trees, you will see how strong the winds on the WA coast are......The trees near the Greenough coast grow horizontally as the wind is constantly pushing them sideways!
OneJZsupra
Oct 30, 2012 19:57 |  #9
Good luck, let use know if the update works.
1,845 views & 0 likes for this thread, 7 members have posted to it.
7d weather proofing
1699 guests, 140 members online
